WESTIN SAFARI LIGHT BAR fit an '07???
Discussion in 'Lighting' started by Fast Eddie, Jul 7, 2008.
  1. Jul 7, 2008 at 12:29 PM
    Fast Eddie
    Fast Eddie [OP] Active Member
    Toronto, Ontario. Canada
    07 Tacoma 4dr TRD Long Box
    XDi Cold Air Intake Pioneer F90BT Husky Floor Liner Coverking Seat covers
    Finally decided I liked the Westin Safari Light Bar but it says it only goes to 2004.
    Is there any change for a 2007 or should it fit.
    I e-mailed Westin and a girl kept e-mailing back part #'s for the 04 but would not commit either way if it would fit my 07.
    Any help appreciated.
    http://www.westinautomotive.com/pages/PRODUCT_SL-apps.html
  2. Jul 7, 2008 at 12:31 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    the major model change was for 05. I doubt the 04 would work on your 07. Anything listed for 05-09 would work for you.
  3. Jul 7, 2008 at 12:36 PM
    Rtrn2taco
    Rtrn2taco Nostalgia...
    Philadelphia
    08 DC PreRunner (silver)
    I don't believe westin makes the safari bar for your truck (05+). you will have to go with the e-series or ultimate. I think they abandoned new applications with the inception of the e-series.
  4. Jul 7, 2008 at 3:47 PM
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    Technically it will not work. I had an 04, with a safari bar that I traded for my 07. I kept the safari bar, and tried to mount it on the 07.
    one the holes were not in the right place, so I drilled some new holes, and then mounted it up. Then I stood back and looked at it. The 04 mounting points were a lot higher up on the chassis than the mounting points on the 07, so it sat nearly 4 inches below the front bumper and about 8 inches off the ground thus completely ruining your approach angle.
    If you were good with metal and a welder you could probably fab up some mounting brackets for the safari bar for the gen 2 trucks, but plug and play out of the box it is not an option.
    That said I may just end up doing that at some point and will post the specs if I get it to work and look good as I really am not a fan of the stupid looking skid plates (my oppinion your mileage may vary) on the e series or ultimate, or whoever else's bull bar.
  5. Jul 8, 2008 at 11:26 AM
    Fast Eddie
    Not sure why they would not make them for the Gen 2's.
    Every other Tacoma has a standard Westin Bull bar, but I too don't like the skid plate portion.
    I even looked at buying the Hunter Bull Bars but I think they too aren't available for 07.
    What gives!!??!!
  6. Jul 8, 2008 at 11:29 AM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    Get a regular bull bar and remove the skid plate if you dont like it. It just screws on and off. If your looking for Off Road protection, perhaps a full bumper is better for you.
    BTW - Please dont use all caps in a thread name or post, its very annoying and is generally interpreted as shouting.
  7. Jul 8, 2008 at 11:29 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    hunter's are avail for 05+...any 05+ will fit everything from then on
