Wet seat belt after rain
Discussion in '1st Gen. Tacomas (1995-2004)' started by rybern, May 4, 2021.
  1. May 4, 2021 at 4:59 PM
    rybern
    rybern [OP] Well-Known Member
    N Alabama
    2025 TRD OR & 2000 SR5
    We had a hard rain at work today and when I got in my truck to leave, I noticed that when I put on my seat belt it was wet. The further out I pulled it the more wet it was. Somehow moisture has gotten into the area where the seatbelt rolls up. I don't see any other wet areas and the carpet inside the truck is dry. No roof rack or holes in the roof of my 2000 ex-cab and all windows were up and door shut completely.
    Any ideas?
  2. May 4, 2021 at 6:34 PM
    Pscdouglas
    Pscdouglas Wish you weren't so awkward Darry.
    Stu
    Glens Falls, NY
    2004 black Tacoma Xtracab 4WD TRD AT, 2020 Black Tacoma ACLB 4WD Sport MT
    I had the exact same problem a year ago! I found a daylight gap in the rubber weather seal around the top right corner of the door. Try using a flashlight and a partner to see if you can locate anything not water tight around the door.
  3. May 4, 2021 at 7:23 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    It won`t hurt check around the windshield water gets in on the left side runs along the wire harness.
  4. May 5, 2021 at 3:18 AM
    rybern
    N Alabama
    I'll look at that. I appreciate the response.
    Thanks.
  5. May 5, 2021 at 4:50 AM
    Vann
    Vann Well-Known Member
    Garth
    Weisenburg, PA
    '04 x-cab 4x4, 2.7 5sp. "The Black Pearl"
    stock
    I had the same issue several years ago as well, despite looking for a possible source for several days I never found one and it only happened once. The only scenario I could come up with was that the seatbelt did not retract and got caught outside of the door weather-stripping during a soaking rain.
    ekul310, Wyoming09 and Seagull233 like this.
  6. May 5, 2021 at 4:17 PM
    hogeyphenogey
    hogeyphenogey Back in a Tacoma
    Dave
    Agawam, MA
    Lunar Rock 2023 TRD Sport 6spd
    Every damned time!!!
