Wet carpets
Discussion in '1st Gen. Tacomas (1995-2004)' started by Akeela1995, Oct 22, 2023.
  1. Oct 22, 2023 at 12:34 PM
    Akeela1995
    Akeela1995 [OP] Active Member
    1995 Tacoma
    Hi everyone! I just hopped in my truck today to discover a very unpleasant smell! A smell I hadn’t smelt in my truck before…
    Checking under my floor mats I have discovered my carpets being wet. Only under the front floor mats. both driver and passenger side.
    The last few days we’ve had lots of rain but today is nice and sunny so the trucks completely dry right now besides the inside carpets!
    Ive driven the last few days and haven’t noticed any water dripping anywhere so I’m quite confused. Has anyone else had this problem and solved where the waters coming from?
    Thought I’d just post here first
    pic of the truck
  2. Oct 22, 2023 at 1:13 PM
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    Have you removed your door panels before?
  3. Oct 22, 2023 at 1:20 PM
    Akeela1995
    1995 Tacoma
    I have not!
    It’s possible previous owner had, but that would’ve been over three years ago now.
    Should I?
  4. Oct 22, 2023 at 1:23 PM
    RedManRocket
    Red
    2002 Double Cab LT
    Well there's a vapor barrier behind it, the clear plastic covering. And if it has come unstuck it can leak from there. Water is supposed to be able to drain through your door. But if the vapor barrier is damaged it can splash in your door and out onto your door panel, and then drain onto your carpet.
  5. Oct 22, 2023 at 1:24 PM
    Akeela1995
    1995 Tacoma
    I had no idea. I will have to check that. Thank you. I just thought it was weird that it was both sides. Haven’t had this issue before, or at least not that I noticed.
    RedManRocket[QUOTED] likes this.
  6. Oct 22, 2023 at 1:25 PM
    Clearwater Bill
    Billy
    Largo Florida
    Heater core leak is possible. Losing any coolant?
    Holes on the firewall leaking. Run any new wires?
    AC drain clogged.
    Front cab drains clogged and overflowing into the body some how.
  7. Oct 22, 2023 at 1:28 PM
    RedManRocket
    Red
    2002 Double Cab LT
    If you haven't had it before than maybe not, always good to check though. These are good ideas also ^^
  8. Oct 22, 2023 at 1:39 PM
    Akeela1995
    1995 Tacoma
    perfect. Thanks so much. I’ll check these
  9. Oct 22, 2023 at 4:13 PM
    tacoman2001$
    tacoman2001$ Well-Known Member
    Having had many water leak cars. The most common thing is windshields leaking especially if its been replaced. Sunroofs also leak. You might pop some trim pieces out like the kick panels and glovebox and use a garden hose to spray the truck down. Do you have a sunroof?
    1blink likes this.
  10. Oct 22, 2023 at 4:35 PM
    Akeela1995
    1995 Tacoma
    I do have a sunroof yes! You think that could be leaking and causing my floors to be wet?
  11. Oct 22, 2023 at 4:40 PM
    tacoman2001$
    The best thing is to take a couple of panels off and get an assistant to take a garden hose to your truck while your inside and look for any water. Could be a bad door seal as well.
  12. Oct 23, 2023 at 12:09 PM
    rocknbil
    rocknbil Well-Known Member
    Bill
    2003 Taco Ext Cab DLX TRD 4WD MT 3.4L
    Not sure on the Taco, but have had a few vehicles where the drains under/in front of the bottom of the windshield get clogged up. In moderate rain this causes them to overflow and it goes right down the back of the firewall and into the carpet. Worth looking at.
  13. Oct 27, 2023 at 6:35 PM
    HoneyBadger153
    HoneyBadger153 Well-Known Member
    Lowcountry, SC
    2002 Lunar Mist Tacoma SR5 4WD
    ARB, Hella FF75, SoftTopper, Power Limited Seats, OME Suspension, Heated Mirrors
    https://www.tacomaworld.com/threads/passenger-side-floor-wet.778956/page-2#post-27881706
    You may want to run a garden hose on the windshield cowl (black plastic panel between the glass and hood). Pull the carpet back and see if water trickles down. That's where mine was coming from. I got some flex seal on a paint brush and crammed my arm inside the hole (cowl and wipers removed). Then I painted it along the 90 degree angle where the metal meets. You could also do what this guy did and take off the fender in case your arm can't contort like a creature.
  14. Oct 28, 2023 at 5:30 AM
    Kevin Jones
    Kevin Jones Well-Known Member
    Kevin
    Va
    1996 Tacoma - 2018 Tacoma
    Agree with other poster, a heater core leak will cause wet floor. Is windshield fogging up, as can be another sign of leaking heater core?
  15. Oct 28, 2023 at 8:21 AM
    noodles93
    noodles93 Well-Known Member
    Charleston, SC
    1999 Tacoma Prerunner 2.7
    Check your seams like some others have mentioned. I was able to repair mine from the interior with flex seal. Leaked up against the firewall and cab.
  16. Oct 30, 2023 at 8:47 AM
    travis500
    travis500 Well-Known Member
    Travis
    Denver
    2001 M/T 3.4 Xtracab 230k
    I had this happen a few months ago. Tried everything mentioned in other threads, I had weathertech mats but the water was getting under them some how. Turns out at the top of the windshield (where the windshield is sealed to the body), the body was rusting causing a gap. Water was getting in through here during rain, running down the headliner to the passenger pillar, down the right hand side of the dash and onto the carpet. 20 year old carpet stewing in water does not smell great. This was an absolute pita to find. Ended up replacing carpets and doing sound deadening while I was in there. Had to get windshield off, de rust, paint and re seal.
