Wet Okole Insallation Help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by chrisrothrock2000, Nov 13, 2008.
  1. Nov 13, 2008 at 6:10 AM
    chrisrothrock2000
    chrisrothrock2000 [OP] Well-Known Member
    Fairfax, VA
    Devil Horn Emblem, Access Bed Cover, Wet Okole Seat Covers, Bed Mat, AFE Dry Drop In Filter, Sock Monkey Decals, Custom Fishing Rod Holder
    Just got a set of Wet Okole's for my front seats and rear. Anyway, the rear ones went on easy but I am having some difficulty with the fronts. I got the bottom portion on alright but the backs are tough. I can't figure out how to attach the velcro on the bottom end to the back (basically wrap under the seat to reach the back of the seat back). I can't see how it fits - there is this plastic piece when I try to tuck it under. Hope this makes sense. Any help would be greatly appreciated. :devil:
  2. Nov 13, 2008 at 6:18 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    get a sheet of plastic, like painters use, cut it so its big enough to drape over the front and back of the seats. Drape it over, put seat cover on (the plastic makes the seat cover slide easier over the surface of the seat) and then pull out the plastic from the back. Repeat process on other side.
  3. Nov 13, 2008 at 6:25 AM
    chrisrothrock2000
    Fairfax, VA
  4. Nov 13, 2008 at 6:41 AM
    Dark Knight
    Jeff
    NC/SC
    Ahh I see. Whats the problem? Too tight?
  5. Nov 13, 2008 at 6:42 AM
    chrisrothrock2000
    Fairfax, VA
    No I can't get it through the seat to attach to the back of the seat.... some plastic piece is in its way.
  6. Nov 13, 2008 at 6:44 AM
    Rtrn2taco
    Rtrn2taco Nostalgia...
    Philadelphia
    08 DC PreRunner (silver)
    the plastic peice hanging from the top of the seat is clipped underneath. Reach below the seat and you will feel two elastic straps clipped anb holding it to the frame, remove them and I guess fold it up under the seat cover.
  7. Nov 14, 2008 at 12:29 AM
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
  8. Nov 14, 2008 at 8:14 AM
    papabear050
    papabear050 Well-Known Member
    11 dc 4x4 TRD OR Auto
    holy crap, I just spit coffee all over my keyboard after seeing the price for the seat covers..........235 for just the fronts......... what makes these things so special???
  9. Nov 14, 2008 at 8:19 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    I believe that plastic sheet is connected using metal hog clips. Open those up and heat up the plastic a little bit to make it a little more flexible. Then fold it so that it sits against the back of the seat.
  10. Nov 14, 2008 at 9:16 AM
    FamouzStarz
    FamouzStarz The illest taco
    21 TRD PRO
    ICON Build and then some
    um there made out of SHAW WOW havent you seen the infomercial they protect against all elements of nature had can soak up to 5gallons of liquid :D
  11. Nov 15, 2008 at 12:13 AM
    FoxySandChick
    Kristin
    Henderson, NV
    I guess you would have to see them to appreciate, they are the best thing I could have bought for my truck and I got an entire set for about $500. They are custom fit to your seats, I mean super snug with every little detail included for seat belts, air bags, sport seats, child car seat hooks etc. They are made from neoprene ie wet suit material, so clean up is a breeze and never any stains on the original seats. They are great for my dog in the back seat.
  12. Dec 4, 2008 at 12:38 PM
    spaghettiedy
    spaghettiedy Well-Known Member
    Pittsburgh
    09 DC LB Sport in Black 4x4
    Gray Weathertechs, LG Wet Okoles, Tacome OEM Bedmat
    ***AWESOME SOLUTION***
    I read this post right before I got my Okole's in, and didn't really understand what you were talking about.
    GO OUT AND BUY YOURSELF SOME 3M VELCRO TAPE, OR COMPARABLE. Get the width of regular scotch tape.
    1. Remove Seat
    2. Unclip plastic "plastic backing" seat clips from underneath the seat
    3. Install bottoms
    4. Stick the matching velcro for the Okoles to the plastic smooth side of the "plastic backing"
    5. Slide the seat cover over the seat, and velcro the front portion to the velcro tape that you just stuck on the smooth part of the plastic backing (the underneath)
    6. Velco the Okole seat cover to the carpeted back portion of the "plastic backing".
    7. Reclip the "plastic backing", and clip the wet okole's under the seat
    No more funny looking nipples from bending the "plastic backing" up into the Wet Okole seat covers.
    Sorry, no pics. The damn financee had the camera when I was installing them.
  13. Dec 4, 2008 at 1:17 PM
    Johnson8537
    Johnson8537 Well-Known Member
    Oregon
    06 TRD SPORT 4x4 Double Cab Long bed
    Revtek Leveling Kit with 1 1/2 block spacer in rear. 17" MotoMetal blacks on 32" tires. Access Lorado Tonneau - Bed mat Billet Grill Tinted Windows Pioneer 700BT with PAC steering wheel inerface. Wet Okole Seat Covers Front and back.
    I did mine like pictured in this thread if i remember right.
    http://www.toyotanation.com/forum/showthread.php?t=235795&highlight=okole+installation&page=2
    If you can't figure it out by spaghettiedy's post let me know and I can go take pics of how I did mine.
  14. Dec 5, 2008 at 12:51 AM
    FoxySandChick
    Kristin
    Henderson, NV
    I did the folding up option with mine, after awhile the "funny looking nipples" go away and you can't even tell its under there.
  15. Dec 5, 2008 at 9:41 AM
    Johnson8537
    Oregon
    Are you saying you had "funny looking nipples" but look normal now?:D
    Sorry I Had too....
  16. Dec 5, 2008 at 9:47 AM
    Jedidiah
    Jedidiah TakeItEasy
    Oregon
    BHLM Bilstein 5100's BFG AT 285's HID (6000K) Maglite Grillcraft Grill debadged
    Eh howzit going! Just wanted to say good choice with the seat covers! I'm from hawaii and i had a set on my old 04 double cab and i could just hop right in them after a surf sesh. I was wondering where you heard of them....Its awesome!
    Take it easy
  17. Dec 5, 2008 at 10:12 AM
    spaghettiedy
    Pittsburgh
    I heard of them from other TW members. GOOD THING TOO!!! They're are awesome.
    I just got back from a hunting trip. My friend and I were out scouting on the Sunday before, and it was pooring rain out. I new truck not worrying about anything because I had Weathertechs on the floor and Okoles on my seats. I paid about 600 for fronts and rears, but they're worth it.
    This is exactly why people join forums, to figure out what the good shit is for _______.
  18. Dec 5, 2008 at 11:39 AM
    Jedidiah
    Jedidiah TakeItEasy
    Oregon
    Yeah they're worth it!! haha....i took the seat covers from my 04 and put it on my 08 once i got up here too...they last a long time! Anyway take it easy!
  19. Dec 6, 2008 at 12:50 AM
    FoxySandChick
    Kristin
    Henderson, NV
    :eek:
    I expected that ;), I laughed when I read it, so I had to quote it.
  20. Dec 6, 2008 at 2:57 PM
    Johnson8537
    Oregon
    I was going to write "lets see the Proof"... but thought that sounded a little perverted..
    Glad to see you have a sense of humor! :D
