Wet damping or speakers
Discussion in 'Audio & Video' started by TheMaker, Jan 9, 2020.
  1. Jan 9, 2020 at 7:20 AM
    TheMaker
    TheMaker [OP] Member
    86' Toyota 4x4, 2019 TRD OR
    I have no option but to park my 2019 TRD OR at a slant = I get a little water in the doors when it rains. Some folks on here say that’s normal. OK. I’m planning to replace the front door speakers and add damping. I’ve seen a few scattered comments about this but nothing definitive. Experience? Advice?
  2. Jan 9, 2020 at 7:24 AM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    I don't own a third gen but I have never had water on the insides of my cab, even in fording deeper water. Something doesn't seem right here.
  3. Jan 9, 2020 at 7:48 AM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    water will always get inside of door panels. they're designed for it. that's what the plastic moisture barrier is for.
    as for sound dampening material, just make sure you use good quality product, and i would clean the metal surface very good before install. use some rubbing alcohol on a rag or similar. just want to make sure the material has a good surface to stick to
  4. Jan 9, 2020 at 9:08 AM
    TheMaker
    Water in the door, NOT the cab. Yes, I thought water in the door was normal.
    About the damping...good and dry so it will stick, but does it hold water after the fact? Also, what about moisture damaging the speaker?
  5. Jan 9, 2020 at 9:26 AM
    destin_meeks
    Destin
    Tuscaloosa, AL
    the material will not hold water. it is a rubber material so no worries there. even the foam layers you can buy are closed-cell foam so they're not absorbent either. for the speakers, they will not get damaged in nearly all scenarios. manufacturers know that they will get damp/wet and they build them accordingly
  6. Jan 9, 2020 at 11:40 AM
    TheMaker
    Thanks for the info
  7. Jan 9, 2020 at 7:17 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Also you should get the foam speaker cups to keep the water from dripping onto the speaker magnets. I ruined one speaker because of water dripping down. Make sure you cut out the bottom half of the foam cup though, or else they will just sound like garbage... hot hot garbage.
    EDIT: I should say that the water that got into my speaker froze and ruined the coil... not a huge issue if you dont have sub zero temps.
