Whale Whale Whale - She wont start. HELP
Discussion in '1st Gen. Tacomas (1995-2004)' started by blakewhisenant, Jan 3, 2013.
  1. Jan 3, 2013 at 7:38 AM
    blakewhisenant
    blakewhisenant [OP] Active Member
    Blake
    Oklahoma
    1995 Toyota Tacoma 4x4 V6
    lots to come...
    The facts:
    I have a 95 tacoma, auto, 4x4, 3.4 v6. It has over 200K miles on her. Had a old Alpine alarm installed, no remotes. Truck ran great.
    The story:
    I wanted to install a car alarm, for the keyless entry. This was my first alarm and first mistake in 2013. I could not get the alarm working. I decided to scrap the idea, removed all alarm conections. This truck did have a alarm installed, so I was able to see 80% of the splices made the first time and reuse them.
    I moved the truck to my drive way. The next day my truck would not start.
    The Problem:
    Truck will not start.
    Has a newer battery. Turns over, cranks fine. Just does not seem to fire up.
    Fuel or spark right? I have check all the fuses, they are good. I switched the EFI and Acc relays. Also checked AM1/2 and they seem to be good.
    I have the OCR out, but am not sure how to test it...
    I do not hear the fuel pump running... Does this make a sound that would let you know? I have read some say it does and some say it does not.
    I have an Ohms meter but am not sure I am using it the right way (Ha!) and have ordered a new fuel pump to install. And have an OBDII scanner on the way as well (have wanted on for a long time).
    Lets keep in mind that my truck started fine after removing the alarm.
    It has a lot of miles.... but ran fine...
    What did I do?
    What should I check?
    Is this a common problem?
  2. Jan 3, 2013 at 8:07 AM
    Devout
    Devout Well-Known Member
    Seattle
    03 TRD 4X4
    None yet
    My favorite way to differentiate between fuel and spark problems is with a little starting fluid.
    I've never done it, but can't you use a tire pressure gauge on the fuel rail valve to check fuel pressure?
  3. Jan 3, 2013 at 8:10 AM
    blakewhisenant
    Blake
    Oklahoma
    lots to come...
    My volvo has that kind of connection, but the tacoma requires a bolt and fitting or something.
  4. Jan 3, 2013 at 8:51 AM
    RAT PRODUCTS
    RAT PRODUCTS RAT Products
    Farmington, MN
    Cummins Coal Rollin SOB
    Smokin with a smarty.
    When you turn the key to ON, you should hear a faint buzzing sort of noise. That is the fuel pump. On my Honda, when I thought the fuel pump was bad I removed the fuel hose before the intake and put it in a milk carton. Then when I turned the key to ON it pumped into the carton and I knew it worked. Simple test.
  5. Jan 3, 2013 at 8:57 AM
    blakewhisenant
    Blake
    Oklahoma
    lots to come...
    No buzz. So I am happy I have the pump on the way.
    Does anyone know how to test the COR/OCR? Can I make a jumper wire to test with?
    I am trying to stop throwing money at it, I need to trace the problem down.
  6. Jan 4, 2013 at 6:33 AM
    blakewhisenant
    Blake
    Oklahoma
    lots to come...
    any ideas guys...
  7. Jan 4, 2013 at 6:35 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    2006 Toyota 4Runner SR5 V8
    Find out if you have power to the pump before throwing a new one at it.
  8. Jan 14, 2013 at 6:26 AM
    blakewhisenant
    Blake
    Oklahoma
    lots to come...
    I GOT IT FIXED!
    Turns out it was the Mass Air Flow Sensor!
    I ended up changing the Fuel filter, and had ordered the fuel pump, but did not install it.
    I got the MAF from Pull-a-part, off of newer Lexus. Only $21 bucks! Sure beats 500 OEM!
    Its running!
    Next step is to have my mechanic do the front end, I ordered all the parts for about 200 bucks. I got PepBoys to price match rockauto.com
    It can be done! LOL
