What am I missing
Discussion in 'Audio & Video' started by primer, Apr 25, 2011.
  1. Apr 25, 2011 at 10:04 AM
    primer
    primer [OP] Well-Known Member
    T
    OK
    06 SS Mica AC 4x4 TRD Off-Road
    (Mostly) debadged, Homelink mirror, Elevated rear diff breather, LED illuminated 4x4 switch, Color matched grill surround, Bed cover, Ivan Stewart wheels, Bridgestone 265/75 Dueler AT Revo 2 tires
    Planning on a Kenwood dbl DIN NAV unit. 7180 or 9980
    Putting this in an 06 AC.
    I know I need th following:
    Dash kit
    Wire harness
    Steering wheel control module
    Reverse camera
    Anything else I need to plan on?
    Is it worth it to get one of the kenwood cameras oR is something cheaper just as good?
    Thanks
    TL
  2. Apr 25, 2011 at 10:07 AM
    mike686
    mike686 Well-Known Member
    Michael
    Waldorf
    10 Tacoma TRD Off Road
    See Build Thread
    Ipod interface kit? Idk what you wanna do but that's one thing I can think of
  3. Apr 25, 2011 at 2:21 PM
    primer
    T
    OK
    Good point. I've added that to my list.
    Thanks
  4. Apr 25, 2011 at 2:25 PM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    If ordering, look at Crutchfields, they include the dash kit, and harness as well as some instructions and tips for install. I used a cheap camera with my Pioneer HU and am happy with performance. Also, check your HU, as it may have a iPod hook-up, mine does.
  5. Apr 25, 2011 at 2:26 PM
    stmpjmpr
    stmpjmpr Well-Known Member
    Jimmy
    So Orange County, Ca
    2014 Tacoma Sport MGM 4X4
    what camera did u use and where u get it?
  6. Apr 25, 2011 at 2:29 PM
    DevL
    DevL Well-Known Member
    The double sided tape for the camera and voice activation remotes is too thick... get your own. Use your own clips instead of the clips provided with your trim kit. Will you want a satallite radio feature? If you intend to add an amp later it is far easier to add your interconnect cables and remote turn on wore NOW and run them to about where your amp will beso you dont have to dig the radio back out to install them.
  7. Apr 25, 2011 at 2:30 PM
    t4daddy
    North Alabama
    I'm not even sure of brand, I ordered it from Amazon for less than $30.00 shipped.
  8. Apr 25, 2011 at 2:35 PM
    cc350
    cc350 Retired Member
    Also get Crutchfields speaker connectors, makes it easy/ plug and play. Dynamat! Good SPEAKERS!!
  9. Apr 25, 2011 at 7:01 PM
    primer
    T
    OK
    Thanks all.
    I'll check and see if the units I'm considering have one included. I definitely want it set up from the start.
    Interested in the cheap camera. Let me know if you know the brand or anything.
    I've installed head units before (though never dbl DIN) but never an amp. I like the idea of having the wires hooked up from the start. Is there a good DIY guide for this?
    Speakers to follow. I'd love to do some deadening. The sad thing is I tend to want to do things all the way. That means ripping the interior out and going crazy. This is my daily driver, I'm trying to resist the temptation.
    TL
