Wet Fog Light connectors.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 808charger, Sep 24, 2021.
  1. Sep 24, 2021 at 1:43 PM
    808charger
    808charger [OP] Well-Known Member
    Joe
    Black 2015 Tacoma TRD
    leveling kit
    My fog lights stopped working recently, I took a closer look this morning and inside of the connecter is soaking wet. Did the water break the led, the connecter from the truck or both???
  2. Sep 24, 2021 at 5:22 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Take a test light and hook it a good ground.
    Some where on the frame will work. But make sure the connection is good.
    Then test the green wire for power at the connector.
    If the test light lights up, the connection is probably fine.
    Testing the ground side might be a bit harder.
    You need to hook the test light to battery positive, then probe the Black/White wire at the connector.
    If the light lights up, the connector is probably good.
    Jimmyh and Dm93 like this.
  3. Sep 25, 2021 at 5:06 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    If the voltage checks out and you get it working again you can seal the connector using Dielectric grease to keep the water out.
    TnShooter likes this.
  4. Sep 25, 2021 at 4:05 PM
    TnShooter
    Deogee
    STOCK
    I use it on all my connections.
    I’ve even been known to apply a light coat on the “water proof” rubber seals.
    Just to make me feel better, if nothing else.
    Jimmyh[QUOTED] likes this.
  5. Sep 25, 2021 at 5:36 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I also am in the habit of spraying some WD-40 in pretty much all of my connectors before plugging them back in. Occasionally I use silicone spray but usually WD-40. I think anything is better than reinstalling dry.
