What are the hidden costs to adding a winch
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Toywoodsguy82, Aug 7, 2019.
  1. Aug 7, 2019 at 10:16 AM
    Clearwater Bill
    Billy
    Largo Florida
    Something like this is invaluable when there is nothing in cable length to attach too. Assuming the terrain will allow you to put it in by shovel/hand.
    It's amazing the load it will hold.
    I once winched a '68 TravelAll buried to the floor pans in a bog using just a 6" dia version. Of course the winch was a PTO, so no electrical issues.
  2. Aug 7, 2019 at 10:53 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Think the biggest I've ever heard of anyone swapping into a Tacoma was 160A - still not close to running a winch without dipping into the battery reserve. Also, not sure if you can even swap a different alternator into the 3rd gens (more electronic voltage control).
    If you run AGM batteries a voltage booster can be a good idea too.
  3. Aug 7, 2019 at 11:37 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    :hattip:
    I think it worked:thumbsup:
  4. Aug 7, 2019 at 11:42 AM
    Toywoodsguy82
    Toywoodsguy82 [OP] Well-Known Member
    Patrick
    Oregon
    2007 Silver DCSB TRDOR 2017 black crewmax tundra
    Body Armor front and rear bumpers Method 703 Wheels Falken wildpeak AT3’s Ironman Foam Cell Pro kit
    It got it started for sure
    doublethebass and PzTank[QUOTED] like this.
  5. Aug 7, 2019 at 1:19 PM
    computeruser6
    computeruser6 Nuclear Janitor
    Dirk
    Escondido
    2008 Regular Cab Tundra
    King 2.5 coilovers Nitto Exo Grapplers
    No way, check out these alternators (Power Bastards, DC Power Engineering). Yes, you'll use the battery a little no matter what but the battery will not maintain voltage for long under heavy loads. A glass mat or gel type battery may have a little more capacity and will be much better at dealing with discharge cycles but won't let you run a winch for much longer. A second battery can help, but that's a lot of weight to put on that fender sheetmetal. The voltage regulator is a part of the alternator for either generation. Even if no one makes an alternator for the 3.5L specifically a good shop could always modify the stock unit to have a higher output, at least higher RPMs.
  6. Aug 7, 2019 at 1:26 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    This one is bolt in.
    https://sdhqoffroad.com/collections...tacoma-4-0l-270-amp-xp-high-output-alternator
  7. Aug 7, 2019 at 1:33 PM
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    You want a battery that has over 700 CCA, and if spending the money it would be on a good AGM battery. This saves the winch solenoids. I learned this the hard way many years ago when a newb and burnt up my brand new Warn winch solenoids.
    Upgrading the alternator is beneficial at least I’m my case. Went from 90A to 160A and it has been awesome especially during hard winch pulls from my Warn HS9500i. I still need to keep 1500 rpm to not drag down the system.
    PzTank, doublethebass and Gunshot-6A like this.
  8. Aug 7, 2019 at 1:41 PM
    Wixo
    Wixo Platinum+ Member
    Hank
    ‘21 SR5 Tundra CM 5.7L Barcelona Red
    Tint, LED interior
    So if Im running a taco with all sorts of armor will a 9500lb be enough? Would the 10K lb be any better at speed and over heating/not over working the motor too much?
  9. Aug 7, 2019 at 1:47 PM
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    @Stocklocker....might want to keep an eye on this thread too
    :thumbsup:
    Stocklocker likes this.
  10. Aug 7, 2019 at 1:48 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Thanks. Watched.
    doublethebass[QUOTED] likes this.
  11. Aug 7, 2019 at 7:31 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    FYI - if running a dual battery setup it would not be recommended to have both batteries synced together when winching, you want to connect the winch to your starting battery and leave the aux battery isolated so in the case that if the main battery becomes discharged enough the truck won't re-start. Having the aux battery isolated will ensure you always have a way to get the vehicle started even after heavy winching. Most people that do the dual battery upgrade, make sure the new batteries are a larger CCA than OEM anyhow so you should have plenty of winching power.
  12. Aug 7, 2019 at 7:46 PM
    Toywoodsguy82
    Patrick
    Oregon
    I like where this has gone but I just put IE electrical upgrades as just an example. I sure there are other hidden costs some of which have been described
  13. Aug 7, 2019 at 7:53 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    another "hidden cost" if you want to be able to control the winch from in the cab, you will need a switch and some wire. Granted it's not a big cost item but it all adds up. My major "hidden cost" was the frame bending after several hard pulls, luckily I just did the work myself so all it took was a little blood and sweat.
