What am I forgetting (Lift Kit, Etc..)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by brownbagindustries, Aug 20, 2019.
  1. Aug 20, 2019 at 2:36 PM
    brownbagindustries
    brownbagindustries [OP] Active Member
    Canty
    Baltimore, MD
    ‘14 MGM Tacoma
    Toytec 3” Lift JBA UCA’s Fuel Vector 16x8 MT Baja ATZ 285/75R16 TRD Pro Grill
    I’m getting ready to order and install a lift kit and wheels for my new to me 2015 AC V6 SR5.
    I’ve done a ton of reading over the last month on what to avoid (spacer lifts and the such). Looking to see if I’m missing anything. I come from a background of going the opposite direction and lowering cars.
    Parts List:
    Toytec 3” Bilstein 5100 Coilover Kit with the AAL
    JBA UCA’s
    Fuel Vector 16x8 +1mm wheels
    108 to 106 Hubcentric Rings
    New TPMS sensors
    BFG KO2 285/75/16’s
    Everything other than that will be cosmetic.
  2. Aug 20, 2019 at 2:40 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Form or function?
  3. Aug 20, 2019 at 2:44 PM
    brownbagindustries
    Canty
    Baltimore, MD
    ‘14 MGM Tacoma
    Little bit of both, drive on the beach a lot in Assateague to go surfing and some light trails when we go camping and hunting.
  4. Aug 20, 2019 at 2:46 PM
    geekhouse23
    New bumpstops front and rear, extended brake lines in the rear.
    I would do the rear diff breather mod.
    ECGS bushing mod.
    CMC.
    I would highly recommend a new leaf pack over the AAL. Toyota leafs are junk and belong in the dumpster.
  5. Aug 20, 2019 at 2:47 PM
    tcjacado
    tcjacado Well-Known Member
    Do you have a new center pin for the leaf pack to put the aal in?
  6. Aug 20, 2019 at 2:50 PM
    Muddinfun
    Muddinfun Well-Known Member
    Mark the alignment cams. Then loosen them and see if they will turn. If they're seized, you'll need to deal with that before you can get it aligned.
