Wet Okole Install? (2009 DC)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cornwall325, Mar 15, 2010.
  1. Mar 15, 2010 at 2:15 PM
    cornwall325
    cornwall325 [OP] Toyota newbie...
    Jonathan
    Virginia
    09' D.C. TRD Sport 4x4
    Seatbelt chime turned off, Toyota bedmat, Wet Okoles, stock other than that.
    I'm getting ready to install my WO's here in a few minutes. Does anyone have any suggestions since this will be my first set of custom seatcovers I'm installing?
    thanks everyone
  2. Mar 15, 2010 at 2:28 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Take the seats out. It give you more room to work on them, and only takes a few mins. :)
  3. Mar 15, 2010 at 2:31 PM
    cornwall325
    Jonathan
    Virginia
    Alright. With that being said, is there anything I need to be careful of since my seats have the air bags in them?
  4. Mar 15, 2010 at 2:33 PM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    for sure take the seats out...it would be nearly impossible to do if you left them in.
    Also on the front seats, there is a drivers side and pass difference. Ask me how I know? Also leave your windows down for a few days if you have the ability. My seats after two weeks have just stopped smelling like a new wetsuit.
  5. Mar 15, 2010 at 2:38 PM
    cornwall325
    Jonathan
    Virginia
    I didn't really want to take the front seats out but I sure don't want to fight these things. :) So I guess I better take a look under the seats and see what all's gotta be unhooked and all that.
  6. Mar 15, 2010 at 3:08 PM
    Reznor88
    Reznor88 Well-Known Member
    Northern California
    '06 PreRunner DC Off Road
    Don't keep anything in the truck that you may need to wear (hat or whatever) or else it's going to REEK of neoprene.
  7. Mar 15, 2010 at 3:34 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    When you take the seats out, just disconnect the wire harnesses from under the seat, before trying to yank it out. Also, DO NOT turn the ignition on with the seats removed. Make sure they are in, and everything is re conected before turning on the ignition.
  8. Mar 15, 2010 at 3:41 PM
    tarandus
    tarandus Well-Known Member
    Montucky
    '17 TRD DCab OR Supah White
    ProComp/Headstrong leveling kit, AllPro rock sliders.
    Would it help to wash them with neoprene soap before installing? Its still cold here and I don't want to be poisoned for two weeks!?
    Also, when taking out the seats, do you just unbolt them, then disconnect? Haven't taken them out of this vehicle before...
  9. Mar 15, 2010 at 3:46 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    4 bolts per seat. 2 at the front, 2 at the rear under a platic cover. Un bolt them first, then lean the seat back, so you can see the connectors. No need to wash them before installing. You wont be poisoned. Also, when removing the seat, lean the seat back all the way forward, and put a couple rags over the seat rails. They are sharp, and the door pannel plastic is soft. A little bump, and it can easilly scratch the door pannel, or dash....
  10. Mar 15, 2010 at 4:05 PM
    motopilot
    motopilot Well-Known Member
    Central FL
    '10 DC TRD SPORT
    just did mine and I think they came out great. very easy to do but take your time. And like everyone said, take out the seats, was waaayyyy easier.
    The WO's fit great and could not be happier. Just take your time and you will be fine. Mine was like @45min.
  11. Mar 15, 2010 at 5:01 PM
    cornwall325
    Jonathan
    Virginia
    Working on the passenger seat now. Are the covers supposed to be like they have air underneath the middle portion of the seat almost like that of being "puffy" or do I need to cinch them on down?
  12. Mar 15, 2010 at 5:05 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes. After a while, They will fit better.
  13. Mar 15, 2010 at 5:15 PM
    mattcombs
    mattcombs Well-Known Member
    matt
    hazard kentucky
    SR5 tacoma 4wd
    3in revtec lisf westin step bars and westin bull bar and some other odds and ends
    put a thin rag or shirt over your bolts when you turn them and it wont scratch the paint
  14. Mar 15, 2010 at 5:41 PM
    cornwall325
    Jonathan
    Virginia
    Anyone in Va. want to help me install these things? For some reason the idea is stuck in my head that I keep doing something wrong.
    Edit: Nevermind I got them going after fussing and cussing. I sure wish I was in Cali. to get these installed for free though. :) I got the passenger front on and I'm gonna put the console cover on and that will be it for tonight. I don't want to spend anymore time outside away from my daughter. :)
  15. Mar 15, 2010 at 6:21 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Looks great! You know you can pull that black inner plastic off (few screws) on the cubby, and get the WO cover inside it so the button is free and clear?
  16. Mar 15, 2010 at 7:47 PM
    cornwall325
    Jonathan
    Virginia
    Anyone have any side pictures of the console cover installed where it's tucked inside of the button? Fooling with it right now and I can't get it to act right.
  17. Mar 15, 2010 at 8:51 PM
    tekshark
    tekshark Member
    James
    Northern Nevada
    2009 super white xcab trd off road
    ohh great cant wait for mine... sounds like im in for some fun times figurin this out with my neighbors in the complex going wtf is he doing agian... :yay:
  18. Mar 16, 2010 at 6:44 AM
    motopilot
    Central FL
    '10 DC TRD SPORT
    LOL no but thanks, going to do that today. I kind of was wondering about that as well as I saw photos from others here on the forum. Thanks!
  19. Mar 16, 2010 at 7:00 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    18 wrx limited 6MT
    Where at in VA are you? Maybe if I decide to buy some since you're an expert now you can do mine for me :D
  20. Mar 16, 2010 at 9:12 AM
    tarandus
    Montucky
    Can't wait to get mine!!!!
