What’s the best/easiest way to swap tesla rims to a Tacoma ?
Discussion in 'Street Trucks' started by MiniTaco1, Sep 26, 2021.
  1. Sep 26, 2021 at 7:48 PM
    MiniTaco1
    MiniTaco1 [OP] New Member
    2014 Tacoma single cab
    None
    I want to put a set of Tesla rims I have on my Tacoma. What’s the best way ? Blank rotors , have them drilled to Tesla pattern ? Or pre drilled Tesla rotors installed on Tacoma? Adapters?
  2. Sep 26, 2021 at 7:56 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Bolting to the rotor seems reasonable.
    nudavinci64 likes this.
  3. Sep 27, 2021 at 1:43 AM
    BananaMan
    BananaMan Well-Known Member
    Bumfrick nowhere Maine
    06 2.7 RC 2wd manual "squattytruck"
    A set of adapters would probably be your safest and "easy" method. You'll have to find a company that can make a custom set that goes from 5x114.3 to whatever Tesla is. Good luck!
  4. Sep 27, 2021 at 2:02 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    If your trucks a 5 lug, the Tesla bolt pattern Should bolt right up.. no clue if backspacing or anything else will work out though
    BananaMan likes this.
  5. Sep 27, 2021 at 2:06 AM
    BananaMan
    According to my close friend (google-fu) the Tesla uses 5x120. Kinda weird
  6. Sep 27, 2021 at 8:01 AM
    Empty_Lord
    Dan
    Hmm. I could of sworn they’re 5x114.3 too.. my buddies has aftermarket wheels that are. But maybe he is running spacers
  7. Sep 27, 2021 at 8:05 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    Easiest would be to contact one of the OEM reproduction wheel manufacturers and see if they could produce a Tesla style wheel in the fitment you want.
  8. Sep 27, 2021 at 8:10 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    adapters
  9. Sep 27, 2021 at 8:24 AM
    rumandcigars
    rumandcigars Member
    Richard
    Florida
    2021 SR5
    Typical of Tesla, some models are 5x114.3 and some are 5x120.
  10. Sep 27, 2021 at 8:28 AM
    Toyko Joe
    Toyko Joe Here for the pictures
    What’s inviting you to want Tesla wheels over something else? Seems like a strange combination to me.
    rumandcigars likes this.
  11. Sep 27, 2021 at 10:57 PM
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Got this from someone on TW . Punch in info for specs
    ohcaltexscar likes this.
  12. Oct 4, 2021 at 5:06 AM
    ohcaltexscar
    ohcaltexscar Out of Huckleberry Licorice…
    Chas
    El Paso, Texas
    2005 DCLB SR5 Prerunner
    IM4x4 2.5" NitroGas - Coopers
    Which Tesla wheels? Let’s see a picture!
    The Model 3 uses 5x4.5, should bolt right up if you have a 5 lug. You’ll need a 2 mm spacer ring for the center bore though, the Tacoma is 60.1 mm and the Tesla’s are 64.1 mm.
    Adapters seem like your best cost/simplicity ratio if you’re a 6 lug.
    I like this website a lot, and www.tiresize.com too. I scroll around on them a lot :rofl:
    hemitruk[QUOTED] likes this.
