What’s your opinion
Discussion in '3rd Gen. Tacomas (2016-2023)' started by T-Rev0831, Mar 25, 2023.
  1. Mar 25, 2023 at 8:44 AM
    T-Rev0831
    T-Rev0831 [OP] Member
    Trevor
    2008 Tacoma DCSB long travel
    BTF +4.5 long travel
    I have a friend who has only owned tacomas his whole life, with that said he’s in a bit of a dilemma. My buddy currently owns an 08 Tacoma sr5 double cab, that he bought new and currently has 67000 miles on it. He is meticulous with his truck and is probably the most maintained Tacoma I have ever seen… changing directions he just had his 2023 trd pro delivered and he loves it and all it’s features and is pumped about it.
    Which brings me to my dilemma that I wanna help him out with he has cerebral palsy and use crutches to walk with he called me up and said the truck is taller and he struggles to get in compared to his 08. I searched the thread and from what I’m finding nobody has lowered a 4 wheel drive yet, which why would you right, but in his case I understand. I’ve obviously searched around and found kits claiming 3” of lowering and stating for 2wd and 4wd. I don’t mind being the first but my knowledge is in the other direction of reputable company’s for lifting and I’m hoping you guys can put me into the correct company.
    Thanks for any help or recommendations
  2. Mar 25, 2023 at 8:49 AM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    factory running boards, or step nerf bars. Ski
    StayinStock and 98_3RZ_NIC like this.
  3. Mar 25, 2023 at 8:54 AM
    Bishop84
    Bishop84 Well-Known Member
    He could swap out the suspension for a lower trim level, it will lower it a bit ~1" but the newer tacomas sit higher in general.
    I'd suggest checking out all the choices for side steps and see which works best.
  4. Mar 25, 2023 at 8:55 AM
    Exfordman
    Exfordman Well-Known Member
    Norman
    2021 Tacoma TRD OR 4X4 LB White
    None
    Amp research power step. Pricey but retractable.
  5. Mar 25, 2023 at 8:56 AM
    T-Rev0831
    Trevor
    Skidooboy truck has them already
  6. Mar 25, 2023 at 8:57 AM
    T-Rev0831
    Trevor
    Exfordman that is an option but our harsh wyoming winters not always an option cause the damn things freeze up around here.
  7. Mar 25, 2023 at 8:58 AM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
  8. Mar 25, 2023 at 8:58 AM
    T-Rev0831
    Trevor
  9. Mar 25, 2023 at 9:00 AM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
  10. Mar 25, 2023 at 9:00 AM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
  11. Mar 25, 2023 at 9:01 AM
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    He bought a lifted truck what did he expect tho
  12. Mar 25, 2023 at 9:18 AM
    T-Rev0831
    Trevor
    Okay I guess I need to re iterate here yes I have searched. The thread you listed last response was a year ago and honestly doesn’t answer my question on if the kits really will work on 4wd. And yes he knows he bought a lifted truck but he bought it for what it is and knowing I could make it work for his needs. Installing the lowering kit is not a problem at all it just seems to cheap to be true for a 4wd vehicle to be lowered
  13. Mar 25, 2023 at 9:34 AM
    LeakyAC
    We need to know how low he wants it
    Also he bought it "for what it is, knowing I could make it work for him".... but here you are, not knowing how to make it work for him.
    Steves104x4 likes this.
  14. Mar 25, 2023 at 9:36 AM
    RyanDCLB
    4/19 DCLBOR
    @TRSAndrew
    https://www.tacomaworld.com/threads...ally-some-good-pictures.658718/#post-23005695
  15. Mar 25, 2023 at 9:39 AM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Lowering 4wd pickups is very common especially in northern states.Rob measurements from his truck and see where it needs to sit. Drop the rear an inch maybe or get some softer coils from eibach
  16. Mar 25, 2023 at 11:08 AM
    Gatafly
    Gatafly Well-Known Member
    Shawn
    2020 TRD OR AT V6 MGM
    Swap the OR suspension for the Pro and drop a tire size which will probably be about 2" and better than a lowering kit. You could swap with someone on here and money in your pocket and pay for new tires. In other words zero net cost and 2 happy people.
  17. Mar 25, 2023 at 11:36 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    My 87 year old mother had no problems getting into my lifted F150 by stepping on the nerf bar even after having both hips replaced. If your friend can get in an 08 truck he can get in the 23 with steps, running boards or something similar. This doesn't have to be complicated.
    Stevie17 and Jesse H like this.
  18. Mar 25, 2023 at 11:42 AM
    Jesse H
    Jesse H Well-Known Member
    Jesse
    Texas
    '22 TRD Pro 6MT
    There's a lot of overthinking here.
    A late model PRO isn't that much taller than an 08 SR5. Just find one of the many aftermarket running boards that has a lower step height. If he wants to go fancy there's absolutely nothing wrong with the motorized ones; which is what I'd rather go with to not cut into the ground clearance.
    Lowering a PRO makes no sense.
  19. Mar 25, 2023 at 11:46 AM
    AM6217
    AM6217 Well-Known Member
    2021 SR-5 DCSB Silver metallic
    :popcorn:
    Stevie17 likes this.
  20. Mar 25, 2023 at 12:27 PM
    T-Rev0831
    Trevor
    Well I guess I anticipated the same positivity in the 3rd generation threads as the 2nd generation threads
    WOW was I wrong, probably my fault for asking a question that I didn’t have adequate information I felt I was looking for
    I appreciate those that have given some positive feed back and yes my fault for not stating hed like to go around 3 inches lower due to him being handicapped, yes did he need the pro absolutely not did he want it obviously and did he buy yes. So now I have been asked to help due to the vehicles I have built and the things I have accomplished. I have never lowered a Toyota and was asking for opinions on that.
    Guess im wrong which is fine because im more than capable of calling the manufacturers of these lowering kits and discussing it with them, I just figured with how helpful the 2nd gen owners are 3rd gen owners where the same.
    You guys clearly aren’t grasping the fact that I am friends with someone who is handicapped by cerebral palsey and uses hand controls but does not let him dictate his choice in buying a bad ass vehicle. Is it not the best choice to lower a trd pro financial absolutely not but at the end of the is anything we do to our vehicles outside of keeping it stock?
    @LeakyAC Im asking opinions of the kits that are available and if they truly are 4wd/2wd compatible but thanks I get it shouldn’t have asked on here, and yeah he is handicapped with cerebral palsy and uses hand controls and bought probably way more truck than he needs but im not one to judge some one in there choices im only gonna lower it
    @Marshall R that’s wonderful your mother had successful recovery thanks for the information ill make sure I tell my friend hes a bitch for being born with cerebral palsy and he should man up
    @Jesse H we live in Wyoming and I see constant problems for nearly 5 months out of the year where they freeze up, I had already stated that. yeah lowering a pro doesn’t make sense but that wasn’t my question im asking if the kits are compatible or not
    Glad I could come here and be discouraged on asking a question when really theres not much on this forum for lowering a 4wd 3rd gen
    thanks
