What’s causing the pinging
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Benchunter9, Mar 6, 2020.
  1. Mar 9, 2020 at 2:55 PM
    #41
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    I had/have the pinging issue with my 2014. I had the TSB reflash done and it helped, but it's still there. Usually in the low RPM while I'm trying to go up a hill or something in 4th or 5th gear. I haven't heard it at higher RPM's or when just accelerating in the low RPM's. It sounds like you may have it worse than I typically hear people talk about it.
    Are you able to help Toyota replicate it, in place of them trying on their own? First thought was to seek OVTune or HPTuners. Which might help. But it may also be something physical like the others have suggested since the Tacoma ECU tune is with all the 2015's and I haven't heard much issue from others.
    I know the TSB didn't apply to your 2015, so hopefully the recommendations on the seafoam or the plugs work. I haven't heard of anyone really getting rid of the pinging also. My 2014 still has it some even when using 92 octane, although less.
  2. Mar 9, 2020 at 4:14 PM
    #42
    TacoLyfe867
    TacoLyfe867 Well-Known Member
    Art
    2013 4x4 Tacoma TRD
    Have the same issue with my 2013 TRD 4x4. Was way worse when i first got the car in summer and previous owner only filled with 87. Pining hasn't been as bad recently with the cold weather and now i only use 91. Same issue with OP that the noise is non existent when truck is not under load ie. when the car is revved in park or neutral i dont hear any pinging.
    05chaos likes this.
  3. Mar 9, 2020 at 6:08 PM
    #43
    Nachomama2001
    Nachomama2001 Well-Known Member
    South Carolina
    2013 Tacoma TRD OR prerunner
    Bilstein 6112+5160s Air pump delete-Hewitt Technology Rear view mirror switch Hawk pads G2 BAK flip Roadmaster active suspension Seat lifters HVAC AJT knobs
    Mine does it too. New plugs, tsb ecu update...still does it. I even had ecu remapped on here..still does it.
    I now run 93 and for the most part it’s gone but I still hear it.
    Ridiculous.
    My wife’s 3.5 highlander runs like a bat out of hail..with zero pinging on 87.
  4. Mar 9, 2020 at 8:51 PM
    #44
    bluezzy
    bluezzy Love My SuperCharged 07 Sport!
    Monty
    Eugene, Oregon
    #44
    DGXR likes this.
  5. Mar 9, 2020 at 8:57 PM
    #45
    Bishop84
    Bishop84 Well-Known Member
    Knock sensors dial back timing to prevent knock. They aren't magic wands.
    If there is pre-detonation from carbon the sensors can't do anything to stop it.
  6. Mar 10, 2020 at 5:30 PM
    #46
    Nachomama2001
    South Carolina
    I don’t think it’s carbon. I’ve done new plugs, techron, Italian tune-up...same result. Change taco to turd.
    Wish I would have bought 4 banger.
  7. Apr 8, 2020 at 7:53 AM
    #47
    Sirnick88
    Sirnick88 Well-Known Member
    Nick
    2011 TX Pro, 6spd MT, boosted
    URD mk3 s/c, Dobinsons snorkel, Ultragauge, Stoptech rotors, TRD ceramic brake pads, softopper, anytime backup camera, anzo black headlights, oh, and vehicle OCD organizers!!!
    @Benchunter9 sorry if I missed this, but which seafoam did you use? I do a combo every year or two in my gas tank, with an oil change, and the spray into my throttle body. No issues here and I'm at 84k.
  8. Apr 8, 2020 at 10:50 AM
    #48
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    My 15 4.0L doesn’t knock or ping on 87 top tier fuel. I also run Amsoil PI every 5K. 91K currently.