    You can see the damage winching does to the frame in my post here, this was relatively minor compared to other peoples damage I've seen posted up.
    https://www.tacomaworld.com/threads...t-much-of-a-build-thread.337259/#post-8935425
    Beretta4x4 likes this.
  14. Aug 7, 2019 at 7:57 PM
    CedarPark
    CedarPark Master of Destroying CVs
    Dylan
    Cedar Park, TX
    '04 TRD V6 Taco, '11 2WD 5.7 Tundy
    Lights & Lockers & Duals
    After doing the Caddy alternator mod and pulling it out after a couple weeks I say +1 on this
    I’ve gone through two steel cables but I used it a lot, used to be a park ranger at an off road park. Got synthetic now no issues. So maybe that’s a hidden cost? Then just be sure to get a tree saver and a shackle as mentioned above
  15. Aug 7, 2019 at 8:15 PM
    #35
    fb40dash5
    fb40dash5 Well-Known Member
    People's Republic of MD
    11 V6 AC 4x4
    I mean... I think the biggest question, which affects all the answers, is just what level of prepared do you want to be, or how often & extremely are you thinking you'll use it?
    Wanting to have a working winch, just in case, on a solid mount, is one end of the spectrum. At the other end... do you want to be able to winch out of ANYTHING, and maximize your chance of getting out, even if your engine isn't running? Two pretty much totally different situations there.
    Electrically, I had a Superwinch 9.5 on my 1st gen, with the piddly factory alternator, a good group 31 AGM, and I think I replaced the factory cables with 2ga and ran 1/0 to the winch. Never had a problem with that setup, not that I used it often, but it winched the 5000lb truck down and back up a pants-crappingly steep hill once to get around an obstacle, along with occasionally being used to yard logs out of the woods.
    As for other stuff... I went nuts making it usable. Got a separate solenoid winch and made my own cables to the motor, as well as the ones from the battery. Wired the controller plug up on the grille, and also ran wires into the cab for a master switch (that killed the solenoid completely, from inside or from the controller plug) and an in-cab control switch. Then a bunch of good shackles, an ARB snatch block, a bubba rope type thing that I also use as a tree strap, and an extra ~90' of Dyneema rope I made into an extension.
    You can almost always go slow and let your alternator recharge your battery while you also let the motor cool down... but it's hard to reach that hard point 20' too far away cuz you scrimped on gear to buy a "300A" alternator, and an extra battery, mount and isolater.
    Hendrix834 and Thatbassguy like this.
  16. Aug 8, 2019 at 4:49 AM
    #36
    SR-71A
    Zack
    Southern Maine
    The only time that would be true is if for some reason you were winching with the engine off.. And there are very few scenarios I can think of where that would be the case.
    Otherwise you want the engine running, both batteries tied together (if you have duals), and then leave the truck running afterward while you clean up all your gear to let them recharge
    geekhouse23 likes this.
  17. Aug 8, 2019 at 4:55 AM
    #37
    6 gearT444E
    Deep South
    Herculiner Hootus
    If you row gears sometimes that's unavoidable, especially during a tough recovery. I agree you always want the truck to be running but id like to know I can still start my truck if for some reason it does stall Out.
  18. Aug 8, 2019 at 5:08 AM
    #38
    rollin904
    rollin904 Feather Slinger
    TJ
    Greenville, SC
    '14 DCSB 4x4
    Whatttt, I didn't know you could damage the frame from winching. I assume that's why the 90 degree bumper supports are common to add to these? I haven't pulled my bumper since installing it several years ago and have only used the winch a handful of times, though one time I used it to pull a stump out of our yard. FWIW OP, I got the Smitty 9.5 with synthetic rope, only other costs were a cutoff switch (~$70), wiring stuff ($20-30), and a fairlead ($30). My factory alternator and battery handle the load so far but the truck does dip in rpms and lights dim when I use it, I will replace the battery with something better once it starts giving me issues but for now I think it's sufficient.
  19. Aug 8, 2019 at 5:35 AM
    #39
    SR-71A
    Zack
    Southern Maine
    Hmm maybe you just shouldn't stall the truck :D :crapstorm:
    If you are still worried about it though, look into a Noco jump pack. The GB40 would be more than enough to start these trucks. I have the next size up, the GB70 because it was gifted to me. It fits in the cubby under the rear seats perfectly. Amazon and the OEM do decent sales from time to time too
    6 gearT444E[QUOTED] likes this.
  20. Aug 8, 2019 at 8:00 PM
    #40
    6 gearT444E
    Deep South
    Herculiner Hootus
    Sure can, the bumper bolts to 10 gauge steel. Doesn't last long on side pulls or any angles for that matter. The bumper supports are a band-aid to a shotgun wound.
