What are aquamist kits?
Discussion in 'Performance and Tuning' started by NumNutz, Jul 29, 2009.
  1. Jul 29, 2009 at 8:45 PM
    NumNutz
    NumNutz [OP] One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
  2. Jul 29, 2009 at 8:48 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    for turboes. they can run higher pressures and such
  3. Jul 29, 2009 at 8:56 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The main function of these systems is to suppress detonation caused by high temperature and pressure developed within the combustion chamber when the effective compression ratio has been taken beyond the auto-ignition point by either a turbo or a supercharger.
  4. Jul 29, 2009 at 9:25 PM
    XC4ME
    XC4ME Well-Known Member
    Litchfield Park, Arizona
    05 Tacoma DC TRD Sport
    Chris you sound like a Doctor. "Turbo problems? Add the Aquamist and call me in the morning." :)
  5. Jul 29, 2009 at 9:50 PM
    matthew5olson
    matthew5olson Well-Known Member
    matthew
    pittsburgh, PA
    04 ext cab 3.4L 5spd 4x4 sr5
    K&N cold air intake, doug thorley headers, rear sensor simulator, flowmaster 40 series, magnecor plug wires, Royal Purple synthetic gear lube, airaid throttle body spacer, Hyperground system, flex-a-lite elec fan.
    They make water injection systems for N/A setups. running a cooler engine is good for any engine (I should think) and If you do a 50/50 water methanol mix you get the same cooling effect plus the added benefit of extra fuel (power). One of these is my next mod. I am going to tune it to help with fuel economy. I haave seen it advertised as a NOS sort of thing also. You push a button and it adds a bunch of this water methanol mixture for a lot of extra power. This is actually how these started. WWII fighter jets needed some extra umph for take-off
    Please feel free to correct any wrong info on this post. I have never used one of these before only done research on them with an intent to buy.
  6. Jul 29, 2009 at 9:52 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Haha!! All I know is, I don't need one of those!!:D
  7. Jul 30, 2009 at 5:21 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    IDK about the NOS sort of effect...It creates a "higher octane" mixture and cools engine temps...but in a non tuned engine the effects will be minimal...In a blown engine or an engine with significant timing your mpg gains might be non-existant....plus I think the systems have to be set to only spray under heavy loading or even WOT....
  8. Jul 30, 2009 at 6:10 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    X2. Water has the ability to absorb large amounts of heat with little temperature change. On a NA engine, if the intake charge temp is ambient, not alot (if any) gain can be had with a Water/meth injection system. Certainly no "Nos" effect. No2 gives a gain as its intruducing 2 more o2 molecules into the cumbustion chamber, as well as cooling it off. Personally, I think using an water/meth injection on a DD that is not Force Inducted could be hurtfull to the engine. If the water doesnt fully atomize, or condenses in the intake air, you could have some issues.
  9. Jul 30, 2009 at 9:29 AM
    beastlytaco
    Ian
    08 Access Cab SR5
    yeah like it getting into your engine and hydrolocking it
