Wet floors
Discussion in '1st Gen. Tacomas (1995-2004)' started by Isaac850, Mar 28, 2016.
  1. Mar 28, 2016 at 6:09 AM
    Isaac850
    Isaac850 [OP] Active Member
    Isaac
    1999 Tacoma Prerunner Extended Cab 2.7 liter
    Hi everyone. I'm new to the forum. I just bought a 1999 Tacoma Prerunner last Sunday. It's been a great truck so far and I love it. It has been rainy here the past couple of days and I picked up the aftermarket floor mats and noticed moisture on the bottom of them. Felt the carpet and it is soaked. This only happens on the front floorboards on the flat spots on both driver and passenger sides. Any ideas on how to fix this or what my problem could be? Thanks for the help.
  2. Mar 28, 2016 at 7:06 AM
    Lifted 03 Tacoma
    Lifted 03 Tacoma Well-Known Member
    Nathan
    2003 Tacoma TRD off-road
    3in lift, wheels and tires, k&n intake, Gibson exhaust, headache rack, side steps, 42in curved light bar, CBI Moab 1.0 bumper, Rigid Dully spot cubes, 285/75r16 Toyo MT's
    I had that problem with my 03 as well. I believe it is fixed now but I would have to pull up the carpet to double-check. What I found to be the problem was the plastic/rubber plugs under the carpet on the driver and passenger side. Water would leak in when sprayed with a hose. To fix this all I did was seal the plugs with silicon.
  3. Mar 28, 2016 at 9:48 AM
    Isaac850
    Isaac
    Do you have a picture of what plugs you are talking about? Do you think I could just spray over these plugs with some flex seal?
  4. Mar 28, 2016 at 10:01 AM
    Lifted 03 Tacoma
    Nathan
    I don't have a picture but if the floor boards are the same as the 03 it will be really clear when you pull up the carpet, it's hard to miss.
  5. Mar 28, 2016 at 10:03 AM
    Isaac850
    Isaac
    Okay I'm at work right now so I can't check. I think I know which ones you're talking about. On the passenger side is it on the front right hand side covering a bolt head?
  6. Mar 28, 2016 at 10:23 AM
    Lifted 03 Tacoma
    Nathan
    The one that was leaking for me went to nowhere. When I pulled the plug i was looking at the ground under the truck.
  7. Mar 28, 2016 at 10:44 AM
    Indy
    Indy Master of all I survey.
    That's kind of the point of a drain plug :)
    We used to leave them out of our off-road rigs. It made getting the mud out of the interior simpler, just hose off everything and let it drain out.
    I wouldn't recommend doing that in your DD.
  8. Mar 28, 2016 at 10:54 AM
    Isaac850
    Isaac
    Okay thanks. I'll look after work. Did you have to take the carpet out to get to it?
  9. Mar 28, 2016 at 10:55 AM
    Indy
    Yes. They're holes in the body, so under the carpet in the foot wells. There's usually 1 or 2 in every vehicle. They're just rubber plug filling about a 3/4 - 1" hole. Unless you're doing water crossings all they have to do is keep water from splashing in. Even if they're missing entirely you shouldn't see much water coming in through them just driving around.
  10. Mar 29, 2016 at 5:03 AM
    Isaac850
    Isaac
    Thanks y'all. When I got home from work I pulled the soaking wet carpet up and put some fans on both sides to dry it out. After a while I went back out and sprayed the drain plugs with some flex deal. Supposed to rain tomorrow so we'll see if that fixed my problem or not.
  11. Mar 30, 2016 at 5:51 AM
    2scars
    2scars Swollen Member
    Brandon
    RVA
    2003 TRD 4x4 Doublecab
    All-pro, T-G, Budbuilt, Warn, Tepui, Homefab rear bumper
    Is it both sides or just passenger? If just passenger, your heater core could be gone. Check of the coolant level will verify.
  12. Mar 30, 2016 at 5:58 AM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    Also, check to be sure the evaporator core drain on the A/C isn't plugged.
  13. Mar 30, 2016 at 9:28 AM
    Isaac850
    Isaac
    It was wet on both sides. I think I've got it fixed but I will check these other suggestions out too. Where is this drain you are talking about? And where is do I check the coolant level for the heater core?
  14. Mar 30, 2016 at 9:42 AM
    Skrain
    Monticello, Ky
    2009 F.J. Cruiser
    If the cooling system coolant is holding level, and doesn't need constant topping up, then your heater core isn't leaking. it's all the same system. Also, coolant has a particular "sweet" smell.
    I believe the evaporator core drain is a small tube coming out through the firewall. if you turn your A/C on, and see water dripping onto the ground it's not plugged.
  15. Apr 3, 2016 at 11:01 AM
    Isaac850
    Isaac
    Everything y'all have mentioned has checked out but the floors are still wet
  16. Apr 3, 2016 at 11:15 AM
    Isaac850
    Isaac
    The passenger side is more wet than the driver side but the driver side is damp also
  17. Apr 3, 2016 at 12:00 PM
    Skrain
    Monticello, Ky
    2009 F.J. Cruiser
    You might have a leak around the windshield, or rear window that is letting water seep in and collect on the floor.
  18. Apr 3, 2016 at 12:35 PM
    Isaac850
    Isaac
    Okay is there anyway I can check that? Will it be fixed if I replace the windshield? I'm planning on replacing it soon just waiting a few weeks before I claim it on insurance being that I just bought the truck.
  19. Apr 3, 2016 at 12:45 PM
    Isaac850
    Isaac
    I forgot to mention that the truck was parked for a couple days outside without me driving and it rained and when I got back from out of town the floors were wet. Sounds like the windshield could be the problem.
  20. Apr 3, 2016 at 1:50 PM
    Skrain
    Monticello, Ky
    2009 F.J. Cruiser
    Let the truck completely dry out, then go to the car wash, and use the spray around the windshield, check the floor, then do the back window. Also, check for leakage from the cowl vents in front of the windshield. They have drains, but not sure where they are. Just have to hunt for them. Maybe have someone hose off the outside of the truck while you sit in the front seat, and look for any obvious leaks or water spotting on the carpets.
