Wet Passenger Footwell Area
Discussion in '1st Gen. Tacomas (1995-2004)' started by MOReese, Feb 3, 2015.
  1. Feb 3, 2015 at 4:55 AM
    MOReese
    MOReese [OP] Active Member
    Jerry
    Osage Beach, MO
    03 Reg Cab 2WD
    New member here, driving truck home from dealer engine light came on. When I got home some 2 hours later I reached for my coat which had fell down into the passenger foot area and parts of it were wet, The carpet was soaked. I'm thinking heater hose or cracked core on heater. Sound about right? Would it also be reason for check engine light or is that something else I need to check out?
    Truck has 190,000 miles on it, one owner. Also might add that the heater was on the entire trip back home.
  2. Feb 3, 2015 at 5:09 AM
    Darryle
    Darryle It is just a truck
    Darryle
    Weatherford, Texas
    Raining or wet outside? Does it smell like antifreeze? A leaking windshield might be a suspect to.
  3. Feb 3, 2015 at 9:04 AM
    Exhaust
    Exhaust Well-Known Member
    Erik
    Wharton State Forest
    02 DC TRD
    Extended breather, Grey Wire mod, Tundra brakes, Rockford-Fosgate sound, General Spring HDs, 5100s + 880s, Heated Seats, TRD Supercharger, 2.1 Pulley, URD 7th Kit
    Could be a stopped up drain tube for your AC condenser
  4. Feb 3, 2015 at 2:08 PM
    MOReese
    Jerry
    Osage Beach, MO
    03 Reg Cab 2WD
    Didn't have the air on, would it still be from the stopped up drain on AC condenser?
    And no it wasn't wet or raining outside, however it had a lot of snow and ice in the bed and on the cowl, which I brushed off before driving home.
    It didn't smell like antifreeze or leave a bad stain on my coat.
  5. Feb 3, 2015 at 2:12 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    If you have the heater set to defrost, you are using the A/C. Plugged a/c drain is pretty common and easy to fix.
  6. Feb 3, 2015 at 2:40 PM
    Exhaust
    Erik
    02 DC TRD
    A good way to check for a plugged drain without getting under the truck is to turn you're radio off after having the defroster on for a little while and go around a tight corner kind of quickly. If you hear water sloshing around, it's a good indicator of a stopped up plug.
    Then just hop under the truck and find the drain tube. It's in the passenger side wheel well area on the inner side of the truck. Poke a stuck or weed whacker cable in there to get what ever is in there out.
  7. Feb 3, 2015 at 2:51 PM
    oldracer
    oldracer Well-Known Member
    As a previous poster has already written; the heater core or hose may be leaking.
    Look under the dash, at the floor vents, for the heater; if there is moisture present, the leak is in the heater core area. If leaking you should see the anti-freeze; as it does not dry or evaporate as quickly as water.
    On another note: Maybe the dealer just scrubbed the carpets, maybe!
    oldracer
  8. Feb 3, 2015 at 3:39 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    in adition to above suggestions:
    rain water getting in from around front or rear windshield or side windows (bad gaskets or even unseen rust holes)
    rain water getting in through hood cowling vent.
    hole in floor letting rain or water puddles splash up into the truck
    leaky door or window seals letting rain water in (check around bottom of door panels) (i have seen it drip in from the door speaker grills)
    heater core leaking (check radiator water level to confirm)
    blocked a/c drain (mostly only leaks when a/c has been used)
    the best way is to follow the water to its highest point and if you cant guess at the origin then remove your carpet and hang it out to dry and leave it out until you find the water source. with the carpet out it is easy to find because the carpet isn't absorbing it and spreading it out everywhere.
  9. Feb 3, 2015 at 9:22 PM
    MOReese
    Jerry
    Osage Beach, MO
    03 Reg Cab 2WD
    Hey, Thanks for the input
  10. Feb 4, 2015 at 2:33 AM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    ^^^^x2^^^
