Wet Okole seat covers. How hard could it be?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tman12, Apr 6, 2011.
  1. Apr 6, 2011 at 7:06 AM
    Tman12
    Tman12 [OP] =T=
    Taryn
    VA
    01 Limited Double Cab 4x4
    Brush Guard, Flowmaster,Infinity 12" Sub,Vent Visors, Michelin AT2,Powder Coated stock alloy rims, yakima roof rack and bike mounts.
    Just ordered a pair of Wet Okole front seat covers and was wondering how hard it is to put these awesome things on? They should be here soon and id like to know exactly what to do so I can jump right on it.
  2. Apr 6, 2011 at 7:17 AM
    DOERanger
    DOERanger Well-Known Member
    Jordan
    Knoxville, TN
    2010 DC Sport SB
    No Mudflaps, Fog lights on all the time, Map light/Dome light mod, Door sill protectors, In-channel window guards, Re-badged and sock-monkeyed,many more to come.
    First time, give yourself at least 2.5 hours.
  3. Apr 6, 2011 at 7:22 AM
    mak90
    mak90 Well-Known Member
    Central Coast, Ca.
    06 Tacoma 4x4 TRD Off Road 6 spd
    TRD Exhaust, TSB springs,Weathertech mats,Bed mat, Wet Okole seat covers, TRD Pro Suspension
    Unbolt the seats, makes it easy
  4. Apr 6, 2011 at 7:26 AM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2010 FJC
    55w HIDs, 16" Countersteer Offroads, Yokahama All Terrains, Demello Sliders
    When I had my Tacoma it took me about 30 minutes total, front and rear. I don't understand why it takes people so long but whatever. They slip right on, the hardest part is buckling the straps in tight space (under your seat) and adjusting the straps to make sure they're tight. Never had to remove the seats or anything either.
    However Long it ends up taking you, just know the results are some bad ass seats.
    Also, they smell like wet suit for a couple weeks. Some people are totally fine with it, it made me nauseous and gave me a headache. you can try spraying some febreeze on them to help get rid of the smell. It works a little bit but don't expect for the smell to disappear if you use it.
  5. Apr 6, 2011 at 7:30 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    2006 Toyota 4Runner SR5 V8
    Remove the seats, it makes it easier and it is a good opportunity to clean under them.
  6. Apr 6, 2011 at 8:39 AM
    Supra TT
    Supra TT Solid Axle FTMFW!!
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS.. Need I say more.
    Leave the seats in, and remove every other part of the truck :D
  7. Apr 6, 2011 at 8:40 AM
    JDMcQ
    This is install option "B"
  8. Mar 16, 2013 at 5:23 PM
    SpeedoJosh
    SpeedoJosh Well-Known Member
    Florida
    2010 Access cab, Base, 4x4
    What's the best way to install them in the rear of an access cab? The long piece that goes over the back part has straps that are suppose to go around the back of the seat back, but the seat back is attached to the cab. I couldn't see any screws to remove it either. How do you take it off to get the cover on?
  9. Mar 16, 2013 at 5:58 PM
    Madjik_Man
    Boulder, CO
    1998 Ext Cab 3.4 4x4 TRD 5MT sunfire red pearl
    About 25 pounds of spray paint and vinyl dye
    Are you trying to remove the two seat cushions in the rear?
    If so I think you can just pop those plastic covers off the sides then remove the bolts that hold the cushion to the bracket. (I'm trying to go off memory here when I disassembled my interior).
    If not you can spend the 5 minutes it takes to remove the upper trim panel, the cushion on the back wall and the large rear wall panel. Then you can access the bolts that hold the entire seat assembly to the rear wall of your cab.
  10. May 2, 2013 at 11:43 AM
    SpeedoJosh
    Florida
    How do I go about doing this? Trying to get the cushion on the back wall off.
  11. May 2, 2013 at 12:16 PM
    Madjik_Man
    Boulder, CO
    Trying to remember off the top of my head...
    Remove that upper trim piece that runs along the top of the cushion. It's held in by 4 or 5 clips.
    Once you pop that off, I think there are 3 bolts holding that cushion on.
    After that you can then pry off the large plastic panel. I think there's like 10 or so clips holding that puppy in place.
    After that you can remove the rear quarter panels, rear seats, etc...
  12. May 2, 2013 at 12:33 PM
    97Blk_one
    97Blk_one Well-Known Member
    Memfrica
    not so low
    A whole lot,But not satify
    You can replace the transfer case,Engine Flush, and tranny Oil...but you can't figure out how to put on a wet'Okle on ? An Hour and half for both seats and first-timer.....
  13. May 2, 2013 at 12:36 PM
    SpeedoJosh
    Florida
    Thanks. Ended up finding a PDF with it shown. Thought it was going to be a lot harder then it was.
  14. May 2, 2013 at 1:12 PM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    dude its sooooo easy to do on our '01's . seriously, take off the head rest, slip them on and strap them tight. that. is. it. :)
    edit: above comment was for the OP and I didn't see the date. I have no experience w/ the rears
  15. May 2, 2013 at 1:15 PM
    SpeedoJosh
    Florida
    The OP posted this question back in 2011. I'm pretty sure he has installed them by now. :D
  16. May 2, 2013 at 1:39 PM
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    I thought that was the only way to do it.
