What a weekend
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jconn47, Mar 23, 2021.
  1. Mar 23, 2021 at 4:38 AM
    jconn47
    jconn47 [OP] Well-Known Member
    Jordan
    2009 White Tacoma TRD Offroad
    Well the weather in Vermont finally got nice where I could do some things outside on my truck. Got Bilstein 5100s paired with their 600 springs on the front, which lead to the discovery of previously installed Camburg UCA that were extremely worn and damn near frozen. I bet those things had never once seen grease. Okay fine, ordered some JBA and I'll fix it.
    Next up, the rear shocks. Before beginning the R2 process I threaded the nuts that came with the shocks on what I thought was enough. Well I guess it wasnt quite enough because a little while later I cannot figure out why the nut is turning so hard. Definitely didnt want to mess anything up so I took the new shock back out. Looked at the threads on the shock, they look okay. Look at the threads on the nut, fine there too. Try to thread the nut on and it goes about 2 threads on and boom, stops. Same thing with both shocks paired with either nut. Took the shocks to a parts store and no one in the store is able to find a nut that fits on these studs. has anyone else run into this? The shocks are Bilstein 5125s.
    A slew on other things then presented themselves to me but the last main one is the damn IG1 no2 fuse blowing. I've read several of the threads on this and they havnt seemed to quite help, though admittedly I havnt put the proper amount of time into it yet. In the last week ive replaced the fuse 3 times. Once a week ago and once last night and again this morning. The first two times it happened right after I reversed up an incline. But this morning it was right after a bump pulling into a gas station. The fan/ac hasnt been on any of the times. I'm stumped a few times over with all these :bananadead:
  2. Mar 23, 2021 at 7:45 AM
    dustinJ
    dustinJ Taco abuser
    Dustin
    Amarillo tx
    09 dcsb Super white 4x4 sr5.
    Bilstein 5100 at 2.5 inch OME dakars with the big overload removed 265/75/16 on stock wheels 290,000 miles and counting
    I'm not trying to be a dick or assume that you don't know what your doing but, is the nut that turns hard a nylock nut. They go on about two threads then get pretty tight feeling. There should be a shoulder to put a wrench or crescent onto the shaft to hold as a backup while you crank down the nylock nut. Post a pic and let us look.
    Good luck on the fuse part. I'm no help there.
    Jojee117 likes this.
  3. Mar 23, 2021 at 9:05 AM
    jconn47
    Jordan
    No man I appreciate it. I was an jet engine troop in the air force for a while so I hope I'm just not being an idiot, though anything is on the table. But it's definitely going on extremely hard. Every video I watched they didn't put near the amount of force I was to tighten it down. I'll take a picture when I get home and hopefully I just need to spend more time in the gym. Best solution
  4. Mar 23, 2021 at 9:24 AM
    dustinJ
    dustinJ Taco abuser
    Dustin
    Amarillo tx
    Lol. If you worked on jet engines I'm sure you're just fine. Could be one of those weird deals where they put the wrong nuts in. Weird though that they can't find them at the parts store I can't imagine it being some oddball thread. Were they looking at metric or sae? I would imagine its metric.
  5. Mar 23, 2021 at 9:33 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Suspect the nut doesn't match the threads on the stud. Check both SAE and Metrics. Might consider calling Bilsten to confirm the threads.
    All the other stuff seems to be coincidence.
    Just tackle one at a time. Run diagnostics first, selectively fire the part cannon.
  6. Mar 23, 2021 at 10:43 AM
    jconn47
    Jordan
    You never know! That's why I posted here to see if I was just missing something dumb. Yeah we ran both metric and saw just to be sure. They were just as stumped as me.
    I'll be calling them tonight and will definitely let y'all know. At least I'm getting up close and personal with the truck haha
  7. Mar 23, 2021 at 10:57 AM
    MAG GRY TACO15
    MAG GRY TACO15 Well-Known Member
    Alan
    GA
    '15 TRD Off-Road
    Same crap everyone else got
    Does the nut that came off the rear shocks you removed fit the new ones?
  8. Mar 23, 2021 at 10:58 AM
    jconn47
    Jordan
    No it's much bigger. I think the one I took off was a 14mm and the new one is a 17? Or 19? I can't remember off the top of my head.
  9. Mar 23, 2021 at 11:08 AM
    MAG GRY TACO15
    Alan
    GA
    '15 TRD Off-Road
    I'd just take my shock into home depot and start fitting nuts til I found the right pitch so I'd know what i'm working with.
    Silentshredr and Jojee117 like this.
  10. Mar 23, 2021 at 12:07 PM
    JeffBoyardee
    JeffBoyardee Well-Known Member
    Jeff
    Seminole, FL
    2011 TRD Off-Road Tacoma DCSB
    Could it be a deformed thread style locknut?
    Silentshredr likes this.
  11. Mar 23, 2021 at 12:42 PM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    As for the IG1 #2 fuse issue, do you have any aftermarket mods that would require tapping into a power source? (lights, alarm..etc..) That fuse powers alot of circuits @Jimmyh @caribe makaira . I would start by checking out for any corrosion to the trailer towing socket.
  12. Mar 23, 2021 at 12:43 PM
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
  13. Mar 23, 2021 at 1:20 PM
    Knute
    Those are terrible lock nuts. Yes, they work....1 time. Then you need to replace the nut and the stud because the threads are ruined.
    Nylock type are magnitudes better.
  14. Mar 23, 2021 at 3:46 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    The stem has a allen wrench hole in it to hold while tightening the nut.
  15. Mar 23, 2021 at 4:35 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Loads for the IG1 NO2 Fuse see below. The most likely suspect is usually the Trailer towing connection.
    TnShooter likes this.
  16. Apr 1, 2021 at 12:20 PM
    jconn47
    Jordan
    Sorry its taken me so long to get back. Life can be crazy. For those of you that would like an update the following night the truck died while driving. I didnt have the time to mess with it so I took it to someone on our trailer and he found there was a short to the AC unit that was blowing the fuses and not allowing anything to recharge. While I was there I had him look at the shocks and he was just as confused as I was. His thoughts were that somehow they didnt get finished in the machining process. Ran down them with a dye that was very close after measuring the threads and they worked like a charm. Got them all installed now and life's much better.
    sparkystaco likes this.
