What aftermarket gauges are more important with your TRD Supercharger?!?!
Discussion in 'Performance and Tuning' started by novanut21, Aug 31, 2010.
Which 2 gauges would you use to monitor your engine after being boosted?
Poll closed Sep 30, 2010.
  1. Boost/Air Fuel Ratio
    16 vote(s)
    59.3%
  2. Boost/Fuel Pressure
    3 vote(s)
    11.1%
  3. Boost/Oil Pressure
    5 vote(s)
    18.5%
  4. Air Fuel Ratio/Fuel Pressure
    0 vote(s)
    0.0%
  5. Fuel Pressure/Oil Pressure
    0 vote(s)
    0.0%
  6. Air Fuel Ratio/Oil Pressure
    3 vote(s)
    11.1%
  1. Aug 31, 2010 at 11:07 AM
    novanut21
    novanut21 [OP] Well-Known Member
    Brent
    North Central,WV
    2009 TRD SPORT
    AFE CAI, Magnaflow cat-back, TRD S/C, TRD Quickshifter, URD Fuel Pump Kit, Wet Okoles Front&Rear, WeatherTech Mats, Sockmonkey Decals, Satoshi grille, JBA "shorty" headers, URD Y-Pipe, TTC Oil Catch Can, Lotek Dual Apillar gauge pod w/ Autometer Phantom II AFR & Vac/Boost, URD Pulley, HID Retrofit.
    I recently had the trd supercharger installed on my 09 trd sport double cab.:D I'm looking into getting the apillar dual gauge pod so i can monitor the engine. What gauges do you all have? And which do you feel is more important to keep tabs on?
  2. Aug 31, 2010 at 11:59 AM
    Super Werty
    Super Werty Sleeper 4x4
    Arizona
    07 TRD Tacoma
    air and fuel
    You cant really narrow it down to two, but air/fuel, fuel pressure, and oil pressure are probably the most important. but that doesnt mean temp and boost gauges are a waste.
    if I had to pic two from that list it would be AFR and boost, which is what I have.
  3. Aug 31, 2010 at 12:08 PM
    xroller
    xroller Blowin by em sideways
    Ramon
    Albuquerque New Mexico
    2006 Toyota Tacoma Xrunner Speedway Blue
    1 hp mod
    To be honest one of the most important is the AFR gauge..... Lets you know how your engine is running and actually can't be tuned without it. It is critical to have this gauge..... the other two that super werty mentioned are critical as well but the main one is an AFR gauge..... I have afr and boost. I really would feel more comfortable if I had the 3 that werty mentioned.... that way I can literally know how my truck is doing and if i'm risking any damage. Boost isn't very critical since all it does read is vacuum.... Not really all that critical but nice to have so you know if you are getting the maximum power output. I have a brand new boost gauge for sale if you are interested though.
  4. Aug 31, 2010 at 12:11 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    definitely AFR and boost. Then oil pressure after those. I hate how my truck doesn't have an oil pressure gauge.
  5. Aug 31, 2010 at 12:12 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    I want to get boost and AFR, but idk any shop that will weld a bung on my headers.
  6. Aug 31, 2010 at 12:21 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Don't buy an AFR guage unless its a true wideband guage. The narrowband AFR guages are basically a light show and not worth the money.
    http://www.plxdevices.com/wideband.html
    I had a turbo accord before my tacoma. I ran an EGT (exhaust gas temp), oil pressure, and boost guage on my a-pillar. I had a seperate PLX wideband readout mounted by my radio which gave me a digital reading of my actual air/fuel ratio.
    Also get a digital oil pressure guage (one with a sending unit) With the mechanical guages you run the risk of the guage failing and leaving a hot oily mess inside the cab of the truck.
