What’s this noise?! Happened after Bilstein 5100 install
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jamie4x4, Feb 19, 2019.
  1. Feb 19, 2019 at 9:07 PM
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    Check the clearance between your sway bar and lower spring seat. ;) I put a set of 2nd gen 5100's on the bottom notch with 888 coils on mine and get an occasional rub there.
  2. Feb 19, 2019 at 9:41 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Pull the tire off and test it.
  3. Feb 20, 2019 at 5:30 AM
    Tommyb08
    Tommyb08 Well-Known Member
    Tom
    Jersey Shore - Ocean County
    2017 TRD Sport 4X4 DCLB Black
    I had the same noise on my 2nd gen when my exhaust heat shield was falling off, it was hanging on by one bolt, part of the shield rotted away.
  4. Feb 20, 2019 at 3:42 PM
    rzgkane
    rzgkane Well-Known Member
    Huntington Beach, CA
    2019 Tacoma TDR Sport 4WD DCLB - Cement - Tech and Premium
    4Runner Trail wheels and Toyo Open Country ATII tires 265-70-17. Cosmetic stuff like Pro grille and OffRoad black bumper trim, vinyl delete on side, added hood graphic, OEM tube steps.
    Too tinny for a sway bar. Shield of some sort. Buy a rubber mallet from Home Depot and bang on the tire/frame/exhaust until you find it. It'll be easy.
    tcjacado[QUOTED] likes this.
  5. Feb 21, 2019 at 8:53 PM
    tcjacado
    tcjacado Well-Known Member
  6. Feb 21, 2019 at 9:11 PM
    modifiedtaco
    modifiedtaco Well-Known Member
    Alex
    2016 Magnetic Gray Tacoma Limited
    Tuff Country 3 inch spacer kit with aal Tuff Counrty 1/4" spacer on LF (for taco lean) Bilstein 5160 rear shocks Bilstein 5100 adj front struts (removed tuff country front spacers) set to 0 lift OME 886 coil springs Front sway bar relocation bracket N-Fab Rock Rails 17x9 -12 Fuel Beast wheels Toyo AT2 285/70/17 tires Led light conversion on all interior lights Morimoto 35w HID kit 5500k OE all weather floor mats OE Tonneau cover OE Door Sill Protectors Bed Mat De badged all factory emblems matte black vinyl tailgate letter and Tacoma emblem on door silver vinyl insert on glove box and door sill protectors OME Carrier Bearing Drop Insain Fab cab mount chop plates Weathtech Rain guards
    the only thing that could've been touched when installing the 5100's that would make a similar noise is the backing plate. did you leave any tools or loose bolts /nuts lying or wedged on the knuckle near backing plate? I agree it does sound like and exhaust shield though. Its also possible its something unrelated to what you just worked on
  7. Feb 21, 2019 at 10:05 PM
    Jamie4x4
    Jamie4x4 [OP] Well-Known Member
    Jamie
    San Diego
    ‘18 MGM OR 4wd DCLB (Stolen), in market for new DCLB
    255's, 5100s w OME, full Martin Roof Rack, Snugtop
    Just found a full 30 rack in there. Got the beer smell out but unfortunately it was unrelated to the rattling noise.
    avw4x4[QUOTED] likes this.
  8. Feb 21, 2019 at 10:06 PM
    Jamie4x4
    Jamie
    San Diego
    Not yet. I’ll look into it more tomorrow! Where are the exhaust sheilds located?
  9. Feb 21, 2019 at 10:07 PM
    Jamie4x4
    Jamie
    San Diego
    really appreciate it. I’ll definitely want to meet up with you guys. I live in Solana Beach (5 minute walk from seaside reef)
  10. Feb 21, 2019 at 10:07 PM
    Jamie4x4
    Jamie
    San Diego
    I’ll check it out. Thanks!
    tcjacado likes this.
  11. Feb 22, 2019 at 6:26 AM
    tcjacado
    Bolted above the exhaust.... they look kinda like tin foil pans.
