What 4 Gaues do you view on your Scanguage?
Discussion in 'Performance and Tuning' started by luk8272, Dec 1, 2008.
  1. Sep 5, 2009 at 9:44 PM
    Timicha
    Timicha Timicha
    TIM
    Tillamook / Portland , Oregon
    04 White Tacoma
    Fabtech 4 inch lift, tinted windows, diff drop, 33 inch MTZ tires on Raceline Raptor wheels, ELITE OFF-ROAD bumpers and sliders
    i do
    mph rpm
    hpr mpg and occasionally i subsitute the hpr for water temp
  2. Sep 5, 2009 at 9:47 PM
    04coma
    04coma Well-Known Member
    Justin
    Temple Texas
    04 trd offroad sr5 prerunner debadged
    air aid intake and throttle body spacer billet grill clear corner lights and 3rdbrake decal "coma" :)
    may i ask is this only for the 2nd gen i just googles this product and looks like it just plugs in to where the obd goes and whats the point of having one?
  3. Sep 5, 2009 at 9:55 PM
    Timicha
    Timicha Timicha
    TIM
    04 White Tacoma
    it works for any car or truck with the obdII sensor. i have the first gen
  4. Sep 6, 2009 at 1:40 AM
    JKD
    JKD Well-Known Member
    What's the point of having one? Well, access to the computer's sensor data, the ability to display it as four numeric gauges, trip computer functions, code reading and reset functions...
    That's about it, really.
  5. Sep 6, 2009 at 2:17 AM
    MiikeyD
    MiikeyD The Green Machine
    Upland, CA
    Green Prerunner DC 2.7L
    Suspension / Wheels / Tires 3.5" Fabtech lift w/ AAL 265/75/16 BFG A/T American Racing Baja Audio Alpine HU CDA-9886 Kicker DS650 Z-Edition 1000W Memphis M3 US Amps 4000W 2.5Farad Cap Lighting 6000K HID 2 Hella 500FF 2 Aux Bed Lights 2 Aux Driving Lights Performance Volant CAI Flomaster Super 44 Doug Thorley Long Tube headers (coming soon) NGK Iridium Sparkplugs Accessories Scanguage II Cobra LTD27-NW with 3' Firestik Radio Shack Triple Trunking Scanner Harbor Freight Hi-Lift Cosmetics Flat Black Bumper Trim Flat Black Grill Surrounding with Satoshi Clear Corners Future Modifications (not specific) Longtravel w/ king shocks or fox Caged bed Shackles rear suspension. Fox / king shocks custom front bumper Custom Glassworks extreme kit for 01-04 (only have hood and passenger side.. need driver panel) Supercharger + 8port intake manifold optima yellow top battery remounted new rims caged interior rear bench removal 4 sparc
    RPM VOLTs MPG Intake Temp
  6. Sep 6, 2009 at 9:06 AM
    DblD
    DblD Well-Known Member
    Dave
    SW Missouri
    '18 DCSB TRD/OR - Prem. & Tech.
    Anyone have any pictures of where you have yours mounted in a 2nd generation? I have often thought about pulling the trigger on one of these units but I can’t decide where to put the display so it doesn’t look hokey(sp?).
    Thanks,
    dd
  7. Sep 6, 2009 at 11:03 AM
    JKD
    I don't have a pic handy, but I tried a location I saw in a picture somehwere, and it has worked great. On my auto trans '09, there is a little oddly shaped storage pocket in the dash close to my right knee. I test mounted it there, and I can easily glance down through the steering wheel and see the left two gauges without moving my head during normal driving. I can shift my head slightly to see the right two gauges.
    Benefits: Five minute install, you can coil the extra wire and stick it behind the gauge in the pocket, and it is all but invisible from the outside.
  8. Sep 6, 2009 at 12:06 PM
    sonjay
    sonjay Well-Known Member
    Avg L/100km, realtime L/100km, water temp, volts
    I've got mine mounted with the velcro it comes with on top of the steering column.
    How do you get distance to empty displayed?
  9. Sep 6, 2009 at 12:12 PM
    Hologram
    Hologram Go with the flow
    Pensacola-Destin, FL 850
    03 Doublecab PreRunner SR5
    mpg/rpm/hp/mph
  10. Sep 6, 2009 at 12:41 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    where in the hell is the OBDII sensor in the second gens????
