What amp to use
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Johnm2491, Sep 23, 2015.
  1. Sep 23, 2015 at 4:07 PM
    Johnm2491
    Johnm2491 [OP] Well-Known Member
    2024 TRD Off Road DCSB
    Frigg-off Barb
    What amp should I use for my JL audio stealth box? Rockford fosgate punch P400x2? Or PG tantrum 400.4? Also what gauge wire kit should I use? Also I have the JBL audio factory in the truck if that matters. Any help you'll be awesome. THANKS!
  2. Sep 23, 2015 at 7:13 PM
    buickv6
    buickv6 Member
    Shane
    Canada
    2005 DC off-road, yes it's a US truck
    I used the jl slash 600v3, I have a pic somewhere here under my user name
  3. Sep 23, 2015 at 7:28 PM
    Johnm2491
    Frigg-off Barb
    What do those cost? The guy at the shop said to use the JX 250/1. But I don't wanna buy a third amp if one of the two I have would work.
  4. Sep 24, 2015 at 5:19 PM
    buickv6
    buickv6 Member
    Shane
    Canada
    Neither of your amps will work unless you rewire the box so it has 2 channels instead of the single channel they come with. If you do that you could use your PG which is considerably better than the jl250/1. Ideally you need a single channel or mono amp to deliver 600w as each sub is 300w, you can go 75%-150% of this value. You should be looking for a 2 ohm amp to deliver from 450w-900w, that being said the jl250/1 is too small, however the jl500/1 would be a better match
  5. Sep 24, 2015 at 5:37 PM
    Johnm2491
    Frigg-off Barb
    Yeah I was looking at that amp. I saw someone with the stealth box with the 500/1 amp. Also should I have 4 or 8 gauge wire and what's the difference with gauges? I would like to know more about these things.
