Wet 3rd Gen Interior
Discussion in '3rd Gen. Tacomas (2016-2023)' started by YungVineyard, Jan 15, 2023.
  1. Jan 15, 2023 at 3:44 PM
    YungVineyard
    YungVineyard [OP] Well-Known Member
    NY
    2021 TRD Offroad Northeast USA Woods Build
    ARB OME Suspension SPC Upper Control Arms ECGS 5.29 Gears 255/80/17 Cooper Discoverer ST/Maxxx Tires BWAM Front Bumper Greenlane Aluminum Sliders Victory 4x4 Steel Skid Plate ARE Model CX Cap Badlands 12K Winch Firestone Ride Rite airbag helpers with bluetooth controller and compressor Airbag Cradles Rear Diff Breather
    I went offroading in my 2021 TRD Offroad and ended up getting stuck in about 40" of standing fresh water. Winched out just fine and thanks to my lift, 33' tires, and diff breather nothing happened mechanically to the truck.
    Water entered my interior which I drained by opening the doors. I then used a carpet extractor and a wet vac to remove as much water from the carpets as I could.
    It's been about 24 hours and the carpet is dry to the touch but I'm worried about mildew and trapped water. Do Tacomas have drain plugs? I have two Damprid bags in the truck right now and plan on swapping them out tomorrow with two fresh bags.
    I'm also confused why the door seals failed so easily (The water only went about 6" past the bottom of the door, I only sat in the water for about 5 minutes, and my truck is only 14 months old so I figured the seals would do a better job. )
    In addition to removing the water does anyone have advice on better sealing the doors for future water crossings?
    Any and all advice is appreciated!
    GilbertOz and Old goat1914 like this.
  2. Jan 15, 2023 at 3:49 PM
    GeauxTacoma
    GeauxTacoma Well-Known Member
    Maryland
    2022 TRD Sport DCSB Lunar Rock
    My suggestion: get a boat if you don’t want water intrusion.
    t2c, petethemeat, Tacoma Rant and 9 others like this.
  3. Jan 15, 2023 at 3:51 PM
    YungVineyard
    NY
    The waters too deep for my truck and too shallow for my boat. I can't win! lol
  4. Jan 15, 2023 at 3:52 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Yes there are plugs on the bottom.
  5. Jan 15, 2023 at 3:54 PM
    TacoPandaTRD
    TacoPandaTRD Well-Known Member
    TacoPandaTRD
    Chilliwack, British Columbia, Canada
    2020 Toyota Tacoma TRD Off-Road
    Always looking to modify! Check out my Instagram @TacoPandaTRD
    I’ve been told the door seals are only good for 3”. If I were you I would remove the interior completely. Take out the seats then remove the carpet. Sure it’s dry to the touch now but the padding underneath will still be soaked. The truck does have drain plugs but that requires popping off the inner door trim and lifting up the carpet
  6. Jan 15, 2023 at 3:55 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Pull the carpet out, there is sound deadening and some electrical connectors under it.
    YungVineyard[OP] likes this.
  7. Jan 15, 2023 at 3:56 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    And this is why I’d never buy a used Tacoma
    Lunar Squirrel, AM6217, t2c and 15 others like this.
  8. Jan 15, 2023 at 3:57 PM
    Bcjammerx
    Bcjammerx I'm not ALWAYS an a-hole, I swear
    North East Texas
    ‘17 TRD Off-road 4X4
    Better check the diffs and transmission and transfer case, I know the latter two have vents that aren't sealed, if it was above the doors it was above those. I'm not sure about the rear diff but I want to say it has a vent too. they have little caps that keep dirt out but if air can get in, so can water
    door seals aren't designed to keep standing water out either just fyi
    TacoPandaTRD likes this.
  9. Jan 15, 2023 at 3:57 PM
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    Personally, I'd take the entire carpet out. Also the door sills (wiring in there) to make sure all water and dampness has been removed. I really don't think the trucks interiors were meant to get that wet. The door seals were not designed for that type of submersion. You live and learn I suppose.
  10. Jan 15, 2023 at 3:58 PM
    YungVineyard
    NY
    Countless cars suffer water damage every year. At least I went in with the right equipment to avoid REALLY breaking anything haha
  11. Jan 15, 2023 at 3:58 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Ugh, water crossings! I’d recommend checking your rear differential oil for water (specially if you didn’t relocate the breather) and the front diff actuator for water intrusion- the parts inside it don’t do well with water and some of them leak.
  12. Jan 15, 2023 at 3:59 PM
    skeletron
    skeletron Disgraced Member
    Clark
    Sakerlina
    2020 TRD Broh
    He's asking about different door seals so he can do this again. Nothing has been learned
  13. Jan 15, 2023 at 3:59 PM
    YungVineyard
    NY
    The factory front diff, transfer case and transmission breathers are located high up in the engine bay. I extended the rear diff breather to behind my tail light with an ARB kit. I checked the diff fluid through the fill plugs and everything looks mint.
    bulalo, Jeffch and OnHartung'sRoad like this.
  14. Jan 15, 2023 at 4:01 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    StayinStock, TS4x4 and Delta09 like this.
  15. Jan 15, 2023 at 4:01 PM
    YungVineyard
    NY
    You're right - I should stick to the mall and let NY winters destroy the offroad parts I installed rather than enjoying my truck as I intended
    Toycoma2021 likes this.
  16. Jan 15, 2023 at 4:02 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    For sure drain and refill the transfer case and rear axle, as the axle cools, it will draw in water if below the surface. Place a piece of plywood on the rear seat or drop it and place a dehumidifier inside, fire it up and let is run constantly for multiple days. You want to dry out the interior air so much that any moisture trapped goes into the air. Tape off the vent behind the seat so their is no in/out air mixing. Personally, I'd run it for a week straight.
  17. Jan 15, 2023 at 4:03 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    This, you need to remove the carpet itself and let it dry completely maybe for a few days in a dry area
    Taco23Trl and YungVineyard[OP] like this.
  18. Jan 15, 2023 at 4:03 PM
    Bcjammerx
    North East Texas
    granted I was looking at them from under the truck but they sure seemed about that height, maybe an inch or two higher, I hope you checked them all regardless, especially the transmission
  19. Jan 15, 2023 at 4:04 PM
    YungVineyard
    NY
    I have a breather kit on the rear. I have a custom breather fitting/extension on my actuator as well. I'll probably open it to check my design once I find the motivation to pull the front axels again.
    Bcjammerx likes this.
  20. Jan 15, 2023 at 4:04 PM
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
