Wet road "spinning" solution
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoma1944, May 24, 2018.
  1. May 24, 2018 at 8:49 AM
    Tacoma1944
    Tacoma1944 [OP] Member
    Regis
    2015 Toyota Tacoma Access Cab
    I have 2015 Tacoma Access cab long bed (72") and my wheels spin starting out with any rain or wet road. Tires are OEM Dunlop 215/70 R15 and seem to do fine driving but, not starting out and I am pretty easy on the gas pedal. If it was just a winter issue, I could simply add some weight but, it is all year.
    What is best fix? Replacing tires with different style is easy but, I don't want to spend that much and still have the same issue. Would wider tire solve this? Or do I need to get larger rims & tires? How large, as I found a chart that says I can use 16", 17", or 18"? Mine is the 2.7L 4 cylinder.
    Surely this is not isolated issue.
    Appreciate some tips on this.
    ExpertReader likes this.
  2. May 24, 2018 at 8:49 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    User error and/or shitty tires... or both.
    ABNFDC, blu92in99, knottyrope and 2 others like this.
  3. May 24, 2018 at 8:51 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    You are too heavy on the pedal or have shitty tires.
    So if you really are being easy on the gas ... you need new tires
  4. May 24, 2018 at 8:53 AM
    black coffee
    black coffee A is A.
    Glenn
    509
    2010 AC 4x4 SR5 V6
    Stick or auto?
    You just have to learn to take off without spin. This happens to me every once in a while and I’ve been driving for a long time.
  5. May 24, 2018 at 8:53 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Another vote here for garbage tires. Ditch the dungflops
    nobescare and Tacoma1944[OP] like this.
  6. May 24, 2018 at 8:55 AM
    Depoxy
    Depoxy Well-Known Member
    SoCal
    2010 Regular Cab 5-speed 4x4
    URD S/S, Eibach pro-truck @ 0.8" lift, hanook 265/75r16 AT
    Im pretty sure it's the smaller 215 wifth tires and the fact that the dunlops are not that great. My 2.7 could break the stock 245/75r16 dunlops loose in the rain, but not anymore with 265/75r16 dynapro atms. Going up in tire size (diameter) will also reduce the effective torque at the wheels, which will help reduce tire spin as well.
    honda50r and Tacoma1944[OP] like this.
  7. May 24, 2018 at 9:18 AM
    Tacoma1944
    Regis
    Been driving nearly 60 years in a LOT of different trucks, suv's, and cars.
    Thanks all and may have to bump up wheel size
    llamasmurf likes this.
  8. May 24, 2018 at 9:21 AM
    medic2230
    Murph
    Bama! Roll Tide
    Dunflops suck in wet weather. I have the v6 and 285's and can still spin the tires if I give it too much gas but if you go light on the gas like you're driving in wet weather they grip and move the truck just fine.
    Tacoma1944[OP] likes this.
  9. May 24, 2018 at 10:13 AM
    black coffee
    Glenn
    509
    2010 AC 4x4 SR5 V6
    Welcome to the forum.
    It sounds like better tires would help the most.
  10. May 24, 2018 at 10:30 AM
    2011Streaker
    2011Streaker Well-Known Member
    Maine
    2012 DCSB TRD Sport
    Dunlop GrandTrek At20s are the worst performing tire ive ever driven. theyre quiet, but other than that they are atrocious. They corner like shit, they are dangerously under performing in snow, and they suck in the rain.
    Look at Destination A/T by Firestone or Goodyear Wrangler Duratrac
  11. May 24, 2018 at 10:34 AM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    repeat after me michelin michelin michelin...ymmv
  12. May 24, 2018 at 10:41 AM
    King Rex
    King Rex Well-Known Member
    DFW, TX
    2009 DCSB TRD OR
    I have 295 70 17 Nitto ridge grapplers and mine still spin when starting from a stop if I’m too heavy on the gas, so size won’t help you much. A better tire I’m sure will help but Tacoma’s seem to be lighter in the rear compared to what I’ve driven in the past, F150.
  13. May 24, 2018 at 10:49 AM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    What tire pressure are you running? I agree with everyone above the problem is mostly your tires, but too high pressure just adds to the problem.
    DGXR and Tacoma1944[OP] like this.
  14. May 24, 2018 at 10:50 AM
    azzwethinkweiz
    azzwethinkweiz Well-Known Member
    Tucson, AZ
    2013 4x4 DCSB V6 6-Spd, TRD OR, Tow Package
    I once drove a 2nd gen ranger with tiny tires and a peg leg rear end, that thing would spin the tire (not plural lol) at almost every go from a dead stop if you didn't go super easy on the pedal... light truck, even lighter rear end... that's just how it is. I lived in a hilly area and on wet days I would have to purposely avoid the steep hills as I would get stuck at the bottom.
  15. May 24, 2018 at 1:47 PM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Don’t floor it :thumbsup:
  16. May 24, 2018 at 1:48 PM
    Alexely999
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Get a shell, and a rear plate bumper.
    xxTacocaTxx and Tacoma1944[OP] like this.
  17. May 24, 2018 at 1:58 PM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    there is no weight back there
    get some rear sag by slowly pressing the accelerator to transfer weight then got full retard, I mean throttle
    Radarninja and reg0928 like this.
  18. May 24, 2018 at 2:06 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    It’s the tires. Newer better make tires will help, but once they have a decent amount of mileage, they will most likely begin to spin on wet roads from stops.
  19. May 24, 2018 at 2:12 PM
    medic2230
    Murph
    Bama! Roll Tide
    I agree, the AT20's are the worse tire I've ever had. They will slide on a wet road with little effort turning. I replaced mine within a couple months with Nitto Terra Grapplers and been very happy with them and their performance all around.
  20. May 24, 2018 at 3:40 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    This was my thought when reading the original post. The recommended pressure for the stock 215s is 29 front and 32 rear. It's my understanding that the rear is higher because many owners forget to add pressure with a load in the bed. So when it's empty you can take a few pounds out of the rears since it's so light back there. Just be sure to air them back up if you load the bed or tow anything.
