What are the lines on my rear axle ?
Discussion in 'Suspension' started by Poodle Head Mikey, Mar 21, 2013.
  1. Mar 21, 2013 at 12:29 PM
    Poodle Head Mikey
    Poodle Head Mikey [OP] Well-Known Member
    2007 Tacoma standard
    utility cap, ladder rack, frame hitch, sliding bed
    2007 Base w/std. cab and 2.7 engine
    On the rear axle are mounted two (plastic?) lines which connect to the outer end of the rear housing - about where the bearing might be. To the flange just inboard of the brake backing plate.
    The brake lines are metal - not them. What are the other two lines on my rear axle? Flexible - sort of look and feel like air shock air lines?
    Anybody know?
    PHM
  2. Mar 21, 2013 at 12:30 PM
    davidpick
    davidpick NWXPDTN
    David
    Everett, WA
    2004 Xcab 4x4 TRD
    probably ABS
  3. Mar 22, 2013 at 6:14 AM
    Poodle Head Mikey
    When I saw that you suggested: ABS I went out and looked closer to find that I was wrong about them being plastic lines - they go to some kind of electrical connection next to the top of the gas tank. <g>
    Some kind of sensor which compares the RPM of each wheel?
    PHM
  4. Mar 22, 2013 at 6:19 AM
    disc0monkey
    disc0monkey All right. I believe ya. But my Tommy Gun don't!
    wheel speed sensor the abs uses those too.
