What are the prons and cons of buying a new engine
Discussion in '1st Gen. Tacomas (1995-2004)' started by hnrajah, May 21, 2010.
  1. May 21, 2010 at 11:01 PM
    JasoTaco
    JasoTaco Well-Known Member
    Salt Lake City, Utah
    09 Tacoma TRD Off Road
    ToyTec Ultimate 3" Lift -TSB Rear springs - TRD Cold Air Intake - TRD Skid Plate - Total Chaos Upper Control Arms - 2 Hella Rallye 4000 lights (130W Bulbs) - Clear Bra - Under Coat - Bed extener - Toyota Bed Mat - Weathertech floor mats - Tailgate hose clamp & washer mod - PIAA Fog Lights - ScanGauge II - Beefed Sliders - Differential Breather Mod - Heated Seats - All-Pro Bumper - Warn M8000 Winch with wireless controls - Boztec Diff Skid - ATO skids
    Pro - I would like to see a V8 under the hood of your Taco.
  2. May 21, 2010 at 11:31 PM
    75thrangertaco
    75thrangertaco Sua Sponte! RLTW
    charles
    casper wyoming
    procomp 6 inch co lift ,305/55/20 xtreme a/t tires,4.88 gears ,,grill shell painted white billet inserts.Trd cat back ,
    i have probably installed 75 engines in my life. please take great care where u buy it or have it rebuilt, there alot of bad machine shops out there sure all give you a warranty but its frustrating to remove an engine two or three times till they get it right, i personaly would contact jasper engines, they have a 5 year 100000 mile nationwide parts and labor warranty standard,you can also purchase the install kit for your specific vehicle.comes with everything but coolant and oil,also if there is an inherant problem with certain engines they engineer it out. i have ony had a problem wih one of there engines and they flew a rep out and he fixed it, ps i am an ase certified master auto and diesel tech and this is just my 2 cents,
  3. May 22, 2010 at 12:23 AM
    kumaWRX
    kumaWRX Well-Known Member
    Jase
    Oahu, Hawaii
    2004 TRD Offroad PreRunner 3.4L V6
    SAW 2.0 Coilovers, Wheeler's 3-leaf AAL, Toytec 1" lift shackles, Bilstein 5100 rear shocks, aFE Stg. 2 intake, Doug Thorley headers, Magnaflow muffler, 16x8 ProComp 7089 wheels, Toyo Open Country A/T tires, Pamalu bedliner, Bakflip G2 bedcover
    That or try and shoehorn a 3.9L 4cyl Cummins, haha.
    But as someone mentioned earlier, be careful where you get your engine from. At work, I've had to do a motor swap twice because the junkyard guy said the motor only has about 40k miles on it, he didnt mention that whoever owned it before probably only changed the oil once in that time and the motor smoked like a chimney.
  4. May 22, 2010 at 8:44 AM
    Project.paradigm
    Project.paradigm Well-Known Member
    Oil Country,Alberta, Canada
    04 TRD 4X4 Dub cab
    Airlift rear air bags. Hood struts. sockmonkey bedside decal. TRD supercharger(not installed). Deckplate. Grey wire mod. Extended rear diff breather. 6000k HIDS. 18"Magnaflow. Truxxx 3" level kit. (Temporary) Wet Okole seat covers. BoxRocket bed rack. Bora 0.75 wheel spacers All pro sliders. BAMF BPV. B&M trans cooler.
    Keep in mind that if you get a new engine and don't do oil changes, it'll void the warranty. I'd rebuild if it were me. Like others have said, you could rebuild it with upgraded/stronger components and also supercharge it for the price of a new one.
  5. May 22, 2010 at 9:45 AM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    You should be locked up for treating your taco so bad!!! 16 mnths without an oil change :mad:
  6. May 22, 2010 at 10:42 AM
    hnrajah
    hnrajah [OP] Active Member
    Harry
    Charleston, SC
    2004 toyota tacoma
    hmmm. that is interesting. I look into the Jasper company because I'd like an engine with a good warranty.
  7. May 22, 2010 at 11:01 AM
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
    Did the truck get ran out of oil then? Sure, 16 months is way past due for an oil change of course, but the engine should still run nonetheless even with the dirty oil assuming the oil is not dangerously low to cause it to seize. But I guess that I can see if a ton a miles were put on it between that time period it just wore out the oil so much that caused excessive wear and ruined the engine.
