Wet floorboards
Discussion in '1st Gen. Tacomas (1995-2004)' started by Redneck92, Apr 6, 2014.
  1. Apr 6, 2014 at 7:57 PM
    Redneck92
    Redneck92 [OP] Well-Known Member
    Concord, NC
    02 Tacoma Limited TRD
    Just the norm skids, sliders, & 35's
    I've noticed for some reason both of my floorboards seem to always stay wet. It's just the area under the mat and no where else up front. Seems to be just water. Just wondering if anybody else had this issues before I go taking the carpet out, I'm guessing it's a seal leaking rain water in and it never evaporates.
  2. Apr 6, 2014 at 8:38 PM
    paquu
    paquu Well-Known Member
    RI
    02 doublecab fj trm rims, roof led bar
    42" LED bar
    Mine used to do that when I used the AC. My condensation tube was clogged. Water backed up and got on both floor boards. Not sure what else it could be.
  3. Apr 7, 2014 at 12:33 PM
    Redneck92
    Concord, NC
    I'll check that and see. It been like this for a while just finally figured I should look into it. Don't want the floor rusting out.
  4. Apr 7, 2014 at 1:38 PM
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    Chances are, that is what the problem is. Mine has done it a couple of times.
    The tube is on the passenger side. Its silver and makes a 90 to the ground. It pulls out of the grommet fairly easy. You might have to stick a screwdriver or something in the hole to unclog it.
  5. Apr 7, 2014 at 1:40 PM
    COMAtized99
    COMAtized99 Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    There is a TSB around here some place detailing water leaks on 1st gen Tacoma's. Basically the seams under the wipers leak and the seams under the fenders.
  6. Apr 7, 2014 at 7:08 PM
    Mulepadre
    Mulepadre Mulepadre
    Central Arkansas
    2003 Std Cab 2.7L 4x4 & 2024 Off Road
    Bilstein 5100s, Deaver Leaf Springs, JBA UCAs on 2003 King 2.5 shocks front and rear on Off Road
    Windshield leaking?
  7. Apr 7, 2014 at 7:13 PM
    Redneck92
    Concord, NC
    Don't think so, it's isolated under the mats. The upper parts near the firewall, at least on the driver side is dry. I'll try to dig into it on my day off this week. Didn't know if it was common or not.
  8. Apr 7, 2014 at 7:23 PM
    muddedtaco
    muddedtaco Well-Known Member
    Wesley
    South Mississippi
    96 Tacoma 4x4 2.7
    Rattle caned black, Mossy oak door panels, shifter shroud, and radio cluster surround
    Mine gets wet mysteriously about one or twice a year. Last week I opened my door and there was about an inch of water in the driver's side floorboard, lucky my amps did not get wet. I am thinking about taking carpet out and bed lining the inside of the cab.
  9. Apr 7, 2014 at 9:09 PM
    Pakrat
    Pakrat Well-Known Member
    Brian
    Washington,State Columbia gorge
    02 tacoma xtracab 4x4 stock
    Front dome light added,light reminder added,door chime mod, added 2nd gen 4runner headrests,grey wire mod, 2lo mod, more later.
    Hey guys I had this problem with my 02 taco I did a write up with pics where the water was coming in. It was the pinch welds under the door seal at the top by the gutter. The next time it rains pull off the pillar trim and you can see water running down the post, along side of the dash behind kick panel and it soaks the insulation under the carpet.I sealed mine and no more wet carpet. I'll see if I can find my write up. I thought it was the windshield also,I had it replaced anyway and when it was out I seen where the water was coming in. Hope this helps wet carpet sucks!!!
  10. Apr 7, 2014 at 9:16 PM
    Pakrat
    Brian
    Ok found it go to technical chat about half way down it says wet carpet floorboard problem, there is a write up and pics,you'll see what I mean. Like I said its pinch welds and cab seams
  11. Apr 7, 2014 at 9:19 PM
    Pakrat
    Brian
    Ok found it it's in technical chat halfway down wet carpet floorboard problem I did a write up and pics
