What’s in your First Aid Kit?
Discussion in 'Recovery' started by Jmad1997, Jul 20, 2019.
  1. Aug 9, 2019 at 8:27 AM
    #41
    blewisemt
    blewisemt Member
    Ben
    Southern Delaware
    16 MGM Tacoma DCSB TRD OR
    Rock Sliders, Tires, Husky Liners, Remote Start, KTJO Tailgate Lock, TRD Wheels, Console Outlet, Decked System, Tonneau Cover
    I think the most important aspect of wound packing is training. Dfanonymous could likely achieve much better results with plain roller gauze than someone with limited training is probably going to get with a hemostatic agent.
    Extra Hard Taco and Gunshot-6A like this.
  2. Aug 9, 2019 at 6:12 PM
    #42
    Jmad1997
    Jmad1997 [OP] Well-Known Member
    2005 TRD sport long bed 6" fab tech lift
    Not that I’m aware of but in my instances that is an overlooked item. and nothing sucks more than having nausea/vomiting or diarrhea while camping or on the trail.
    StillNoPickles likes this.
  3. Aug 9, 2019 at 6:20 PM
    #43
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    list is growing fast
    These are both low volume high reward items to carry.
    you sir are ready for combat fields.
    I'm EMS, wilderness, FD, LEO, SAR trained...
    I carry a pretty comprehensive first aid kit. Nothing all of you ah my said already. But it's when you aren't around your resources when your life saving instinct comes in handy.
    It's amazing what a roll of duct tape and the clothes off your back can do in an emergency.
    Jmad1997[OP] likes this.
  4. Aug 12, 2019 at 8:03 AM
    #44
    chiefcrunchy
    chiefcrunchy Well-Known Member
    Brian
    Between North and South Virginia
    '15 DC MGM TRD Sport 4x4 6spd 4.0
    5100s, 885s, deaver AAL, Waiting impatiently to install Demello front bumper, Mobtown sliders & skids, and safari snorkel.
    And the one thing I always think about adding but never do is some sort of dental repair or sealant.
  5. Aug 12, 2019 at 11:22 AM
    #45
    Jmad1997
    Totally overlooked! I will be looking to add something along those lines to my kit.
  6. Aug 12, 2019 at 11:33 AM
    #46
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Super glue
  7. Aug 12, 2019 at 10:03 PM
    #47
    blewisemt
    blewisemt Member
    Ben
    Southern Delaware
    I think that depends on how far you are from help. None of us, save for dentists perhaps, train regularly for dental emergencies. I'm not sure what the utility would be in carrying such a niche piece of equipment unless you are truly days away from a road. That said, temporary filling material such as Cavit can be used in cases of specific dental pathologies.
  8. Aug 13, 2019 at 3:16 PM
    #48
    PacNW_Taco
    PacNW_Taco Get lost.
    Colby
    Tacoma, WA
    2016 Black DCSB OR
    Peachy Peach air fesheners
    Went on a ride-along with Sea FD last month, and they specifically warned about standing back for those two reasons, if Narcan was used. It was used, luckily no vomit or punches, but the immediacy in which it works was remarkable.
    Jmad1997[QUOTED][OP] likes this.
  9. Aug 21, 2019 at 9:17 AM
    #49
    bagleboy
    Scott
    Norcal, Santa Rosa
    Probably the most taken for granted item is anteseptic like neosporin.
  10. Aug 28, 2019 at 7:51 AM
    #50
    Scott17818
    Scott17818 Well-Known Member
    Scott
    Midcoast Maine
    2016 Tacoma DCSB OR
    methodMR305NV, 265/70/17duratracs, ARB RTT, DITCH Lights
    I carry this in my center console https://www.walmart.com/ip/Total-Resources-International-First-Aid-Kit-123-Pieces/20450231
    .. and I have a small back of bandaids behind my rear drivers seat. (literally has only a dozen bandaids, and some alcohol prep pads in a plastic case
    eventually when i go onlonger trips, and cross country ventures I plan to get a much more extensive kit.. like this... https://www.amazon.com/MFASCO-Compl...irst+aid+bag&qid=1567003788&s=gateway&sr=8-13
    and yes I have had training on all of it.
    chiefcrunchy and Jmad1997[OP] like this.