  8. May 22, 2010 at 11:12 AM
    hnrajah
    Harry
    Charleston, SC
    2004 toyota tacoma
    7500 miles, im guessing yeah it ran out of oil. THey say it is because I didn't change the oil. So thats that.
  9. May 22, 2010 at 5:45 PM
    derekp
    derekp giddy up!
    Derek
    Grand Forks, ND
    2001 X-Cab 4x4 TRD V6 5Spd
    Deck plate, Flowmaster Delta-Flow 40 series, 265/75-16 Wrangler TDs, more to come...
    Check out http://www.dieseltoyz.com/
    The thought of a diesel Tacoma is mind boggling! If you are thinking an engine swap because you want to keep this truck for a long time, this might be your ticket. It is a bit pricey but they do everything. I think they might have a cheaper option where they order the engine/transmission (front clip) for you and you do it. Not sure, but something to look into.
  10. May 22, 2010 at 6:23 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Dude I ran a taco engine (2.4L) without oil for 150 simulated miles and it still worked fine. Shop class experiment.
  11. May 22, 2010 at 6:38 PM
    Madjik_Man
    Colorado Front Range
    A brand new engine can be trusted so long as you treat it right.
    (just like a woman, btw)
  12. May 22, 2010 at 7:05 PM
    Taco76087
    Taco76087 Well-Known Member
    Robert
    Weatherford,Texas
    04 Tacoma prerunner TRD SR5
    Rockford Fosgate p2 10'', Q-Logic Enclosure, JVC KD-PDR30 Ipod Connection, Rockford p200.2 Amp, Clear Corners, KING Coilovers, Rancho Rear shocks FJ TRD Trail Teams Wheels with 285/75/16 Duratracs
    As mentioned I would try Jasper engines or go to your local auto parts store and they also sell remanufactured engines.
  13. May 22, 2010 at 9:30 PM
    hnrajah
    Harry
    Charleston, SC
    2004 toyota tacoma
    Thanx for the advice. THe truck shuddered before it broke down. Like the front area made the whole truck shudder right before it couldnt drive anymore. If it can drive, 10 mphs tops and that is with the shuddering.
  14. May 22, 2010 at 10:53 PM
    75thrangertaco
    charles
    casper wyoming
    auto parts store engines suck!i actualy put 5 in the same vehicle in the course of 2 years.finaly they stoped warrantying them for the customer. so he paid me to take the last one apart. ummmm it had 3 sizes of crank bearings , 2 different cylinder heads ie different chamber size. and 7 flat top pistons and one dish piston. garbage. this is not the first time ive run into this.
  15. May 23, 2010 at 5:59 AM
    #35
    Bretsuaz48
    Bretsuaz48 Well-Known Member
    Bret
    Surprise, Arizona
    2016 Sport
    How many miles did you drive in the 16 months?
  16. May 23, 2010 at 7:40 AM
    #36
    Barnone
    Barnone Guest
    Are you sure that the engine is damaged? Check the oil? Have you had a mechanic take a look at the engine? Bad to not change the oil for 16 months but shouldn't be terminal unless all the oil is gone.
  17. May 23, 2010 at 10:49 AM
    #37
    hnrajah
    Harry
    Charleston, SC
    2004 toyota tacoma
    7500 miles
  18. May 23, 2010 at 10:53 AM
    #38
    Justin723
    Justin723 Dont judge me
    Justin
    Phoenix AZ
    02 Tacoma TRD
    Performance- bored .20 over, Doug Thorely Headers, Magnaflow Exhaust, and K&N cold air intake. Exterior- Trail Gear Solid Axle Swap, ARB compressor, high pinion 4.88 with ARB locker, 4.88 TRD Locker in the rear. Interior- 2 10inch JL W1 subs, Alpine MRX-V70 amp, Alpine type R SPR 17C 6x6 speaker in the back, Focal 165 VR with crossover tweeter up front, and Weather Tech floor mats.
    I just got done rebuilding my engine. 3.4 2001 tacoma cost me about 1600 dollars. But i also did it myself.
  19. May 23, 2010 at 10:57 AM
    #39
    hnrajah
    Harry
    Charleston, SC
    2004 toyota tacoma
    Positive, I've taken it to two places. The engine needs to be replaced. The truck shudders like crazy and doesnt go over 10 mph.
  20. May 23, 2010 at 11:00 AM
    #40
    Justin723
    Justin
    Phoenix AZ
    02 Tacoma TRD
    Yeah but you gotta think man its only the bottom end that needs to be rebuilt. Thats not to bad if you ask me. Heads are good and shoot thats like the hardest part.
