wet transfer case! why?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Deer Slayer, Jun 11, 2009.
  1. Jun 11, 2009 at 8:00 PM
    Deer Slayer
    Deer Slayer [OP] Active Member
    NW Mississippi
    08 4X4 I4 MT Acc Cab
    My truck only has 16K miles on it and recently when I had crawled under my truck I noticed that my transfer case was wet with oil :(. I am not sure why and what is going on. it is not dripping oil, just enough to wet the surface. Has anybody else experienced similar thing on low mileage truck and how did you guys deal with it?
  2. Jun 11, 2009 at 9:47 PM
    dirthawker1313
    dirthawker1313 Well-Known Member
    take it to your local dealer under warranty.. have them take a look.
  3. Jun 12, 2009 at 1:26 AM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    It's the transfer case seal. While your down there, check around the oil pan on the motor. If that's lubed up too, your rear main seal is going.
    All under the Powertrain Warranty :)
  4. Jun 12, 2009 at 5:07 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Where has Toyota quality gone?
  5. Jun 12, 2009 at 5:19 AM
    Joe B
    Joe B Well-Known Member
    It went away when Toyota started making vehicles here and in Mexico.
    Also,Toyota's quest to be #1 cause a hit in quality control.
  6. Jun 12, 2009 at 6:13 AM
    TX Tacoma
    TX Tacoma Fightin Texas Aggie
    Arlington, TX
    Have to admit, hearing about failing rear main seals on a Tacoma with 16K miles is scary. The bad news is that's a PITA job, the good news is that it'd be covered under warranty. Hopefully your case is a statistical outlier and the majority of us don't have to worry about it. You can bet I'll be keeping an eye on it though. Thanks for the heads up.
  7. Jun 12, 2009 at 7:12 AM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    Classic !.............^^^^
  8. Jun 12, 2009 at 7:15 AM
    Deer Slayer
    NW Mississippi
    Where is the "rear main seal"? not sure what you guys are refering to!
  9. Jun 12, 2009 at 10:43 AM
    johnecon2001
    Phoenix, AZ
    You can't see it with the transmission attached to the motor. But you can see if it's leaking.
  10. Jun 12, 2009 at 10:51 AM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    06 DC 4x4 TRD Off-Road
  11. Jun 12, 2009 at 10:51 AM
    Deer Slayer
    NW Mississippi
    is it on back side of engine where it is connected to the transmision?
    I haven't noticed any other oil leak under the truck. nothing on the engine oil pan or the manual transmision, so if this seal is where I think it is, it is not leaking. I think in my case since the oil leak is isolated to the transfer case and it is a good distance from the engine and transmision, I believe it is isolated to the transfer case seals. I thought maybe the bolts attaching the housing together needs to be tightened. maybe it is nothing wrong with the seal itself, just bolts not tightened adequately!
  12. Jun 12, 2009 at 12:16 PM
    Janster
    Jandy
    Lancaster, PA
    Take it to the dealer anyway..... Use and abuse them for as long as you can. You paid for it!!
  13. Jun 12, 2009 at 6:22 PM
    Deer Slayer
    NW Mississippi
    I am not sure if that is worth the waisted time, hastle and aggrevation; leave alone that at the end of all that, they won't do anything about it and just make up B.S. excuses why they won't do anything.
  14. Jun 12, 2009 at 6:31 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    did you clean the transfer case yet to see if you can pinpoint the leak?
  15. Jun 12, 2009 at 6:44 PM
    Deer Slayer
    NW Mississippi
    Not yet. I just got my order of Red Line gear oil and am going to replace them this weekend. At that time I will check the bolts around the transfer case to see if they are not properly tightened and if not, I will tighten them a little more, then clean up the whole housing and check later to see if gets wet again. But I am a little concerned if the problem persists and it is something that I can't simply take care of myself, Toyota dealership may refuse working on it if they find out that I had messed with it.
    As it is clear, I am a little conflicted. It is very hard for me not to at least change the gear oil in it now that I have got all those high quality synthetic gear oil from Redline.
  16. Jun 12, 2009 at 6:47 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    its one reason i'd clean the area first before the gear oil change...............if it is leaking, and under warranty, they'll probably end up draining it/loosing oil from it while they are fixing the leak, and if you go on with the new redline, you'll have to redo it after the leak is fixed. thats why i recommend cleaning it first just to see, and if no leaks after tightening bolts up....go ahead with the oil change.
  17. Jun 12, 2009 at 6:58 PM
    Deer Slayer
    NW Mississippi
    Do you think if I just tighten the bolts and clean it up, they would have an excuse to deny warranty if they have work on it?
  18. Jun 12, 2009 at 7:00 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    no way.......especially if it starts leaking again. i mean.......you didnt make the seal faulty, if its leaking from a seal. trying to tighten bolts to see if thats the problem is smart in my opinion.
  19. Jun 12, 2009 at 7:05 PM
    Deer Slayer
    NW Mississippi
    OK. I will change all the other gear oils except the transfer case, but will just check the bolts and clean it and wait and see if it gets wet again. If it does, I will take it to the dealership.
  20. Jun 12, 2009 at 7:06 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    to me.....thats your best bet. after it quits leaking/is fixed....go for the good oil in the transfer case.:)
