What A Dipstick
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bsheriff11, Apr 28, 2013.
  1. Apr 28, 2013 at 6:11 PM
    Bsheriff11
    Bsheriff11 [OP] Remember Your ABC's. Always. Be. Casual.
    Brandon
    Virginia livin', South Carolina raised
    2000 Limited T4R
    Click My Sig Homie
    Are you a victim of changing your own oil, only to check your oil level and realizing its inaccurate? Well that's me, these dipsticks suck, and I want the exact amount of oil in that damn engine the book calls for. That book is my bible and the dipstick is the devil! Suggestions for aftermarket sticks?
  2. Apr 28, 2013 at 6:13 PM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    Just put the required by the book amount in and disregard your dipstick?
    Keep track of your "proper" fill level on the dipstick and go off of that in the future.
  3. Apr 28, 2013 at 6:13 PM
    TacoDawgfan
    TacoDawgfan Hunker Down You Hairy Dawg!
    Georgia
    2011 Silver 4x4 TRD Sport w/JBL
    5100's at 1.75, Rear leaf TSB, Moto Metal 951 16x8, BFG TKO2 265/75/16, AFe Stage 2 CAI w/pro dry filter, Kenwood DDX374BT installed with Idatalink Maestro kit, Access Loredo tonneau cover, N-Fab steps, Tinted windows, EGR in channel vent visors, UGA drink coasters in the front cup holders, and a Graco car seat in the back seat
    There are some more threads on here already discussing this. Some sanded on the dip stick to help. Search on here if you want to read more on it.
  4. Apr 28, 2013 at 6:14 PM
    AK Taco
    AK Taco Well-Known Member
    matt
    Anchorage, Ak
    chrome-free '99 sr5
    20% tint on all windows, Deckplate mod, satoshi-ish grille, blacked out and/or body matched emblems, rattle canned rims, red l.e.d. interior lights, bilstein 5100's and OME 881 coils , deaver 8 leaf pack, 1.5" lift shackle, alpine sound system, 55w HID lightforce 140 and 170 fogs
    Don't worry what the dipstick says. Just put in the specified amount, and call it good.
  5. Apr 28, 2013 at 6:16 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Remove dipstick.
    Wait 5 minutes for the dipstick tube to drain
    Insert and remove to measure.
    The tube extends down into the sump, and removing the dipstick "drags" oil up the tube. Makes for inconsistent readings if the tube is not allowed to drain.
  6. Apr 28, 2013 at 6:18 PM
    Bsheriff11
    Brandon
    2000 Limited T4R
    Click My Sig Homie
    Yea thanks for the replies, I'm just being silly tonight. But seriously, I can't disregard that dipstick, it is the eye for which sees proper lubrication. I will sand it tomorrow, and sorry, I was too lazy to search through the threads.
  7. Apr 28, 2013 at 6:19 PM
    Slodgetto
    Slodgetto Über Posre
    Silas
    Is the dipstick saying too much or too little? Because you'll never get all the oil/other crud out of there.... so in theory, adding the exact capacity as stated in the bible might overfill the engine? :notsure:
    I usually trust the dipstick over the bible stated capacity.....but that's just me.
  8. Apr 28, 2013 at 6:26 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    I just dump in 5.5qts, and dump the last 1/2qt into the wife's Rav4 because at 140k she's using a bit between changes now.
    1/2qt high or low is not going to cause a problem on the Tacoma.
  9. Apr 28, 2013 at 6:27 PM
    Bsheriff11
    Brandon
    2000 Limited T4R
    Click My Sig Homie
    True enough, the engine does like to consume oil so I check it regularly and just anal about oil levels. Usually I put the 5.5 in, then wait 5-7 days and check it again and it usually is thick about half way up, then thins out. So I just put another quart in today and it is reading thick all the way to the second notch, and thin about an inch above that. Not a big deal as I can drain some if I hear any engine noise, but just curious if anyone had any mods to the stick, or tips. Just more of a OCD thing I guess.
