What’s up with the clicking?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Archer757, Sep 29, 2019.
  1. Sep 29, 2019 at 12:22 PM
    Archer757
    Archer757 [OP] New Member
    2005 6cyl 4x5
    I have a 2005 4x4 4.0L. So far I have replaced the sway bar end-links, both CV axles. Upper and lower control arms, front wheel bearings, shocks, swaybar bushings, Even new spring clips on the brake pads. Before I started replacing all these items I had a clicking sound coming from the front end. Anytime I hit any type of bump the front end “clicks”. After I replaced each of these items, I test drove the truck and the sound is exactly the same. Does anyone have any ideas of what else it could possibly be?
  2. Sep 29, 2019 at 12:34 PM
    JoshS
    JoshS Well-Known Member
    Josh
    2014 Tacoma TRD Sport DCSB 4x4
    Mine does this too if I go too fast over speed bumps (>6-8 MPH I'd say)
    I have a 2014 AT 4x4 4.0L, stock suspension, tires, etc up front still.
  3. Sep 29, 2019 at 1:06 PM
    ohiowa
    ohiowa Have you tried rebooting?
    Ohio
    2015 Super White TRD OR DCSB V6 6MT
    ARE Overland Shell
    My RA60F manual 4X4 does this when the clutch is depressed or if it's in neutral over bumps. The whole driveline sounds like it rattles. Nothing is loose and a good friend I have at a Toyota dealer says it's normal.
  4. Sep 29, 2019 at 1:11 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Could try your radiator support bushings.
