What amplifier for my setup?
Discussion in 'Audio & Video' started by Evil Monkey, Feb 9, 2010.
  1. Feb 9, 2010 at 8:53 PM
    Evil Monkey
    Evil Monkey [OP] There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    I'm replacing the stock head unit/JL Audio Cleansweep with a new headunit. I want to get an amp appropriate for my items. I was thinking about a Polk Audio pa1100.5 5 channel amp to save space and make wiring easier.
    Does anyone know if the speakers can be run at 4 ohms with the sub at 2 ohms? Or is that not recommended (should they all be at the same ohm rating)? Should I just go with a 4 channel and a mono amp for the sub.
    Here are the components I have so far:
    Replacement headunit:
    Pioneer Premier DEH-P880PRS (not installed yet)
    Currently installed:
    Stock radio with JL Audio Cleansweep
    Phoenix Gold Ryval 1000w 4-channel amp
    Front and back wired in parallel on front channel of the amp (2 ohm):
    Polk Audio db691 6" x 9" 3-way Car Speakers in the front
    Polk Audio DB651 6-1/2" Coaxial 2-Way in the back doors
    Bridged on the back channels at 8 ohms:
    Image Dynamics ID10D4.v3 dual voice coil subwoofer
  2. Feb 9, 2010 at 9:31 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    The Polk audio amp is quite large so be prepared to give up some space for it. My suggestions would be either a PDX5 or a JL HD 900/5 based on your setup and space constraints that I know we both share. The Alpine being the cheaper option and the JL being the one I own; it's not cheap but it's a fantastic package.
  3. Feb 9, 2010 at 9:32 PM
    ItalynStylion
    Steven
    DFW, Tx.
    And you can run the fronts and rears at different impedances and it's no problem.
  4. Feb 9, 2010 at 10:51 PM
    FurbiesAndBeans
    FurbiesAndBeans Member
    '10 Toyota 4x4 TRD Sport
    For me, i would steer away from 5 channel amps as they can be expensive like the JLs and Alpine ones. Why spend more money for the same quality when it could be had for less?
    If you do decide to go with a 5 channel, then it's fine to run the subwoofer at a lower ohm than the other channels. You can even run, for example, 4 ohm speakers for the front and 2 ohm for the rears, then an 8 ohm sub for the 5th channel lol
    Nice headunit btw ;)
  5. Feb 10, 2010 at 9:08 AM
    Evil Monkey
    Robert
    Escondido, CA
    Wow, that Polk amplifier reallly is a beast. I didn't notice the dimensions. I think I'll go with the Alpine. Thanks for the heads-up.
  6. Feb 10, 2010 at 9:15 AM
    Evil Monkey
    Robert
    Escondido, CA
    Ease of install mostly. I have everything already wired, so a 5-channel amp would be mostly plug-n-play because I wouldn't have to run more wires. The Alpine is available for about $360, so it doesn't seem that expensive to me. I don't know that you'd get much cheaper running a 4-channel amp plus a sub amp.
  7. Feb 10, 2010 at 9:17 AM
    08TRD Sport
    08TRD Sport ROOTIN AROUND
    Joshua
    Augusta, Georgia
    10 5th Gen 4Runner
    I would go with JL audio amps. I love JL
  8. Feb 10, 2010 at 12:09 PM
    tacomarock
    tacomarock Well-Known Member
