What’s up with the SR5 tire size?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kidlin, Jul 27, 2021.
  1. Aug 20, 2022 at 2:32 PM
    #61
    adrew
    adrew Well-Known Member
    '21 SR 2.7L 4x4 Old Man Truck
    Leer 100XR
    Yeah, I mainly got them so I could air them down to 20-25 PSI and not worry about punctures or sidewall cuts. I don't need their capability about 95% of the time, but when we go to Colorado we like to do 5-6 days of dispersed camping out in the wilderness on rough roads with sharp rocks, or going through deep sand and stuff, so I was a little nervous to do that on the thin/SL stock tires.
    These are so light (relative to a 33" BFG KO2 or something that weighs almost 60 lbs) and added a ton of capability with barely any MPG penalty. It seems most people just immediately add the largest possible tire which kills performance and MPG. I found that a more capable tire in the stock size was all we needed for the easy/moderate trails around the Ouray ara.
    AxisCab likes this.
  2. Aug 20, 2022 at 2:45 PM
    #62
    Toe Knee
    Toe Knee Well-Known Member
    Tony
    Chester County
    2020 DC Black
    For your use, understandable. Me, some light off road on vacation and mainly on road normally
  3. Aug 20, 2022 at 10:39 PM
    #63
    bham
    bham Member
    none
    This is a timely thread for me. Time for a tire decision for my Taco. I have around 60K miles on my 2018 SR5 Access Cab and need to be looking at new tires. I swapped out the stock tires the day after I bought the truck for Falken Wild Peak 265/75 R16 tires. Great tires in my opinion, we live in a 4 season climate, driving is maybe 80% urban and 20% Nat Forest/ logging roads. With a rear bed cap and the decked sys installed (300lbs?) my milage is still around 21/22 when not using the winter blend of gas. I am not a hard core off roader. Also no rubbing at all, stock set up, except for the summo springs in the rear.
    I am looking at Coopers, another set of the Wild Peaks or maybe BFG KO.
  4. Aug 20, 2022 at 10:42 PM
    #64
    Coondawg07
    Coondawg07 Master of none
    Alabama
    2016 DCLB BBP
    I’m currently looking at the General Grabber. Might be another one to consider for you.
  5. Aug 21, 2022 at 5:05 AM
    #65
    usmc2msu
    usmc2msu Well-Known Member
    TJ
    2017 SR5
    The Coopers are awesome. Especially on snow and ice.
  6. Aug 22, 2022 at 7:31 AM
    #66
    bham
    bham Member
    none
    Question for those of you who are running E rated or the tires rated for towing. My understanding is they have stiffer sidewalls for towing/hauling. Does that effect the ride quality of your Tacoma ? I retired a month ago and my driving habits are changing. I find myself towing the cargo camper (about 2200-2300 lbs) much more on camping / hunting trips. I expect that to continue or increase as time goes by. Wondering if I need to consider those E or 10 rated tires? Also they seem to be a bit heavier as well, about 10 lbs per tire. That is going to effect mpgs a bit.
    Lt. Dangle likes this.
  7. Aug 22, 2022 at 8:01 AM
    #67
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    I went from SL rated wildpeaks to E rated S/T Maxx's and notice no substantial difference when towing between the 2 tires. I have around 70k miles on my truck and better than half of that is towing.
    Most SL rated tires have a higher capacity than the truck, so there is really no "need" to go to an E rated tire for towing with a Taco IMO. Are the SL's squishy compared to an E? Yeah I guess, but adjusting air pressure can negate most of that and at the weight you are towing, it's only an extra 300# or so of weight the truck is carrying from the Tongue. Carry around a fat friend (not judging, I like pie too.) and see how it handles lol.
    MPG's and ride quality take a major hit on E's as well. Ride quality is subjective of course, but MPG's aren't.
    As someone who ran SL's for 55k miles and E's the last 15k, I would stick with SL's is my advise for what you mentioned.
    gudujarlson and bham[QUOTED] like this.
  8. Aug 22, 2022 at 8:15 AM
    #68
    CalcityRenegade
    CalcityRenegade Well-Known Member
    Calgary, Alberta, Canada, Earth
    2023 T4R ORP KDSS
    The option page of the brochure is where it lists tire sizes for each trim level.
  9. Aug 22, 2022 at 10:27 AM
    #69
    adrew
    Leer 100XR
    I don't haul or tow but the primary reason I got E-rated ones was so I could air down and not worry (as much) about punctures when we are on trips. It does ride more firmly with 45 PSI (really only noticeable if you hit a giant pothole) but it corners a lot better (tires don't immediately roll over and howl). With a 39-lb E-rated tire in the stock 245/75-16 size, I lost maybe .5 MPG around town and 1 MPG on the highway (24-25 is still attainable on the highway at 65-70 MPH vs 25-26 before).
    I kept the OEM Firestone LE2 tires that came on mine (in case the MPG was drastically affected). The sidewalls were so thin and flexible - the summer tires I put on my Yaris feel sturdier/more substantial.
    bham likes this.