  10. Apr 28, 2013 at 6:34 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Your 2012 shouldn't be consuming any oil yet, and shouldn't for a very long time.
    My wife's Rav4 is an '04, and she's hard as hell on it with constant short trips and self-imposed stop and go driving (she seems to think that a zig-zag across a diagonal is a shorter distance than driving straight down the perimeter).
    And she only burns a half quart over 5000 miles.
    If your dipstick is showing oil between the marks, the level is good. It's a gauge, not a meter.
  11. Apr 28, 2013 at 7:32 PM
    Jetman1979
    Jetman1979 Well-Known Member
    Michael
    North Texas
    2009 tacoma 4X4
    Fill with right amount of oil and use a etcher to make your own line.
  12. Apr 28, 2013 at 7:54 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    The problem isn't the dipstick has poor calibration, the problem is inconsistent results when checking because of the way it draws oil up the tube when withdrawn.
    You end up with a heavy layer of oil below the marks, and then "spotty bits" from the marks up another foot.
    Give the tube 5 minutes to drain, then reinsert the stick and the results will be much more consistent.
  13. Apr 28, 2013 at 8:43 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    :thumbsup:
    never even thought about this. :) thanks!
  14. Apr 28, 2013 at 8:53 PM
    EatMyTacomaDust
    EatMyTacomaDust Well-Known Member
    2014 "Black Beauty" Baja DC 4x4
    ICON 3" LIFT, Console Vault, Tailgate Security Clamp MOD, SuperBumper Crash Attenuator, TRD Front Skid Plate, Wet Okoles - 1/2 Piped, Undercover SE Tonneau
    Jesus, I've tried everything it seems BUT THAT!
    Thanks Rich.
  15. Apr 28, 2013 at 9:30 PM
    Raceline08
    Raceline08 Well-Known Member
    Brett
    Santa Rosa, ca
    Silver 08 DBC SB 4x4 TRD Offroad
    front Billies, 885x coils, taco lean spacer, TC UCA'S, Magnaflow 22" OME Dakars, Billy 110 rear's, B.A.M.F CMC, custom made E-locker guard
    This makes great sence. Thanks Rich!
    Thanks,
    Brett
  16. Apr 28, 2013 at 9:37 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    I change mine at night, and wait till morning to check it. the 5+ quart jugs have worked well for me so far. just dump er in, start the truck to fill the filter (I hate how the v6s install upside down so that I cant fill it before starting), then leave it till morning.
  17. Apr 29, 2013 at 7:00 AM
    Wicked 2007
    Wicked 2007 Well-Known Member
    Bay Area, CA
    2007 Tacoma AT DC SB 4x4
    2007 Tacoma Double Cab SB 4WD - Auto -TRD Off Road - Icon Billet UCA - 8" ORI Front Struts - Bilstein 5100 11" RCD Shock - AllPro Expo Springs - Demello Sliders - Tom Woods 1 Piece Driveshaft - 16x8 Mojave Teflon Rims - Locker Mod - Locker Guard - 35" MT MTZ's - ARB Bumper - Warn 8000 winch w/synthetic line - All-Pro Front Skid/Transmission Skid/Rear Armor - ARB Front Locker - Nitro 4.56 gears - Marlin 4.7 crawl box - Twin Stick FJ t-case - ATO high clearance rear bumper
    exactly what I do. if you want real accurate take it out overnight and reinsert/check in the morning.
  18. Apr 29, 2013 at 8:19 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    i just let it all settle down. i have no issues reading my dipstick.
  19. Apr 29, 2013 at 6:45 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    I don't have the patience for that.... but I do have the patience to check the tire inflation or clean the windows ;)
  20. Apr 29, 2013 at 6:49 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    If you live in an area with road salt, the engine will outlive the frame/body by a signficant margin. ;)
