Wet Driver AND Passenger side carpet (NOT AC drain)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Toytac07, Oct 12, 2023.
  1. Oct 12, 2023 at 9:50 AM
    Toytac07
    Toytac07 [OP] New Member
    Central Fla
    07PrerunnerSR5
    fading, scratches, rust
    Hello all. 2007 Tacoma owner here.
    For about a year I've been having an issue with wet floorboard carpet, but I notice it only after a heavy rain. It's always parked on level ground.
    I've been leaving the plastic trimpanels and thresholds out of the truck so that I can easily lift up the carpet to let it dry. I'm really tired of this problem, but I cannot find where it's leaking from. If it helps to diagnose, the passenger side gets probably twice as wet as the driver's side.
    Thanks in advance.
  2. Oct 12, 2023 at 10:20 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Turn your blower on high (recirc off), close the windows and doors, and go around the windshield and roof rack seals with soapy water.
    GilbertOz, Toytac07[OP] and Geeves77 like this.
  3. Oct 12, 2023 at 10:21 AM
    BluberryBCtaco
    BluberryBCtaco Making the magic happen
    BC Canada
    2007 Tacoma Sport DCLB
    3in lift, Tow package, Any time 400w inverter, in cab outlet, vinyl floor, roof rack
    I’ve been having something similar for months.
    Found out it was a crack in the body weld, where the bottom of the A pillar intersects with the floor and the fire wall.
    From the outside perspective it was the wheel well.
    Had to peel out the floor liner and the fire wall insulation from the inside.
    Check Gromets.
    Check if you see daylight from inside the cab.
    When it rains put your hand in very awkward places and feel your way down. Till you feel the wet spot.
    (Yeah reading back that sounded better in my head)
    I’ll post some photos of it tonight of my problem.
  4. Oct 12, 2023 at 12:38 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    GilbertOz and Toytac07[OP] like this.
