What are the mesaurements for the ome lift kit?
Discussion in 'Suspension' started by aidenhardcore, Apr 10, 2012.
  1. Apr 10, 2012 at 4:51 AM
    aidenhardcore
    aidenhardcore [OP] Well-Known Member
    miguel
    boston,ma
    2010 4 door black
    None yet but soon all black.
    Hey guys, I have a ome lift kit. 2 inch Aal and no top spacer. So I should have 2.5 up front and 3 in the back since the back is higher. can someone tell me the measurements of it which people that have the ome kit. . From the hub to fender or from ground to fender. I wanna see If mine matchs up. Gonna Install my top plates today and wanna see if everything matches up to a full 3 inches. Thanks guys. These are what I have.
    39 inch from ground to fender in back. 25 from center hub to fender in back
    And 37 front ground to fender. And center hub to fender 23. Should that = to 2.5 up front and 3 in the rear. I have no idea haha. Thanks guys
  2. Apr 10, 2012 at 7:27 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Your hub to fender measurements are approx 2 3/4 over stock front , and 2 1/2 rear
  3. Apr 10, 2012 at 8:38 AM
    aidenhardcore
    miguel
    boston,ma
    2010 4 door black
    Ok great thanks. So when I put my top plate spacer things from ome , I should be at 3 Inches up front right?
  4. Apr 10, 2012 at 9:02 AM
    OZ-T
    Peter North
    British Columbia
    What spacer thickness ?
  5. Apr 10, 2012 at 9:20 AM
    aidenhardcore
    miguel
    boston,ma
    2010 4 door black
    I think there 1/4 and then that equals to 1/2 lift right. What ever came With the ome kit from toytec. I know it's suppose to lift the right 1/2 so 1/4 sounds right. My front is at a rake now and the back is higher so I wanna put the plates in and level the front
  6. Apr 10, 2012 at 1:27 PM
    OZ-T
    Peter North
    British Columbia
    You got 2 spacers ? Are they the same thickness , did they come with longer studs ? Do you own a tape measure ? Nibiru ?
  7. Apr 10, 2012 at 1:31 PM
    aidenhardcore
    miguel
    boston,ma
    2010 4 door black
    Yes 2 spacers. Same thickness. And yes longer studs. I do
