What’s the best fuel injector cleaner?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1997tacomav6, May 21, 2019.
  1. May 21, 2019 at 8:07 PM
    1997tacomav6
    1997tacomav6 [OP] V6 5sp,RegCab,TVS1320 Supercharger,Haltech, 800k
    Denver
    I know there are PLENTY of fuel injector cleaners out there.
    But what’s the best???
    and does it take just one application for a full cleaning?
    GQ7227, homegrown_xt and OneWheelPeel like this.
  2. May 21, 2019 at 8:50 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    dealer told me yesterday i can get some real good cleaning for about $250 :eek:
    anybody ever have that type of service done?
    takes ~2 hours I think he said
    they use BG stuff, not sure what else
    it will make my truck sooo much faster too, he also said
    snake oil or not :confused:
  3. May 21, 2019 at 8:51 PM
    black coffee
    black coffee A is A.
    Glenn
    509
    2010 AC 4x4 SR5 V6
  4. May 21, 2019 at 9:01 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
  5. May 21, 2019 at 9:03 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    how much for your own system?
    I don't much care to pay dealer that money
  6. May 21, 2019 at 9:05 PM
    Speedytech7
    Can make it yourself with some pipe and pipe fittings, lots of instructions on the internet
    https://youtu.be/dp-ECEpN52k
  7. May 21, 2019 at 9:55 PM
    Luv my yota
    Luv my yota Well-Known Member
    00 turd lift 33's
    Kings,total chaos uppers, Deavers, JBA headers, Borla exhuast, engine mods, DC power 270 amp alt, 2k watts of sound, gps alarm.
    Send em to RC injectors in Ca, they cleaned mine and rebuilt them professionally with exact denso parts, and sent them back cleaned flow benched and a printout of flow beforehand and after. It’s about 150 and they package them up nicely and send you, your old o rings and pintels. Next day service too, I had two tested that dripped out of my six, and they match them to the same flow, racers do this even with brand new injectors to match flow, they have the worlds fastest Supra running their custom built injectors. They tell ya nothing in a can will make them flow correctly, I’ve used every type over the years and now will only have these guys clean and match mine.
  8. May 21, 2019 at 10:18 PM
    1997tacomav6
    Denver
    I like this info, thanks,
    What is the time frame or miles for having injectors cleaned
    Luv my yota[QUOTED], GQ7227 and CS_AR like this.
  9. May 22, 2019 at 12:24 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    To me if it is not broke don`t break it!!
    Starting to bleed into the manifold so full of dirt the spray is a trickle time to do some work .
    Get another set of injectors send them out install them send the set you removed out when you feel the need change them again repeat .
    Seems to be luck some get 75,000 miles the next gets 250,000 miles my original are 230,000 miles
    GQ7227, cruiserguy and oneshot808 like this.
  10. May 22, 2019 at 5:18 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    using my degree from google university lol @jbrandt
    'Cleaning fuel injectors is a service frequently recommended by dealers and repair shops. But unless there are noticeable signs of clogged fuel injectors (such as a rough idle, stalling, poor acceleration or high emissions levels), it might not benecessary.'
    is this with NO cleaning or additives,etc ever?
  11. May 22, 2019 at 5:34 AM
    1997tacomav6
    Denver
    I’ve never had an injector actually fail, but I’m guessing a dirty one like a dirty filter
    would not let the engine perform as well as it should
    GQ7227 likes this.
  12. May 22, 2019 at 5:38 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    it never hurts to try! your truck only lives once :)
    are you equipped with the scientific measuring equipment to plot and graph the data points, (before and after measurements)
  13. May 22, 2019 at 5:44 AM
    1997tacomav6
    Denver
    Next time I need a rebuilt on the supercharger I probably will do this because the supercharger has to be completely removed to get to them
  14. May 22, 2019 at 5:45 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    From what I've read, proper functioning injector shoots a fine mist of fuel. When this mist is compromised(debris or anything keeping it from engaging or sealing off fully, etc) the fuel air mix doesn't cumbust fully or as complete as it should. Or something kinda like that lol
    But i imagine it's a real thing that accomplishes real goals because race cars do it:D
  15. May 22, 2019 at 5:57 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    so in the meantime what are your plans, or have you decided yet on one of the additives?
  16. May 22, 2019 at 6:00 AM
    1997tacomav6
    Denver
    I will probably just toss a can BG cleaner in there for now
    GQ7227[QUOTED] and cruiserguy like this.
  17. May 22, 2019 at 6:01 AM
    cruiserguy
    Elijah
    SEKS
    That or Techron are about the best you can do for just throwing something in the gas tank
  18. May 22, 2019 at 6:04 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    are you opposed to that dealer cleaner service i mentioned?
  19. May 22, 2019 at 6:11 AM
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    BG officially recommends FI service every 15k miles, many dealerships such as mine (Cadillac) will recommend every 30k.
    1997tacomav6[OP] and GQ7227 like this.
  20. May 22, 2019 at 6:21 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i do recall getting the fuel injector cleaning as part of the yearly maintenance packages in the early days (may have been every 30k perhaps 15k (will check))
    then in 2oo7 they pretty much stopped having the all-inclusive packages and started doing chit ala carte, totally messed up my scheduled maintenance :(
