What am I doing wrong in 4-wheel on the beach?
Discussion in 'Off-Roading & Trails' started by edisme, Nov 5, 2020.
  1. Nov 5, 2020 at 1:40 PM
    edisme
    edisme [OP] New Member
    Wilmington, NC
    White tacoma 2016 4x4 trd off road
    On beach soft sand in 4x4 hi with tra off. But when I started to leave my tacoma violently started to buck in the soft sand. Finally stopped put it in 4x4 lo and it was ok.
    Only had the bucking 2 times in the past and not sure why. Can anyone shed light on it? Thank you
    Edisme.
  2. Nov 5, 2020 at 1:45 PM
    rocky_mountain_dave
    rocky_mountain_dave Well-Known Member
    David
    2009 Tacoma Access Cab 4x4 4cyl 5spd
    There was not enough traction to accelerate away at the speed you were trying to go in 4hi. 4lo allows much more control/ finesse which can be a big advantage in this situation.
    If 4lo doesn't cut it, your next option is to air down to around 20 psi and you should be able to drive away no problem. If you drive on the beach often, I highly recommend buying a high quality air compressor (around $100) to air back up if you have to air down.
    $yoda$ and doublethebass like this.
  3. Nov 5, 2020 at 1:46 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    Too much skinny pedal for the amount of traction you had. Nothing is wrong with the truck.
    NMroamer likes this.
  4. Nov 5, 2020 at 1:50 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Most beach ramps in NC have signs
    AIR
    DOWN
    12psi floats on sand
    keygrip and shift957 like this.
  5. Dec 26, 2020 at 5:23 PM
    keygrip
    keygrip Well-Known Member
    Greg
    Catskill Mountains, NY
    2020 Tacoma TRD offroad, DCLB, magnetic grey metallic
    2" Fox 2.5 performance elite dsc front lift, 33" KM3 (summer),265/75 r16 KO2s (winter), led bed lights, remote start, vhf/uhf radio, trailer brake controller, Jericho mid rise cap, US Offroad winch cradle, Warn Zeon 10k winch, Martin Offroad roof rack, Deaver stage 2 leafs, u bolt flip, Duro bumps front/rear, Overland Tailor tune, Cali-raised trail rock sliders, Cali-raised full skid plates, SPC UCAs.
    I second the 12psi. Believe it or not. Out on Cape Cod 12psi is required by regulations.
    POSTacoMike likes this.
  6. Dec 26, 2020 at 5:26 PM
    AI Surf Fisher
    AI Surf Fisher Well-Known Member
    Richard
    Gaithersburg, MD
    08 Tacoma DC 4x4 TRD Off-road, 21 AG 4Runner Trail Edition
    Leer Cap, thule racks, 5100's, Yokahoma Geolandar 265/75/16
    Air down or dig out. Everyone gets stuck eventually no matter what you do. But I can guarantee you will definitely get stuck if you don't
  7. Dec 28, 2020 at 10:07 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Tire pressure.
    20psi is better than 35, but you can easily go much lower, like 10-15 in the soft sand.
    Can even go lower if you really have to.
    It's amazing what can happen if you get stuck in the sand and just lower the pressure by a few pounds.
  8. Dec 28, 2020 at 10:11 AM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    10psi rear and 12 psi front lets me play in the sand without 4x4. I get stuck, but it's made me a lot smarter as a driver.
  9. Dec 28, 2020 at 10:15 AM
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    Air down, 2nd gear start.
  10. Dec 28, 2020 at 10:28 AM
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    I don’t think I’m brave enough to go to 10psi without bead locks. 15 works good for me.
  11. Dec 28, 2020 at 10:55 AM
    jbrandt
    Justin
    I wouldn't drive around with 10 psi, but you can go that low to get out of a bind, then air back up.
    I knew a guy that would air down to 8psi all the time. no beadlocks. I remember he did eventually blow a bead, but he was in a pretty tight bind, crossed up in the dunes
  12. Dec 28, 2020 at 11:19 AM
    Sterling_vH111
    Sterling
    socal
    For sure a worry. I’ve never blown a bead and have driven pretty hard — up to ~45mph, whoops, and sliding around at full throttle in the sand.