  11. Aug 28, 2019 at 8:02 AM
    #51
    StillNoPickles
    StillNoPickles Well-Known Member
    2020 RAV4 Hybrid LE
    Had a work accident yesterday and people were scrambling to provide aid to someone. Biggest thing I’ve noticed with premade kits is that the contents are usually cheap (even in expensive kits), they aren’t organized all that well or functionally, and you’re paying a ton for convenience. This leads to wasted time in the case of an actual emergency, and while this case wasn’t time sensitive, you may not have that luxury in the backcountry. That is why I’ll always advocate for building and organizing your own kit. You can build it to your specific needs, know exactly where everything is located, and save a ton of money in the process. It allows for familiarization and confidence in the field, which is where it matters.
  12. Aug 28, 2019 at 11:27 AM
    #52
    Scott17818
    Scott
    Midcoast Maine
    2016 Tacoma DCSB OR
    while I am in agreement with most of this, there are good box kits out there. just have to plan and look at content lists, as some put in stuff you will never/hardly ever use.. others like bacitracin, or neosporin, or alcohol wipes you will use a lot of, not to mention items to clip nails (should you stub a toe, and need to cut a nail/nailbed out).. a splint is good to have, but you can make one from wood, and a piece of cloth.. cold compress, you should have ice, or cold water in your cooler, but an instant pack works in a pinch, steri strips, gauze, and wrappings, as well as some coban for pressure dressings, hypafix, and tegaderm are my favorites for medium sized wounds, while I've had great luck with the 3m NexCare Bandaids (pricey at $9-11/box).. I'm also not shy about taking a clean shop towel and wrapping my finger in electrical tape, or the large roll of gorilla tape i keep in the truck.. FYI electrical tape comes clean off the skin if you change the bandage as soon as you get the right stuff, or get home with proper supplies.
  13. Aug 28, 2019 at 12:14 PM
    #53
    StillNoPickles
    2020 RAV4 Hybrid LE
    Agreed on all of this. Too many people included overlanders and outdoorsman buy a kit and don’t think twice about it until they need it and find out that they’re poorly equipped.
    Your second half is very valid. Folks sometime just need to think outside the box and improvise with what’s available. That why I like the WFR training so much!
  14. Aug 28, 2019 at 12:20 PM
    #54
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
  15. Aug 28, 2019 at 4:43 PM
    #55
    Jmad1997
    Knowing where your gear is during an emergency is a huge success. I’ve seen a few pre made kits that were setup easy. Packing your own kit is good, I need to open mine up once and while to remember where it all is.
  16. Aug 30, 2019 at 1:55 PM
    #56
    Gruber1922
    Gruber1922 Well-Known Member
    Tacoma, WA
    2015 Tacoma Sport
  17. Sep 1, 2019 at 10:07 AM
    #57
    chiefcrunchy
    Brian
    It only works as good as your knowledge.
    If you haven't opened the kit since purchase, it's going to slow you down. Regardless of pre-made or assembled personally, know how to use things and put them in an order that makes sense.
  18. Sep 1, 2019 at 2:17 PM
    #58
    C-Rok275
    C-Rok275 Well-Known Member
    2017 TRD Pro
    6112/5160s with Icon stage 2 leaf’s.
    Definitely not my job.
  19. Sep 1, 2019 at 2:20 PM
    #59
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    Exactly. My kit is for people with me and legit injuries of people around me. Drug induced people can go help themselves. I'm an EMT too. Being type 1 diabetic I'm always wondering if I were to pass out if someone is going to administer narcan to me.
  20. Sep 1, 2019 at 2:27 PM
    #60
    Scott17818
    Scott
    Midcoast Maine
    2016 Tacoma DCSB OR
    lol, narcan has an expiration, and must be stored under 100 degrees.. pretty sure my interior gets over 120 in the summer with the windows closed.... if it was a police officer sure... some meathead taking any drug laced with fentanyl can F- themselves.. not that it matters much anymore.. there are narcan resistant fentanyls out there... can't do anything to counter their affects other than put someone on O2, and hope you get them to an ER fast enough to get intibated, and plumbed for artificial respiration.. this is partly the reason I offroad.. I get my excitement from being outdoors, seeing things few get to and enjoying life with some like minded people. campfires, a few beers.. that's all I need.
