What all do I need?
Discussion in 'Suspension' started by FLtaco, Dec 7, 2010.
  1. Dec 7, 2010 at 2:29 PM
    FLtaco
    FLtaco [OP] Well-Known Member
    Nick
    Cocoa beach, fl
    05 prerunner dc
    Painted stock wheels, bfg km2s, 5100s front and rear, tc spindles, add a leaf, 3" block, debaged, flowmaster exhaust, 2nd air filter removed, wheel spacers and k&n air filter
    I'm getting 5100s all around for Christmas And setting front to max. I have a 3 inch spacer suspension lift. Will the add a leaf that came with the previous lift level it or no? If not will I be nose high or rear high? And do I need anything else for this I'm doing work myself
  2. Dec 7, 2010 at 2:47 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    You will have to ditch the 3" spacer to run the 5100's at anything but 0.
    I recommend setting the 5100's at 2.5", and pair that with a 1.5" add-a-leaf to level.
    You will need a spring compressor to do the work yourself, and air tools make the job much easier.
    You can either rent a spring compressor from your local auto parts store, or bring the whole shock assemblies by your local shop and have them disassemble and reassemble them.
  3. Dec 7, 2010 at 2:51 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    What size is your AAL you have in the rear right now? 1.5"-2"? If your are level right now and set the 5100's at 2.5"s of lift, you rear might be a tad higher since you have a 3" spacer lift right now and will be dropping the front by 1/2 and inch.
  4. Dec 8, 2010 at 3:18 AM
    FLtaco
    Nick
    Cocoa beach, fl
    05 prerunner dc
    I'm not sure what add a leaf is kit before never told me. It sits pretty level so I assume I'll have some rake then. What should I do to level out front more than.
    Thanks for info gentlemen
