What are the specs on our coilovers?
Discussion in 'Suspension' started by HB52taco, May 19, 2010.
  1. May 19, 2010 at 12:26 AM
    HB52taco
    HB52taco [OP] Member
    Alex
    Huntington Beach
    06 4x4
    Bass you can hear a block away
    I am about to order some custom kings and need to know the length of a coilover to get, compression length, and extended length with a 2" lower rod. I cant find any specs on the kings available but I have the option to get the setup cheaper in pieces.
  2. May 19, 2010 at 12:31 AM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    I believe they should be 8" strokes. someone correct me if I'm wrong. Spring Rates varies, but I think they are 650# or 700#. Valving I'm not too sure on either.
    If you go with the eyelet to eyelet coilovers you're going to need a top plate mount. And I'm, pretty sure they don't have that 2 in lower piece on those coilovers.
    Edit: I think the ext travel version is around 10".
  3. May 19, 2010 at 8:42 AM
    HB52taco
    Alex
    Huntington Beach
    06 4x4
    sounds good. what would i get for compression and extended length
  4. May 19, 2010 at 5:36 PM
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    why are you getting custom ones? just tell them your truck and they will take care of you...why are you making it harder than it has to be?
  5. May 19, 2010 at 7:35 PM
    Timber
    Timber Crankey Old Yacht Jockey
    Tim
    San Pedro Bay Ports
    just a couple comfort items.
    You better double check the 10" travel shock. If a replacement Icon shock is 8" I know that the extended travel is not 2" longer. you may see 10" travel at the spindle but not shock stroke.
  6. May 19, 2010 at 7:49 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    yeah, there is no way a 10" coilover is gonna fit on a stock susp.
    why order "custom" kings?
    the OE replacment shock is what you want. it made specificaly for the tacoma
    http://downsouthmotorsports.com/i-1...05-2010-toyota-tacoma-4wd-2wd-pre-runner.html
  7. May 19, 2010 at 7:52 PM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    also, the OE shocks are not the same as an 8" coilover.
    the OE's are smaller
    in these pics you can kinda see how much smaller the OE shock is complared to the 8" LT shock. not the best pics for comparison but you get an idea...
  8. May 20, 2010 at 8:28 AM
    Downsouth Motorsports
    Downsouth Motorsports Downsouth Motorsport Vendor
    Lakeside, Ca. 92040
    2017 4-Runner Dirt King Long Travel King 2.5 Coil-Over / 2.5 Bypass Front and Rear ICON Rear Upper and Lower Arms ICON Rear 2" Springs 34" x 10.50" x 17 Toyo Tires on 17" x 9" RaceLine Wheels
    I have to ask too.....what is the need for a "custom ordered" shock? Let us know and maybe we can help you out.
    Marco @ DSM
  9. May 20, 2010 at 6:23 PM
    HB52taco
    Alex
    Huntington Beach
    06 4x4
    I know someone who can get king shocks for cheap but i would have to get separate coils. I dont know if i can get the OEM setup because it has a spring. I am giving him the product number so I will find out if I can but if not then I will have to buy only the shock. The spring rate is #550 lb I believe.. correct me if im wrong
  10. May 20, 2010 at 6:28 PM
    yosh2000
    CO
    '17 Tundra CM 5.7
    your wrong.. spring rate is 650#
  11. May 21, 2010 at 8:20 AM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    huh?
  12. May 21, 2010 at 8:30 AM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
