What aftermarket wheel and tire are you running on your Tacoma?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Hold The Gauc, Jun 10, 2020.
  1. Jun 11, 2020 at 6:43 AM
    Hold The Gauc
    Hold The Gauc [OP] Before we get started, does anyone wanna get out?
    I will never financially recover from this
    looks good, any lift?
  2. Jun 11, 2020 at 7:04 AM
    madtacoma
    madtacoma Member
    pittsburgh
    2017 trd sport
    Fuel Boosts with zero offset with 285/70/1720200609_171606 (2).jpg
    mean_green likes this.
  3. Jun 11, 2020 at 7:41 AM
    mattyb227
    mattyb227 Member
    2018 Tacoma SR 2.7
    Preesh! No lift.
  4. Jun 11, 2020 at 8:39 AM
    projghost
    projghost Well-Known Member
    Joey
    Portland OR
    2019 TRD OR DCLB
    Bilstein 5100's +2" front Rear Wheeler AAL +1.5" Rear Dirt King Balljoint UCA's Method 701 Wheels BFG K02 C4 Hybrid Front Bumper RCI Skid Plate Baja Designs S2 Sport Ditch Lights Baja Designs Squadron Sport Fog Lights Cali Raised DItch Light Brackets CVT Mt Bachelor RTT CBI Overland Bars Cali Raised Rock Sliders Prinsu Cab Rack TheTacoGarage TRD pro grill + raptor lights CBI/prinsu Maxtrax and Rotopax mounts Victory 4x4 Bed Stiffeners ActionTrax boards 2g Rotopax (Gas/Water) Ironman 4x4 Compressor Agency 6 Recovery Hitch Blacked out Emblems
    701's with KO2's
    Boss hoss and Superhulk LB like this.
  5. Jun 11, 2020 at 9:14 PM
    Hatfieco05
    Hatfieco05 Well-Known Member
    Portland, OR
    2020 DCLB TRD Off-Road Premium
    Bilstein 5100s front on 4th clip and 1” rear block with 5100 shocks.
    71tattooguy likes this.
  6. Jun 11, 2020 at 9:15 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    Extra Guac Please
  7. Jun 11, 2020 at 9:26 PM
    BigL09Guy
    BigL09Guy Well-Known Member
    Portland OR
    2020 Tacoma OR
    6112/5160 on 5/6 Falken Wildpeak 275/70/17
  8. Jun 11, 2020 at 10:29 PM
    Invid
    Invid Well-Known Member
    New Braunfels, Texas
    2016 Tacoma Limited
    275/65/18 Wildpeaks on KMC Addict 2 with 6112/5160 at 4/5.
    Boss hoss likes this.
  9. Jun 12, 2020 at 12:12 AM
    WZ00R2
    WZ00R2 Well-Known Member
    TN
    2020 Cement OR
    6112/5160, Deaver U402, 255/80r17, SCS BR6
    255/80r17 Nitto Ridge Grapplers with SCS BR6s and 6112s on the 5th setting.
    Depending on the height you choose for your 6112s, the 265s may look a bit small.
  10. Jun 12, 2020 at 4:26 AM
    MW20Taco
    MW20Taco Well-Known Member
    Mykle
    2020 TRD OR Premium
    What is your wheel offset and BS? 2” lift. LRE? Any rubbing ?
  11. Jun 12, 2020 at 4:34 AM
    MW20Taco
    Mykle
    2020 TRD OR Premium
    255/80-17 huh?
    How do you like the ride? 8.5” wheel? It sits taller by like 1/2” over the 285/70 but offers less rubbing ?
    setting 5 all around?
    Anything in the rear?
    mcallahan 98 taco likes this.
  12. Jun 12, 2020 at 4:40 AM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    '06 and '18 TRD OR 4x4 Access Cab
    Method 712 and Cooper Evolution MT
  13. Jun 12, 2020 at 8:09 AM
    kevlar3324
    kevlar3324 New Member
    Kevin
    2019 Tacoma TRD Off Road Cavalry Blue
    Method 702's, BFG KO2's 285/70/R17, Fox 2.5's front, 2.0's rear, Camburg Performance Uniball UCA's with a 3" lift. However, some pretty good rub (sharp turns) when the truck has gear/people. Dropping down to 275/70/R17.
    Daddy_Firebird and projghost like this.
  14. Jun 12, 2020 at 9:33 AM
    WZ00R2
    TN
    2020 Cement OR
    I love this setup. It rides much better than stock, no rubbing at all and I still get 19mpgs.
    I have both of the 6112s on the fifth setting with a spacer on the driver side. The rear has a 1.5” AAL.
    MW20Taco[QUOTED] likes this.
  15. Jun 12, 2020 at 9:38 AM
    #35
    SoCal TacoOR
    SoCal TacoOR Life at Redline
    Kommie Kali
    17 DCSB TRD OR Super White
    DCD17036-3798-4708-8344-5559EE816C62.jpg 07BE8681-ACC4-4C59-A504-168D6433137B.jpg Method 315s zero offset + Wildpeaks
    Eyez_on, Boss hoss, joe25rs and 2 others like this.
  16. Jun 12, 2020 at 10:04 AM
    #36
    MW20Taco
    Mykle
    2020 TRD OR Premium
    I will essentially have the same set up
    6112/5160 setting 5/6
    1.5 AAL
    What about UCAs? I ordered SPC just to be safe.
    17x8.5 wheel -12mm off set and 4.28BS.
    The only thing I need to pin down are tires.
    I was planning on a 285/70-17 Duratrac or Nitto RG.
    but taking up more wheel well space, sitting a bit higher and better snow traction (pizza cutters) might change my mind.
    how is the ride? Do they drift at all. The make KM3 in that size too.
  17. Jun 12, 2020 at 11:05 AM
    #37
    ClintS
    ClintS Well-Known Member
    San Diego
    • Eicbach pro lift kit, 2-2.5 inch lift
    • ProComp 17x8.5 wheels w/4.75” backspace
    • BFGoodrich All Terrain T/A KO2 DT LT285/70 R17
    Wheels were the least expensive that were available and would last through some rough 4 wheeling. They’re wheels and looks won’t change the performance of the truck. KO2 were not my first choice – however the Falken Wildpeak A/T3W were not going to be available for a month.
  18. Jun 12, 2020 at 12:25 PM
    #38
    johnnyjunk
    johnnyjunk Lurk more, learn more.
    The Great PNW
    2016 Tacoma TRD Off-Road
    17x8.5 Ray10s
    295/70/17 Cooper STT Pro
  19. Jun 12, 2020 at 6:28 PM
    #39
    WZ00R2
    TN
    2020 Cement OR
    I kept the factory UCAs as mine aligned fine and drives prefect. I had no reason to waste the time with the money installing new UCAs.
    The tires ride perfect. I’m not sure what you mean when you ask if they drift but with these tires and suspension set up it’s far more responsive than it was from the factory. 255s on a 8.5” wheel really are not as skinny as people make them out to be. They are about the same width as a factory off-road tires, just a bit taller.
  20. Jun 12, 2020 at 6:39 PM
    #40
    Russty__
    Russty__ Well-Known Member
    Russ
    Maryland
    Sold-‘16 DCSB Taco Sold-‘21 Power Wagon Now-‘20 Gx460
    1552 turbomac HD’s with Falken Wildpeaks A/T 285/70/17
    VietxLe, TurdTaco64 and MurkedYota like this.