  7. Aug 31, 2010 at 1:07 PM
    novanut21
    Brent
    North Central,WV
    2009 TRD SPORT
    What brand is it? Does it have the map sensor or just the tubing
  8. Aug 31, 2010 at 1:24 PM
    novanut21
    Brent
    North Central,WV
    2009 TRD SPORT
    This is what im looking at getting for a boost gauge. I'm going to opt for the wiring harness and map sensor I feel it will be more accurate. Also they have a wideband air/fuel also in the phantom II but they havent released it yet to the public. (plus I think they look sick at night!)[​IMG][​IMG]:headbang:
  9. Aug 31, 2010 at 1:30 PM
    novanut21
    Brent
    North Central,WV
    2009 TRD SPORT
    Me too
  10. Aug 31, 2010 at 7:42 PM
    novanut21
    Brent
    North Central,WV
    2009 TRD SPORT
    Why would you need pyro? I thought that was only used on turbo setups? What benifits would come from using it with a supercharger?
  11. Sep 5, 2010 at 7:27 PM
    roxspin72
    roxspin72 Enjoying my addiction
    NC
    Speedway Blue, TRD, 4X4,
    Oh Yeah!!!
    Sorry to thread jack, but is there a way to run a guage utilizing the AFR numbers being logged by the APR X-1? I know I can get AFR readings off a live DATA Log run. Wondering if there is a way for constant display, rather than pulling headers off and welding in a wide band sensor and all that mess...
    let me know, Thanks.
  12. Sep 5, 2010 at 9:03 PM
    ktmrider
    Junk
    I was just browsing APRs website and on there FAQs it said this
    I have no Idea but it says so. Also I sent you a PM
  13. Sep 5, 2010 at 9:11 PM
    rcbs204
    rcbs204 Well-Known Member Vendor
    When i had my TRD S/C the two most important gauges i had were AFR and EGT. They will tell you immediately if there are any issues.
  14. Sep 5, 2010 at 10:22 PM
    roxspin72
    NC
    Oh Yeah!!!
    Yes I seen that.. But need to know how this compares to wideband. I sold mine that I had on the old old headers...
  15. Sep 6, 2010 at 10:51 AM
    XrunnIT
    XrunnIT Well-Known Member
    Austin, TX
    1GR-GZE X-Runner
    Built Motor by LC Engineering Boosted by TRD
    I'm running a boost/vac and fuel pressure in my truck at the moment.
    You can use a wideband gauge with the X-1. I forget which pins to connect into, but you can do that without welding in a dedicated sensor. It will pull the data being seen by the OEM WRAF sensors.
  16. Sep 6, 2010 at 2:01 PM
    novanut21
    Brent
    North Central,WV
    2009 TRD SPORT
    Thanks for clearing that up for me. And I to would gladly pay the extra $$$ for forged internals.
  17. Sep 6, 2010 at 2:46 PM
    roxspin72
    NC
    Oh Yeah!!!
    Cool, good to know. Im definately going to be doing the URD Flex POD with Boost, and AFR Gauge..
  18. Sep 24, 2010 at 6:11 PM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    Sorted by importance with supercharger;
    1, Air to Fuel Ratio
    2, Oil pressure
    3, Boost
    Honestly the ONLY gauge you really need with supercharger is AFR gauge. Boost gauge is useless, because with supercharger you cannot over boost, since boost is determined by the diameter of the supercharger pulley. Turbo is a completely different story...
  19. Oct 25, 2021 at 10:39 AM
    Mcycletech
    Mcycletech Member
    2008 Tacoma 2010 Tacom
    2008 Tc upper. Icon ext travel with R. nex4200. 2010 TC upper and lower. King adjustable and dual bypass. King rear adjustable with hydraulic bump stop. TRD SC. Pioneer nav amp and sub Premium sound system. Hid on n so on
    I know this is a really old thread just wondering if anyone has tried the Banks datamonster or super gauge. From a quick glance it looks like it allows you to add multiple sensors and displays just about anything that one would want to monitor. No need for multiple gauges unless you just like the looks of them. Anyone have on installed on their Tacoma ?