  11. Sep 6, 2009 at 12:54 PM
    xsvtoyz
    xsvtoyz Well-Known Member
    AL
    Oklahoma
    03 Pre-Runner Inprogress
    HID (ACA)/ Web cams/ Header/Full Custom exhaust/ K&N FIPK II/SuperCharger
    air temp/mpg/water temp and tps since on my 3rz the tps seems to change with the humidity and I monitor that. idles tps varies from 9 tps to 13 tps depending on the humidity.
    :rolleyes:
  12. Sep 6, 2009 at 3:17 PM
    blackphantom09
    blackphantom09 Newbie
    V.B., VA
    09 Double Cab TRD-Off Road SB
    TRD Exhaust, Black badges, Jason Rage tonneau bed cover, TRD S/C, OEM roof rack, Avid Light Bar
    It took me a while to figure out where I wanted to mount my scangauge. I didn't want to purchase the blendmount so I mounted the scangauge on the steering column with the velcro. I ran the wire through the steering colum and left some slack so that on hot days or when I don't want to leave the scangauge in the open for people to steal, I just keep it in the little storage compartment above my right knee.
  13. Sep 6, 2009 at 3:50 PM
    socaltrucker00
    socaltrucker00 Well-Known Member
    Luis
    South California
    00' stepside tacoma
    rims
    where do u guys get this feature? any links thankjs
  14. Sep 6, 2009 at 10:43 PM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    It's tucked up under the dash on the left side. Also has a cap covering the port that just pulls off. :)
  15. Sep 6, 2009 at 10:53 PM
    #35
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    Why do you guys monitor rpm and mph if you already have it displayed on the stock gauges?
    I understand that if you modified your wheel size it will display the correct speed and such, but I think you are wasting the features of your scangauge.
    Just my .02.
    btw, I monitor batt. voltage, mpg, LOD, and either water temp. or intake temp.
    voltage because I have a lot of lights and an inverter, plus when im in pismo, we play music a lot at the camp site and I monitor how much battery I have left. Intake temp cuz I have a cold air intake and I wanna make sure it matches outside temp. well, and water temp. to gauge how warm my engine is after start up.
    you're saying humidity affects throttle position??
  16. Sep 7, 2009 at 5:43 AM
    #36
    xsvtoyz
    AL
    Oklahoma
    yeah it seems to have an effect on the tps reading. in the am its like 9 and when I go home its like 13 and varies through out the day. the idle stays the same but since I watch the tps I noticed it varies. Kinda odd but it does not seem to be a performance issue just odd. I have heard other 3rz/2rz owners say the same but not 6 cyl. thats what is odd.
  17. Sep 20, 2009 at 12:36 PM
    #37
    JKD
    Hit the lower right button. You will see something like "Code" and "Trip" on the left hand side, "Gauge" and "More" on the right.
    Hit "Trip".
    Now the left hand bottom button might say several things, but press it until you see "Tank".
    Now cycle through the trip gauges using the top left and right buttons. You should see one that says "xxx miles to empty".
  18. Sep 20, 2009 at 12:45 PM
    #38
    moto932
    moto932 What's the matter, Colonel Sandurz? CHICKEN?
    Eric
    Dayton, Ohio
    04 TRD Off Road
    Basically stock. OME 882s, HD Dakars and nitrochrgers, TG front bumper, custom rear bumper, 4Xinnovations sliders, RAT skids, Softopper, 255/85/16 ST MAXX's on 16" steelies, 1" B.O.R.A. wheel spacers Scangaugae II, deck plate mod, grey wire mod,ECGS bushing, diff breather relocation, alarm mod, defrost w/o compressor mod, de-badged, sockmonkey beside decals.
    do you have to have the xgauge for the hp reading? do i need to get the extra length of wire for my 1st gen?
  19. Sep 20, 2009 at 12:54 PM
    #39
    carmellocafe
    KEVIN
    N. California
    I've been wondering this too! I've read JKD's post further down the page. I can see the reading that way, but how do you get it to show up as one of the four gauges displayed?? Or can you? :confused:
  20. Sep 20, 2009 at 2:33 PM
    #40
    JKD
    The manual is a little cryptic, but I do think you can do this...somehow.
    I haven't tried yet.
