What are the best u joints for 2008 2wd pre-runner
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AHearing, Sep 12, 2019.
  1. Sep 12, 2019 at 5:35 AM
    AHearing
    AHearing [OP] Member
    Andrew
    2008 white Tacoma Prerunner
    Looking for a good quality u joint and center carrier for a 2008 2wd dbl cab. Where is the best place to order them from. I need cheap but looking for quality too. Any suggestions?
  2. Sep 12, 2019 at 5:57 AM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
  3. Sep 12, 2019 at 6:05 AM
    AHearing
    Andrew
    what is the difference from the kit you recommended and just the u-joint, its a street truck, no off road use. Any thoughts on grease vs non-grease
    Gunshot-6A likes this.
  4. Sep 12, 2019 at 6:06 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Go greasable. Still a high wear and rotation part.
    The "kit" is really just extra / different retaining clips to make sure you find a pair that fits the clip channels. Ill give you a hint, you wanna use the green tinted ones.
    Edit: Our drive shafts are Dana Spicer, so that U-joint kit he posted is pretty much OEM replacement. I just helped @ImMrCrash replace his with the same kit.
    TnShooter likes this.
