What aftermarket fogs work with OEM harness?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kodachrome, Sep 30, 2011.
  1. Sep 30, 2011 at 10:48 AM
    Kodachrome
    Kodachrome [OP] Well-Known Member
    Western Colorado
    2005 Taco, 2024 Audi SQ8 ETron
    TRD S/C, URD...Stuff
    I have an Aluminess front bumper on order for my 05 access cab Tacoma, I want to install fog lights, would prefer the stock ones but Aluminess says they won't work in the new bumper, suggested PIAA 510's or 540's.
    But from what I have been reading, people are not able to use the stock harness for the OEM lights on the PIAA set without blowing relays. I just need new fog position driving lights, not airport runway lights, so is there another option out there that I can use with my stock harness and dash switch, not need to adapt the aftermarket one?
  2. Sep 30, 2011 at 10:53 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    FWIW, the factory harness will not plug into PIAA 510's or 540's, you'd have to splice wires since they aren't compatible. You can use the stock switch with PIAA lights though and the rest of the PIAA wiring kit is fairly easy to install. It comes with a relay and plenty of wire to get the job done, all you'd have to do is connect to the factory switch instead of the PIAA switch. So basically you'd either have to cut the factory fog light harness and mate it to the PIAA lights or cut the PIAA wires and mate them to the factory switch.
  3. Sep 30, 2011 at 11:44 AM
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Ventura, CA
    2022 Toyota Tacoma SR5 DCSB 4x4
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    I have my hids connected into the stock fog light wires. Just had to cut off the plugs and strip them.
  4. Sep 30, 2011 at 5:37 PM
    Pugga
    Massachusetts
    Your HID's have less draw than the stock fogs. The PIAA's have quite a bit more so there's a risk of blowing fuses or the relay since they weren't designed for that kind of load.
