Wet Floor in Passenger Foot Area
Discussion in '4 Cylinder' started by MOReese, Feb 7, 2015.
  1. Feb 7, 2015 at 4:31 AM
    MOReese
    MOReese [OP] Active Member
    Jerry
    Osage Beach, MO
    03 Reg Cab 2WD
    I have posted this on another topic thread but haven't solved problem yet. Anyone run into this and figured out problem? This is on an 03 Reg Cab 2WD w/Auto trans. Has air but haven't turned it on although have been running heater.
  2. Feb 7, 2015 at 4:56 AM
    Bpassmore8
    Bpassmore8 Brian13DCSB
    Brian
    Vacaville, CA
    2013 Super White TRD Sport
    Debadged, N-Fab step bars, LED cup holder lights, LED dome and map lights, TRD stickers, HID retrofit (Morimoto Mini H1 6.0, BHLM, HomerTaco ghost raptor grill, OME 885s with 90021 up front, 60091 in the rear with trim spacer
    Check the drain tubes for the a/c evaporator
  3. Feb 7, 2015 at 5:07 AM
    MOReese
    Jerry
    Osage Beach, MO
    03 Reg Cab 2WD
    Whow....Thanks Scott this will give me several causes to check out
  4. Feb 7, 2015 at 6:22 PM
    Nomad_Pilot
    Nomad_Pilot I need to pewp
    Clay
    Ft Collins
    Leaves in the drain for the high pressure area just below the base of the windshield...my old Nissan did this every year
  5. Feb 11, 2015 at 5:43 AM
    MOReese
    Jerry
    Osage Beach, MO
    03 Reg Cab 2WD
    OK it is probably a stopped up drain line, but can someone tell me where the drain is. In other threads some have said it is on the firewall , others have said it is in the passenger wheel well.....I don't see it in either place...HELP.
  6. Feb 11, 2015 at 9:53 AM
    Nomad_Pilot
    Clay
    Ft Collins
    The drain holes for the high pressure area are in each back corner of the lower part, I just shot a water hose in there and it in clogged em, now holes in the ac drain I'm not sure, but my hood is open outside give me a sec
    OK here is the ac drain, it sticks out front fire wall, that's my finger on it, the second is the hole that the water from windshield run off drains out of, one on each side
  7. Feb 11, 2015 at 10:48 AM
    Nomad_Pilot
    Clay
    Ft Collins
    I just realized your in MO in winter, why are you running ac? Or does it come on with defrost to dry air?
  8. Feb 11, 2015 at 3:40 PM
    MOReese
    Jerry
    Osage Beach, MO
    03 Reg Cab 2WD
    Not running any A/C, not even running the defrost but I am running the heater directed towards the feet area. Someone said the A/C runs when you run the defrost but I haven't even turned it on to see what happens......still get wet passenger floorboard.
    Clay thanks for the pics, I'll check those area tomorrow but I don't see how I could have missed the tube you are pointing too. I wonder if my 03 is like your 14?
  9. Feb 11, 2015 at 10:15 PM
    Nomad_Pilot
    Clay
    Ft Collins
    If your not using defrost or ac, and you said you been getting lots of rain....I would put a water hose on the windshield and sit in truck and see if you could see it drip somewhere...then you would know for sure!
  10. Feb 12, 2015 at 4:19 AM
    MOReese
    Jerry
    Osage Beach, MO
    03 Reg Cab 2WD
    Clay....haven't had any rain for several weeks, but I may try this just to rule it out...Thanks.
  11. Feb 15, 2015 at 5:03 AM
    MOReese
    Jerry
    Osage Beach, MO
    03 Reg Cab 2WD
    OK its not the drain tube....stuck wire in there and blew it out, nothing, no water draining. It hasn't rained here or snowed, so not a windshield seal leak or cowl drain plugged up with leaves. Anybody got any other ideas??
  12. Feb 15, 2015 at 5:06 AM
    Clearwater Bill
    Billy
    Largo Florida
    Leaking heater core?
    Coolant level stable or adding some along the way?
  13. Feb 15, 2015 at 8:33 AM
    Nomad_Pilot
    Clay
    Ft Collins
    This^.
    I forgot all about that sob. I hope 8ts not though, they are a bitch to change
