Wet Carpet in a Double Cab?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Codemonkey3, Oct 27, 2014.
  1. Oct 27, 2014 at 12:07 PM
    Codemonkey3
    Codemonkey3 [OP] Well-Known Member
    New York
    2001 Toyota Tacoma
    I have a 2001 double cab and last night while I was taking out the floor mats and putting new ones in I found the carpet in the backseat passenger side floor was wet.
    It was more like damp than wet honestly. I let it dry out over night but it's still somewhat damp still and you can clearly see in this picture this brown mark. That's where it's most damp. Any suggestions to fix it or find the issue? It rained like two days ago. I haven't used the AC at all.
  2. Oct 27, 2014 at 12:14 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    The seal around the door of mine leaks, doesn't let that much water in but could be your issue.
  3. Oct 27, 2014 at 1:41 PM
    Codemonkey3
    New York
    2001 Toyota Tacoma
    Maybe. I checked under the truck and didn't see any obvious holes or rusting. The weird part is that it's dry alongside the door and only wet in that corner by the cup holder and hump.
  4. Oct 27, 2014 at 2:14 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    Weird. Put some newspaper down and keep an eye on it, might be able to tell where it's coming from. I remember hearing about people having similar problems and I'm pretty sure it was the weather-stripping.
  5. Oct 27, 2014 at 4:18 PM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    Check the center storage area at the very bottom.
    There are two bolts that have a threaded nut on the end of the transmission tunnel that are exposed to the elements.
    Also check the door sills, meaning the plate.
  6. Oct 27, 2014 at 6:08 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    back window or side glass gasket leak is my bet. if its wet in the back seat but dry by the door, unless you park on a steep hill, then it has to be something from the roof or the rear glass so if the headliner is dry they check for rust holes around the back window gaskets.
    and shop vac that carpet until its dry or you will have mold and mushrooms growing back there in no time
