Wet drums from launching boats
Discussion in 'Towing' started by HawkShot99, Jul 12, 2018.
  1. Jul 12, 2018 at 7:55 PM
    HawkShot99
    HawkShot99 [OP] Well-Known Member
    Kingston, NY
    13' Silver DCLB TRD Sport - Sold
    I have a friend who owns a 11' Tacoma, and recently bought a boat. The ramp he used was quite shallow so he back the truck in quite far, getting the rear drums under water I guess. When he tried to drive out, the rear drums had locked up from water in them and were only able to be released after beating them with a hammer.
    I have never heard of this on here. I try to not put my truck in the water when launching, but some ramps are quite shallow so it does happen at times. Is this a normal issue, or did he have a once in a million experience?
  2. Jul 12, 2018 at 8:04 PM
    Bishop84
    Bishop84 Well-Known Member
    Lots of possibilities but I would want to inspect them. We usually only see tacoma parking brakes stick after parking overnight.
    But you're backing a hot diff and brakes into water and rapidly cooling them off, so leway needs to be given.
    That said I would inspect where the ebrake cable enters the rear brake backing plate, they tend to brake at the cable and cause issues with adjustments being too tight.
    This pic has where the cable enters, also if its wet/soaked with oil like this, it's another possible cause for locking up.
  3. Jul 12, 2018 at 8:20 PM
    Arcturus
    Arcturus New Member
    British Columbia
    Spruce Mica SR5 4X4
    I'm on my second Tacoma now and have never had an issue with my brakes locking up after launching or retrieving boats. I quite often back down a ramp or beach until my exhaust pipe is gurgling and the water is a bit under the door sill so I'm quite sure my brakes are getting wet. So I think your situation is unique. Probably time to service those brakes.
  4. Jul 13, 2018 at 12:36 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    If you or your friend are backing in that deep I think I’d be concerned about getting water into the rear differential through the breather tube.
    Dirtridercrf250 likes this.
  5. Jul 13, 2018 at 1:04 PM
    HawkShot99
    Kingston, NY
    Its my budds truck, like i said I don't even get my wheels wet launching, but haven't used the ramp he had issues with. Ill mention the diff breather to him.
    Its fresh water so no issue there.
    Thanks for responses. Id never heard of this, and just wanted to make sure if it was a big issue or a fluke.
    scottalot[QUOTED] likes this.
  6. Jul 13, 2018 at 1:06 PM
    Dirtridercrf250
    Dirtridercrf250 Well-Known Member
    Just don't back in with steaming hot brakes lol
  7. Jul 13, 2018 at 1:14 PM
    Clearwater Bill
    Billy
    Largo Florida
    Several threads around on the topic. Almost always after sitting a period of time with ebrake engaged after being soaked.
    Are you saying his froze in the few moments it took to launch, while still in the water?
    That would be something new.
  8. Jul 13, 2018 at 3:08 PM
    HawkShot99
    Kingston, NY
    Yes they froze while in the water. He said he had to put it in 4-wheel drive and just mash the throttle to get it up the ramp out of the water.
    I'm just asking questions on this because I would like to cover myself in case it's an issue. He's super pissed off and looking at selling his Tacoma now because of this.
  9. Jul 13, 2018 at 3:11 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    never even realized this was a thing that happened to people. my truck doesen't have e brakes, so when im launching my boat (has to be backed in quite far so the drums get dunked) i just have somone stand on the braked and available incase it needs to be pulled up. But ive never had drum brakes stick on me.
  10. Jul 13, 2018 at 3:34 PM
    Clearwater Bill
    Billy
    Largo Florida
    However, many illogical things stimulate economic markets.
    Send him our thanks. And point out that the new Ranger will be available soon.
  11. Jul 13, 2018 at 3:36 PM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    I’ve had my parking brake stick on me after driving through water off-road, then the truck sitting overnight. It unstuck on its own after pumping the brakes a bit.
  12. Jul 13, 2018 at 6:36 PM
    Indy
    Indy Master of all I survey.
    Heh, I've backed deep enough for the boat to float every time I've launched. The exhaust is always burbling. Brakes getting wet are not an issue.
  13. Jul 15, 2018 at 8:08 AM
    lock
    lock Well-Known Member
    greg
    N.W.OHIO
    tacoma
    This issue screams neglected maintenance.
    A brake job is cheaper than a new truck. Got to wonder what else has been neglected.
