What 4 Gaues do you view on your Scanguage?
Discussion in 'Performance and Tuning' started by luk8272, Dec 1, 2008.
  1. Dec 1, 2008 at 2:08 PM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I was just curious as of to which gauges you choose to view most often on your Scangauge? Here is mine
    MPH MPG
    RPM LOD
    As of right now I am averaging 22.2 mpg, wish it would stay that way.
  2. Dec 1, 2008 at 2:10 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    Rpm hpr
    mpg water temp(forget the acronym)
  3. Dec 1, 2008 at 2:12 PM
    tacoskim
    tacoskim Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
    HP, Intake temp, MPG, and TPS
  4. Dec 1, 2008 at 2:13 PM
    roxspin72
    roxspin72 Enjoying my addiction
    NC
    Speedway Blue, TRD, 4X4,
    Oh Yeah!!!
    How are you getting HP? Is that the X-guage option. I think I need to hook this back up and check it out:D
  5. Dec 1, 2008 at 2:14 PM
    dually
    dually Low and slow
    yep, x-guage
  6. Dec 1, 2008 at 2:15 PM
    tacoskim
    Los Angeles, CA
    Stock
  7. Dec 1, 2008 at 2:17 PM
    roxspin72
    NC
    Oh Yeah!!!
    Whats yours displaying if you dont mind me asking:D
  8. Dec 1, 2008 at 2:17 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    are these scangauges hard to install? i dont really have a whole lot of tech knowledge
  9. Dec 1, 2008 at 2:18 PM
    roxspin72
    NC
    Oh Yeah!!!
    Plug & Play...
  10. Dec 1, 2008 at 2:22 PM
    tacoskim
    Los Angeles, CA
    Stock
    i heard the most realistic numbers are in the 4th gear. ive broken over 300 a couple times but that was in third gear.. i gotta get to 4th gear to get a more accurate reading.
    EDIT: these numbers are to the crank
  11. Dec 1, 2008 at 2:28 PM
    dually
    dually Low and slow
    Pretty sure the HP numbers are in %. There is no sensor on the truck to determine "actual" HP numbers.
  12. Dec 1, 2008 at 2:30 PM
    tacoskim
    Los Angeles, CA
    Stock
    the engine load gives u the %
  13. Dec 1, 2008 at 2:30 PM
    tdm156
    tdm156 Well-Known Member
    San Antonio, TX
    2009 DC 4x4 SR5**Sold
    RPM MPH
    MPG Water Temp
  14. Dec 1, 2008 at 2:34 PM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Southern Louisiana
    Thanks for that info I will be playing with that now.
  15. Dec 1, 2008 at 2:37 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    DTE (Distance to Empty)
    APG (Average MPG per tank)
    MPG (instant), MPH (Miles per hour), or RPM's - I switch around on these frequently.
    Water temp
  16. Sep 5, 2009 at 11:27 AM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    RPM MPH
    MPG Water Temp.
  17. Sep 5, 2009 at 11:35 AM
    MSteinhauer
    MSteinhauer Well-Known Member
    Redondo Beach, CA
    09 4x4 DoubleCab SR5
    Why do so many people watch water temp? I'm thinking of getting the scangauge but I have an 09 and don't know where I'd want to install it since people don't like how the blendmount works in the 09s and I'm not too crazy about sticking velco on my truck.
  18. Sep 5, 2009 at 5:05 PM
    carmellocafe
    KEVIN
    N. California
    That's a good question. I guess I watch water temp. just cuz I'm curious to see what kind of driving makes the bigger differences in it changing. I'd defenitely watch tranny temp. if it were available.:mad: I wish oil pressure was displayed too.:rolleyes:
  19. Sep 5, 2009 at 5:08 PM
    storktaylor
    storktaylor Well-Known Member
    California, MD
    09 Pre-Runner TRD Off-Road
    Bak FLip G2 ScanGauge2 Black Labrador Retriever
    Distance to Empty AVG
    HP MPG
  20. Sep 5, 2009 at 9:41 PM
    JKD
    JKD Well-Known Member
    Mpg volts
    avg.mpg h2o.temp
