Westin Ultimate Bull Bar
Discussion in 'Product Reviews' started by Don Groff, Aug 10, 2012.
  1. Aug 10, 2012 at 7:01 AM
    Don Groff
    Don Groff [OP] Member
    Silver Spring, Maryland
    Hi folks, newbie here
    I have more of a question than a product review but........
    Jist picked up a 2012 Double Cab 4.0 with the Off-Road Package
    I bought the Westin Ultimate Bull Bar - largely because of the "No drilling" installation. Two simple brackets bolt onto existing bumper hardware. The bar itself bolts to these brackets. I don't have a picture, but a flat plate on each side of the bar bolts to the flat plates bolted to the bumper frame.
    But the holes the bolts go through are significantly larger than the diameter of the bolts. I'm sure this is to allow for positioning and adjustment - but - I can't seem to get the bolts tight enough to keep the plates from slipping a bit and the bar from drooping. There's only two bolts on each side and I broke two of them last night during installation. The only thing I can think of is getting the bar into the desired position (already replaced the broken bolts) and then drilling a third hole on each side and threading another, properly sized smaller bolt through that hole
    Thanks
    Don
  2. Aug 10, 2012 at 11:42 AM
    Bender581
    Bender581 Well-Known Member
    AL
    Arkansas
    2012 4X4 Tacoma
    Gobi roof rack. Icon coilovers, Icon tubular UCAs, FOX 2.0 rear shocks, Icon 3-leaf progressive AAL.
    Did you put on the big washers? And did you add the third bolt, nut and washers?
  3. Aug 11, 2012 at 3:51 AM
    Don Groff
    I did. Turns out 2 of the 4 bolts were crossthreaded. Found this out when they snapped while removing them for replacement. New hardware - no problem. Tight!
  4. Aug 11, 2012 at 6:03 AM
    B737
    B737 Throbbing Member
    Kevin
    Jersey Shore
    2015 Tundra Double Cab Limited
    stock
    PICTURES!
  5. Aug 11, 2012 at 6:43 AM
    stewartx
    stewartx Well-Known Member
    Huntsville AL
    2012 Silver DC SB TRD Off-Road
    Winch, front hitch, step bars, bed extender, bed step, gull-wing toolbox, tailgate lock, security system, cb radio, etc.
    Okay, your problem seems to be resolved, so this is more for others than you.
    Anyway, since the bracket itself mounts on the front of the frame (three bolts each side, no adjustment), I'm assuming you're talking about the holes (two bolts each side) attaching the bullbar itself to that bracket. The holes on the bracket for the bullbar are elongated horizontally to allow some adjustment, while the holes on the bullbar are elongated vertically for the same purpose. The latter bolts should be torqued to a maximum of 30-ft/lbs.
    If the latter attachment points continue to slip after tightening (it happens), there are two methods of resolving it. The first is to place lock washers between the bullbar and bracket. I'd recommend the type used for electronics (large teeth around the entire circumference). The second option is using caulking-style adhesive in that same area (wiping off any excess). Of course, you could also combine both methods.
  6. Aug 11, 2012 at 1:00 PM
    Don Groff
    I thought about the gripping washers and even bought some when I picked up the replacement bolts. Also considered silicone or some thin, dense rubber, but I was thinking anything that put more space between the plates would also allow water to collect and lead to rust. As it is I may silicon around the joints. I had a different push par on my Dodge for 10 years and when it rusted out it was anywhere water could get in and not get out - like the horizontal crossbars
  7. Aug 11, 2012 at 1:09 PM
    grizquad
    grizquad Well-Known Member
    Massachusetts
    12 Tacoma TRD sport
    Plasmaglow Firestorm lights, Westin Bull bar, Flyzeye interior console lights
    I bought the same bar from AutoAnything, and it installed and didn't move just fine. The only thing I didn't like was after a rain storm, the brushed stainless plate in front rusted with spots I could not get off. They gave me a full refund and I bought an Aries Bull Bar and it was $100. cheaper and mounted exactly the same, I like it and it looks good. I did buy the Westin nerf bars and like them. Good luck.
  8. Aug 11, 2012 at 4:02 PM
    ssmith29440
    ssmith29440 Well-Known Member
    2012 Tacoma TxPro Trd
    Don check your pm's
  9. Aug 12, 2012 at 3:58 AM
    Don Groff
    Haven't got any PMs. What's up?
  10. Aug 12, 2012 at 5:49 AM
    B737
    Kevin
    Jersey Shore
    stock
    coooomeooonn....
  11. Aug 13, 2012 at 8:35 PM
    Don Groff
    sorry about the lack of pics - the angle of the sun washed out the bar. then i had to go out of town on short notice.
  12. Sep 1, 2012 at 9:55 PM
    Ghumps
    Ghumps Well-Known Member
    post a pic! Im thinking about getting one of these
  13. Sep 13, 2012 at 12:52 PM
    Don Groff
    So, finally,here are a few photos. These include the installed Westin bull bar WITH plate relocator (don't like the look with the relocator, but few options in Maryland. Also a Pop n'lock tailgate latch supposed to match the Barcelona Red factory color. I wouldnt really recommend this item, fit and finish are poor. But I already had the OEM non-lockable latch removed before I noticed. Also the "Superbumper" installed - a small bumper with a built in shock-absorbing feature
    http://www.superbumper.com/
  14. Sep 14, 2012 at 7:54 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    I'm embarrassed to say I had one of these...
    and regret ever wasting muh money on it.
    Mounted some lights on it...
    and they vibrated more then a dildo :mad:
    IMO/E... these are useless bling garbage.
  15. Sep 15, 2012 at 8:20 AM
    Don Groff
    I had something similar on my Dodge Ram that took a lot of abuse and saved bumper and grille damage more than once. If you experienced a lot of vibration, you probably had other issues. I don't even want to know about your experience with the dildo (TMI)
    JGO likes this.
  16. Sep 15, 2012 at 9:35 AM
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    you'd be wrong...
    the problem is with how it's bolted to the truck
    and the bumper's leverage/weight exaggerates the issue.
    I'm not offering my opinion just to be unfriendly
    I just think it's a poorly designed product...
    and feel I have a right to say so.
  17. Sep 15, 2012 at 9:48 AM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Upgraded 2002 Tacoma to 2018 Tundra
    I also don't have any vibration issues. I made sure mine is installed tight and it's been fine for a long time now.
    I do agree that these are by no means bull dozer blades, but they do offer same light protection from people who don't know how to park, etc.
  18. Sep 15, 2012 at 4:30 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    I do like the superbumper though :thumbsup:
  19. Sep 18, 2012 at 9:47 PM
    Space Junk
    Space Junk Flight Ready
    Silicon Valley
    2013 Tacoma access Cab TRD Off Road
    I would like to put one of these on my 2013, the front end is just too plane and needs a little pop. It seems to me that the bull bars don't get a lot of respect on this forum and I wonder why. I mean, I see that they only attach at the bottom and you could experience some lever action while in a wreck. Is this why a lot of people dislike them?
  20. Sep 7, 2021 at 2:56 PM
    straightawaykid
    straightawaykid Member
    Dave
    Toluca Lake, CA
    2002 Black Taco Xtra Cab SR-5 V6 4WD TRD with Leer shell
    On my 1988 V6 4WD and 2002 TRD Tacoma I've had 3 sets of Westin bars, the first two prevented the trucks from being totalled, according to my body shop guy. Besides, they look nice and do not interfere with California front plate. (Yes, the other cars were totalled when hit).
