What 16" wheels won't rub on calipers? Eagle Alloy 140
Discussion in 'Wheels & Tires' started by blazermaniac, Dec 8, 2012.
  1. Dec 8, 2012 at 12:05 PM
    blazermaniac
    blazermaniac [OP] Active Member
    Brian
    Oregon
    Black 08 TRD off-road 6sp.
    Just got a set of EA 185's 16x8 (4"BS) and they just barely contact the caliper. Mostly this has to do with the shape of the wheel rather than back spacing. I really don't want to run wheel spacers or grind down the calipers because there should be a wheel out there that fits correctly. I'm looking at EA 140's but they have a positive offset. (the 185's are -12mm). I think this means less clearance since the hub sits further into the wheel, correct?
    1) Anyone running 140's have caliper clearance issues?
    2) Would going to a 17" help at all?
    3) What are YOU running that doesn't have any issues?
    Thanks in advance for any advice.
  2. Dec 8, 2012 at 12:14 PM
    Robertocritser
    Robertocritser Well-Known Member
    Levi
    KY
    08 sport
    Dirt king 3.5 LT kit with kings, 4 link rear with foa, 4.56 gears, Detroit and arb lockers, one piece drive shaft, armor, and some other things.
    I'm running kmc enduro 16x8 4.5 bs and don't have any issues
  3. Dec 8, 2012 at 12:24 PM
    90YotaPU
    90YotaPU The Messiah
    Union County, NJ
    1990 Toyota 4x4 (Pre-Taco)
    Aftermarket Stereo, Spidertrax Wheel Spacers, HF Air Horns, 3" Lift
    I bought a set of used Eagles and had the same issues. Ran 1/4" spacers for a while but had massive vibrations. Ended up going to the Mickey Thompson Classic II's with 3.65" backspacing.
  4. Dec 12, 2012 at 2:05 PM
    blazermaniac
    Brian
    Oregon
    I exchanged the 16's for 17's and they clear the caliper just fine, about 1/2".
