What are my options for a fuel injector upgrade-- 2.4 L engine
Discussion in '1st Gen. Tacomas (1995-2004)' started by austi012, Aug 31, 2020.
  1. Aug 31, 2020 at 4:20 AM
    austi012
    austi012 [OP] Active Member
    Thaddeus
    1997 Tacoma
    Hi,
    I figure my stock injectors, at 23 years old and 182k miles, might be something I'd like to replace.
    I understand the originals have one spray hole and are kind of crude.
    I'd like to do a straight plug-n-play swap, same flow rate, but get something better. I see a lot of sketchy looking hype on Fleabay and so forth, and I don't want to drop coin on something that wll run the same or worse than what I have.
    Recommendations?
  2. Aug 31, 2020 at 4:24 AM
    LoveableWerewolf
    LoveableWerewolf Well-Known Member
    Nashville
    2014 5 lug, 1989 mighty max
    4 runner seats, storage cubbies
    Rock Auto with tacomaworld discount.
    Denso I've heard is best for least problems
  3. Aug 31, 2020 at 4:46 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Take injectors out and manually clean or have them serviced professionally.
    You can't get better injectors than what came from factory and aftermarkets melt down fast.:mad:
    Save yourself the trouble of redesigning the wheel.:D
    The wheel is round, it rolls, we good:thumbsup:
    phoenix ray likes this.
  4. Aug 31, 2020 at 6:53 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    I went with the Intermotor injectors from RockAuto. They appear to be exactly the same as the OEMS I took out, minus the cracks.
    Be careful though - there are counterfeit injectors on the market and they cause headaches. Don't cheap out.
    LoveableWerewolf, CS_AR and Abeyancer like this.
  5. Aug 31, 2020 at 7:03 AM
    austi012
    Thaddeus
    1997 Tacoma
  6. Aug 31, 2020 at 7:21 AM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    They're knock offs. Chinesium counterfeits... I can tell you from personal experience that ANY seller selling "new" or "remanufactured" injectors for less than $50 PER injector, it's gunna be fake.
    Bad things will happen when you install fake injectors. @CS_AR and @Running Board Man can tell you other than myself
  7. Aug 31, 2020 at 7:24 AM
    Abeyancer
    Jimmie
    PNW
    but if you do go that route, I'll take your used OEM ones you take out... I've been looking for a set of used OEM injectors that I can pay to have rebuilt.
    Since you're a 97 you're probably going to have the brown injectors. Cheapest "upgrade" is going to be from rock auto.. use an 01 or 02 and get the pink intermotor injectors
  8. Aug 31, 2020 at 9:17 AM
    Running Board Man
    Running Board Man Well-Known Member
    I would have given you mine had they not fallen on the side of the road somewhere
  9. Aug 31, 2020 at 9:24 AM
    austi012
    Thaddeus
    1997 Tacoma
    I have so many other things I'm doing to this thing, 50 bucks per injector is outta reach for now. I guess I'll just run some Techron through and call it good for now.
    Abeyancer likes this.
  10. Aug 31, 2020 at 9:56 AM
    Abeyancer
    Jimmie
    PNW
    If you're not noticing a misfire definitely do not mess with them. I bought 2 separate sets of knock off injectors (first set I knew were aftermarket. Second set was "labeled" Denso but they were imitations) and ended up having to put my original injectors back in. They had 219k on em and counting
    Running Board Man likes this.
  11. Aug 31, 2020 at 10:04 AM
    Clearwater Bill
    Billy
    Largo Florida
    It's a 2.4 which is reliable but not performance inclined.
    Is it stock and not in need of more fuel?
    Do you have injector leaks, either external or internal?
    Do you have misses and codes?
    No? Leave them alone. There is no 'upgrade' that will matter if they are functioning fine.
    LoveableWerewolf likes this.
  12. Aug 31, 2020 at 10:11 AM
    Running Board Man
    If your injectors are good don't mess with them unless you get quality replacements
  13. Aug 31, 2020 at 5:17 PM
    BikerinBlak909
    BikerinBlak909 Well-Known Member
    SoCal
    96 LT 5 lug
    JD Fab LT kit 3" lift spindles Fox 2.5 x 10" dual rate Deaver F67 SUA, 9" shackles 8.4 prerunner rear end with 4.10 33 AT3 wildpeaks McNeil Fiberglass fenders PRP comp seats Doug Thorley long tube header K&N CAI
  14. Aug 31, 2020 at 5:25 PM
    Wulf
    rock raisin
    You can clean your own injectors primitively for less than $10 and several hours of your time if cost is an issue.
  15. Aug 31, 2020 at 6:34 PM
    Running Board Man
    But it doesn't make them shiny
  16. Aug 31, 2020 at 6:37 PM
    Bishop84
    Bishop84 Well-Known Member
    Injectors on Toyotas are pretty much life time, you don't change them as a maitenance item, they are replaced as they fail.
    As long as there's no codes, there's no reason to change them. Do a clean if you feel like it, change the orings and keep on truckin'
    New injectors are basically a waste of money.
